2012/09/26
I used both Crew RKTablets Genio CM10.1 beta build v1.3.3 and now build 1.3.4, these roms for my Cube U30GT-H run very smoothly and everything seems great except one problem. The auto-rotation funtion when enabled, the screen edges flickers everytime I rotate the tablet Black and white stripes, sometimes few strips sometimes covers full screen.
Please see the screen during rotation below -
Is there any solution to this glitch or any fix?? Please help or advise..Thanks in advance!
2013/06/28
I solved it in my tab (Scopad Hercules SP0718 re-banded from U9GT4 in Thailand) but must use specified mod system.img and mod boot.img. rotation is very smooth no artifact /flicker on screen. only problem is battery info.
Sorry for bad English
Anucha
The following users say thank you to anu2013 for this useful post:
lessismore8848
2012/09/26
anu2013 said
I solved it in my tab (Scopad Hercules SP0718 re-banded from U9GT4 in Thailand) but must use specified mod system.img and mod boot.img. rotation is very smooth no artifact /flicker on screen. only problem is battery info.Sorry for bad English
Anucha
Seems a bit complicated to me. Am just a novic with little knowledge on playing with ROM. Looking for some .apk or .zip files to fix this bug but thanks mate.
2013/06/28
lessismore8848
2012/09/26
anu2013 said
Sorry for make zip files to fix bug. I can't remember files to fixed it. You must flash rom by RKAndroidTool only.I can't confirm it will solved to your tab in my mod. you must test it by yourself, If you want to test I will share my mod to you.
Sorry for bad English again.
Anucha
Hi Anucha,
Not a problem, your english is good my friend, as far as it makes sense! Wow thank you for your generosity, specially for posting youtube video!! Yes I have been using RKAndroidTool to flash my ROM and am willing to test whatever to remove this flickering bug
Yes please! send me your mod (inbox or send link) and I will give it a go.
Cheers
2013/06/28
\RKAndroidTool//
How to.
1. Unzip "CM10.1_SP0718_New2.7z"
2. Replace your parameter, stock recovery.img and kernel.img in folder "ROM"
3. Follow to pictures.
If it work for you maybe you found problem
1.camera because I fixed rotation.
2.sensor
3. etc...
good luck to you.
Anucha
lessismore8848
2013/10/21
those files are changed
http://download.modaco.pl/gles.zip
rotation animation is now ok... but gpu performance is low ;/ i prefer to have better gpu performace and animation is not so important
2012/09/26
anu2013 said
\RKAndroidTool//
How to.
2. Replace your parameter, stock recovery.img and kernel.img in folder "ROM"3. Follow to pictures.
2.sensor
3. etc...
good luck to you.
Anucha
My apologies! been quite busy with my daily job and stuffs, couldn't check the post regularly. Woww! Appreciate very much your help and information. I'll definitely give a try as soon as possible and let you know how things go! Thanks Anucha, you are the boss
2013/06/28
Hi Ryrzy.
Thank you so much for test and search flies are changed.
My tab used original rom from OMA, but it is slow OpenGL 2.0 and more lag in 3D game.
When I mod it work fine and good performance. only problem is battery info(fix from OMA is not work) and can't to charge battery in power off mode, must open to charge battery.
Can you help me in this problem?
Thank you.
Anucha
edit:
https://docs.google.com/file/d/0B3_x7kKtNBjcenRGTGtScGtBNDg/edit
2012/09/26
Hello Anucha,
Yes, I flashed my Cube U30GT-H with modified CM10.1_SP0718_New2.7z (replaced parameter, stock recovery.img and kernel.img as you instruced from Oma RK30 CM10.1 v1.3.4) and it works!
But some pitfalls like speed is lagging a bit, sounds on touch or notification are missing, no auto brightness etc., gpu speed was even worse with Apex launcher. So, came back to Nova again and it rocks! Most of all auto rotation is fixed. Really Happy! Will stick with it until OMA comes up with a good fix or final release is out.
Once again thank you for supporting
Cheers mate
60 Guest(s)
Devices in use: Desktop (54), Phone (6)
