Prestigio PMP5880D CM10.1
CM10.1 on PMP5880D
31
2014/01/20 - 23:03
Ok, then you need to do a clean install.
BL4CKSH33P
Forum Posts: 23
32
2014/02/07 - 21:59
Oma, what did You change in CM10.1 1.3.5 from 1.3.4? The 1.3.5 has the same issue with HDMI as AOSP rom, but the 1.3.4 works OK. Maybe this could be a solution for AOSP's issue...
33
2014/02/07 - 22:08
Just the mali driver. Stay with the v1.3.4 build, it is the best one.
v1.3.5 is for all user claims the rotation artefacts ;-)
BL4CKSH33P
Forum Posts: 23
34
2014/02/07 - 22:13
1.3.5 and AOSP 3.3 has the same driver version? Because for PMP5880D the AOSP is better, because it has proper fix for the rotation problem.. maybe a driver change would fix the HDMI there..
35
2014/02/07 - 22:18
Negative, not the same mali driver. What is the problem with the orientation?
BL4CKSH33P
Forum Posts: 23
36
2014/02/07 - 22:26
The orientation with sensor fix is ok, but our tablet has a flipped lcd, so the landscape, what is for me normal, is for the system the "reversed landscape". So the HDMI is flipped, and the landscape-only apps are flipped too. In AOSP it is possible to fix it with a build.prop modification, but in CM it's not working, the build.prop mod flips only screen, but not the touchpad... I read somewhere, that's could be a touchscreen driver problem...
37
2014/02/07 - 23:20
This indicates that stock kernel and stock build patched vice versa in all possible ways. So stock kernel "corrects" orientation for specific cases which is in the build (framework) right. No idea to deal with that. Sorry.
38
2014/02/08 - 14:16
Try this and reboot: http://crewrktablets.arctablet.com/?wpfb_dl=1369
Is the rotation of the landscape-apps ok now?
Can you also try this build, if HDMI orientation is right with you? http://crewrktablets.arctablet.com/?wpfb_dl=984
BL4CKSH33P
Forum Posts: 23
39
2014/02/09 - 19:19
This rotation App can't fix the hdmi problem, and the build 1.3.2 has same issues. I found in ownloads 2 earlier AOSP rom's for rk3066, I wanted to try them to try hdmi, but both has a problem. After flashing the tablet every time rebooting to recovery. Is possible to fix this? Thanks..
40
2014/02/10 - 07:58
The rotate app should only correct the rotation of landscape apps. Older AOSP builds needs a 3.0.36+ kernel first (see instruction).
Try also older builds v.1.3.1, v1.3, 1.2.4 .... we have had a build with wrong HDMI orientation.
BL4CKSH33P
Forum Posts: 23
41
2014/02/10 - 11:28
I found a solution for HDMI problem with a build.prop option:
persist.demo.hdmirotationlock=false
It enables the rotation of hdmi screen. Next i need to check the camera settings...
BL4CKSH33P
Forum Posts: 23
42
2014/02/12 - 21:09
Oma, can You make me a sensor fix for these parameters? Thanks!
Landscape (the longer sides of tablet are at the top and bottom of the device):
x:+9,8
Portrait (from landscape turned to right):
y:+9,8
Reversed portrait:
y:-9
Reversed landscape:
x:-9
Thanks!
netlars
Forum Posts: 149
Thanks Received: 29
43
2014/02/13 - 17:09
please test this fix: Sensor fix X=-Y_Y=X_Z=Z
BL4CKSH33P
Forum Posts: 23
44
2014/02/13 - 23:52
Hello!
What can I do, if I have inverted touch screen?
There is a fix for our tablet with ft5x0x_ts.idc conf file, but which are the touchscreen driver files?
45
2014/02/14 - 07:18
I guess you tried to correct orientation in CM10.1 via build.prop. This doesn't work.
97 Guest(s)
Devices in use: Desktop (86), Phone (10), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
