Prestigio PMP5880D CM10.1
CM10.1 on PMP5880D
BL4CKSH33P
Forum Posts: 23
46
2014/02/14 - 21:39
Okay. I will stay on 1.3.4 with rotation fixing app.
Just a last question. Can I rotate the camera's picture? It's flipped on the screen, the front and the rear camera too.
BL4CKSH33P
Forum Posts: 23
48
2014/02/18 - 18:52
Is possible to make CM10.1 rom USB Bluetooth dongle compatible? I have one, but the system recognizes it as Hardware Keyboard...
49
2014/02/18 - 20:07
No. For this you will need a kernel without bt/rfkill stuff.
pria
Forum Posts: 16
50
2014/03/15 - 18:25
viktors70gp said
Installed on Prestigio PMP5880D as d44 did with following diffs
CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.5 with RK30 Kernel 308 Pmp5880d Prestigio.
CrewRKTablets_CM10.1_v1.3.5_TabletUI_fix
+ applied Gallery2.apk_.zip to fix cameras (front and rear) upside down.
Works great, but external display connected over HDMI is upside down. Is there any possibility to fix it?
Well, I tried this configuration on Prestigio PMP5780D (with 5780d kernel) but:
- orientation of a screen is still 180 degree opposite (up down)
- battery percentage doesnt work (question mark or 0 all the time)
Any idea for a solution?
51
2014/03/15 - 22:47
Is wifi working on PMP 5780D?
pria
Forum Posts: 16
52
2014/03/16 - 12:59
Hi Oma!
So, I instaled on my PMP5780D these items:
CrewRKTablets RK30 Genio By Oma CM10.1 v1.3.5
Oma RK30 CM10.1 Format NAND
CrewRKTablets_RK30_CM10.1_sensor_x=-z_y=-x_z=y
Oma Genio CM10.1 TabletUI Battery Percentage Mod
CrewRKTablets RK30 CM10.1 V1.3.5 PvsZ2 Fix
CrewRKTablets RK30 CM10.1 Model Fix Pmp5780d 2
CrewRKTablets RK30 CM10.1 Akku Fix
CrewRKTablets CM10.1 V1.3.5 TabletUI Fix
Conclusions:
Orientation of a screen is ok when I used this sensor:
Wifi DOES NOT work at all. It is possible to switch it on but it keeps on saying "wifi is switching on" and nothing happens.
Strange thing about battery. Even I installed:
Percentage of a battery doesnt work It shows either "?" or "0". Battery tab in setting writtes - info unavailable. As system thinks that battery is empty, very short time after switching tablet on it starts to switch system off saying ("switching off"). If I connect a recharger, it doesnt recognize it, still written "Connect recharger". If I switch a tablet off, red LED is on (indicating charging) but it never changes to orange (indicating battery full) even after all night recharging!
Camera - there are two apks. It crashes and after it camera doesnt work anymore.
Oma, can you help me somehow? I really want to use CM, it is great distro, I used it on my previous tablet Ainol Aurora II.
Thank you a lot.
pria
Forum Posts: 16
53
2014/03/16 - 13:06
One more thing...
When connecting a tablet as the Mass Storage, Windows 7 does not see a tablet. It means that when I connect a tablet to pc by USB, it does not offer me to switch USB mass storage on to make internal storage of a tablet available and visible in pc.
54
2014/03/16 - 14:20
Tried now several times to undertand the problem. The problem is that the stock kernel is patched against the stock build. So with this "non standard kernel" we do not have any chance to run other buids. Sorry.
pria
Forum Posts: 16
55
2014/03/16 - 18:06
Hi Oma!
Well, what does it mean? Does it mean that there is no solution for PMP 5780D? Is it only the problem of your CM 10.1 and / or PMP 5780D?
pria
56
2014/03/16 - 18:36
This means we cannot use the stock kernel to boot other builds.
pria
Forum Posts: 16
57
2014/03/16 - 18:52
Well, I am sorry, I am more BFI than an expert, so I dont understand what you are writing me concerning kernel.
So, I will try to ask again... Is any solution to fix these problems to be able to use CM 10.1 on Prestigio PMP 5780d or do I have to go back to the official firmware?
pria
Forum Posts: 16
58
2014/03/16 - 18:52
I meant BFU, sorry :)
59
2014/03/16 - 19:17
Unfortunately I do not have a solution. So yes, go back to stock.
pria
Forum Posts: 16
60
2014/03/17 - 13:01
OK, I am back to stock. Anyway... Would be possible at least to extend internal storage to 2.5 GB? Could I use a NAND fix for a stock fw? And would be possible to install CWM?
Pria
Currently Online: Daryel
95 Guest(s)
Devices in use: Desktop (85), Phone (10), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
