Rk3066 Kernel problem
olo
2014/09/27 - 22:55
Hello
is it possible to overclock the processor and gpu? currently max is 1.6GHz processor and 266MHz for the gpu
I read somewhere on the internet that goes to 1.7GHz processor and gpu tweak to set to 400MHz
or upload a newer kernel as far as is at all? which will work on my tablet
I tried to do it by "rkpatchomatic tool"
but always leaving me an error CPU
performance of my tablet
CPU: Rockchip 3066 Cortex-A9 Dual Core 1.6GHz
Graphics: Quad Core Mali 400 4 Ă— 250
RAM: 1GB DDR III
Flash memory: 8GB
TF CARD: Support micro SD up to 32 GB
USB host - connect for example. External drive, modem, etc..
Screen: 9.7 ", 1024 x 768 pixels, 10-point multi-touch
Wi-Fi: 802.11b / g / n
Camera: VGA front, rear 2-megapixel
System: ANDROID 4.1.1 Jelly Bean
Video formats: AVI, MKV, VOB, WMV, ASF, PMP, RM, RMVB, MOV, FL, H.263, H.264, MPEG4, VP8, RV, AVS - FULL HD
Audio formats: mp3, wma, ogg, aac, wav
Image formats: jpeg, png, bmp, gif
Output: mini HDMI, mini-USB, headphone jack 3.5 mm
Battery: 8000mAh
adds the file dmesg from the original android 4.1.1 (original) and 4.2.2 (custom by Oma RK30 but my kernel) and the kernel
kernel 3.0.8+ EM3066-912D @ V02 # 226
Link - https://drive.google.com/file/d/0B6wV1vQXePFZRFptLWhDRVgyTDA/edit?usp=sharing
sorry for my english I'm from Polish
Olaf
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/09/28 - 16:30
rkpatchomatic tries to patch a binary file, but not all kernel have the right things to get patched.
If you want to overclock it in the right way, you need the kernel sources.
I was able to patch our kernel, but without having the right sources for your tablet, it is impossible.
Cheers
JochenKauz
olo
2014/09/28 - 19:46
The manufacturer has not made the picture android 4.1.1 and later released for him .
only " RK30 Genio by Oma rocks - AOSP 4.2.2 " I work after swapping the original kernel + fixes to WiFi from
" Oma Pipo S3 Wifi Fix"
Thank you reply
Olaf
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/09/28 - 19:54
If the distributor is not publishing the kernel sources, no way to implement a good overclocking.
Sorry.
73 Guest(s)
Devices in use: Desktop (63), Phone (9), Tablet (1)
ondateste
lilila3
Anatrop
antoniors021
wemiy54158
sidor
