Q) Can rk30 Genio 4.2.2 or CM 10.1 be flashed in any rk3066 device ??
Lava Mtab
greyjawripper
Forum Posts: 13
2013/12/10 - 21:22
I got a question if the ROMs I mentioned in the title can be used in any rk3066 device ?? I have a Lava Mtab ( not so popular) which has no development support at all ....... I've rooted it but I want to upgrade it to 4.2.2 ......
please tell me if its possible here are the specs
TECHNICAL SPECIFICATIONS FOR LAVA M TAB
GENERAL
Operating System: Android v4.1 (Jelly Bean)
Processor: 1.5 GHz Dual Core
Memory: 1 GB DDR3 RAM
DISPLAY
Resolution: 1024 x 600 Pixels
Type: WSVGA TFT LCD Display
Other Display features: Capacitive Touchscreen
CONNECTIVITY
Wi-Fi: 802.11 b/g/n
3G: Supports 3G Dongle
Bluetooth: v3.0
Other Connectivity
options:
Digital Library App for accessing educational content from memory card -
Content has MBOSE Class XI and Class XII Syllabus, supplementary content for
IIT JEE and Medical entrance
PORTS
HDMI: HDMI 1.4
USB: USB 2.0
3.5mm audio jack: Yes
MULTIMEDIA FORMAT SUPPORT
Video Player: 3GP, MKV, AVI, RMVB, MP4, TS, FLV, WEBM, WMV, ASF
Audio Player: ogg, wav, wma, mid,midi, mp3, 3gp(aac), mmf, amr
CAMERA
Rear: 2 Megapixels
Video recording: HD Video Support
PHYSICAL SPECS
Dimensions (mm): 194x122.4x10.7
Weight (g): 350
BATTERY
Capacity: 3700 mAh
STORAGE
Internal: 4 GB
Expandable: Up to 8 GB
2013/12/10 - 22:06
Is a stock firmware available?
greyjawripper
Forum Posts: 13
2013/12/10 - 23:31
no but I have a cwm nandroid backup
greyjawripper
Forum Posts: 13
2013/12/10 - 23:35
I did manage to boot up 4.2.2 generic ROM from FMA site by replacing the kernel inside the zip with the stock kernel from the nandroid backup.......but the rom came with lots of bugs of course.......
greyjawripper
Forum Posts: 13
2013/12/11 - 20:16
the AOSP 4.2.2 booted in my tab with stock kernel but the sensors are a bit messed up... everything is reversed.... can u help me fix it??
greyjawripper
Forum Posts: 13
2013/12/12 - 00:38
these are my reeading from the app androsense if this will help
landscape: x+10
left to portrait : x+6
right to portrait: x-6
horizontal screen up: z+8
greyjawripper
Forum Posts: 13
2013/12/12 - 01:14
I think sensors for my device would be ..... x= -x, y= -y ....not sure bout. z though
fuyun1965
Forum Posts: 24
2013/12/12 - 05:51
Hi, I am facing the same problem. My pad is a Yuandao N90ii RK3066 IPS. I use Kernel from this forum "RK30_kernel_308_n90_yuandao", and can sucessfully flash "CrewRKTablets_RK30_Genio by Oma_AOSP_4.2.2_v3.3". But machine can't boot after flashing. What can I do? I have to flash back to the official stock 4.1.1, while just having 1G application partition.
Please help. Thanks!
greyjawripper
Forum Posts: 13
2013/12/12 - 20:04
any help with the sensors :(
greyjawripper
Forum Posts: 13
2013/12/12 - 21:40
I tried all of those ..... non of them seem to work ........ and I noticed one more thing this morning .... Bluetooth doesn't work.... it switches on but can find and devices or be found by and devices
greyjawripper
Forum Posts: 13
2013/12/12 - 21:47
even the boot animation is upside down
2013/12/12 - 21:53
Can you pls install sensor fix 1 and give the values?
greyjawripper
Forum Posts: 13
2013/12/12 - 21:56
landscape: x+10
here I already did that on the sixth post :D
2013/12/12 - 21:58
x in both directions could not be ;-)
No, I need the values for sensor fix 1.
53 Guest(s)
Devices in use: Desktop (46), Phone (7)
