Prestigio PMP5880D CM10.1
CM10.1 on PMP5880D
BL4CKSH33P
Forum Posts: 23
2013/11/11 - 20:51
The orientations are good. Is somewhere defined, that which is the base orientation of the tablet? Now the base is upside down. Maybe I use only the tablet flipped?? :) But it is really uncomfortable to have hardware keys at the bottom...
Something other...Is there a USB Blouetooth dongle support? I have a broadcom chip based usb dongle. How can I connect for example a phone to my tablet via Bluetooth?
2013/11/11 - 21:02
Don't understand. Just turn the tab.
Genio has BT on board, so never tested with a BT dongle. So put in and test.
BL4CKSH33P
Forum Posts: 23
2013/11/11 - 21:47
I didn't know, that the Auto-rotate function is Settings menu is not the same as the Orientation option in the Top-Right drop-down menu. Sorry, my fault. I tested the 3D performance, and it's good, better than stock rom.
Thanks for Your support, and keep up the good work! Any plans for CM10.2, or KitKat for RK30 boards?
BL4CKSH33P
Forum Posts: 23
2013/11/14 - 23:05
Hello!
Found 2 bugs:
- Camera picture is upside down
- In When connected to PC in Mass storage mode, the tablet mounts only external SD Card. Is it normal?
2013/11/15 - 23:28
d44
d44
2013/11/21 - 21:12
Installed on Prestigio PMP5880D
CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3.7z with RK30 Kernel 308 Pmp5880d Prestigio
Oma RK30 CM10.1 Format NAND.zip
CrewRKTablets_RK30_CM10.1_sensor_x=y_y=-x_z=z.zip
CrewRKTablets_CM10.1_v1.3.2_model fix_pmp5880d.zip
CrewRKTablets_CM10.1_v1.3.2_model fix_pmp5880d_2.zip
CrewRKTablets_CM10.1_v1.3.2_TabletUI_fix.zip
Oma_Genio_CM10.1_TabletUI_battery percentage mod.zip
Works very well. Match  Better than stock. Battery time is improved.
Really Big thanks for Your Work.
2013/11/21 - 21:28
Fine. Thank you for feedback.
viktors70gp
2014/01/14 - 15:53
Installed on Prestigio PMP5880D as d44 did with following diffs
CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.5 with RK30 Kernel 308 Pmp5880d Prestigio.
CrewRKTablets_CM10.1_v1.3.5_TabletUI_fix
+ applied Gallery2.apk_.zip to fix cameras (front and rear) upside down.
Works great, but external display connected over HDMI is upside down. Is there any possibility to fix it?
netlars
Forum Posts: 149
Thanks Received: 29
2014/01/16 - 06:42
Sorry, I forgot where it is surrounded in the code.
When I found it, I'm writing.
viktors70gp
2014/01/16 - 08:44
Great! I am looking forward to your success.
Moreower I've found, that apks which doesn't support rotation are upside down too (and because there is TN display, this sides are bad for watching - especially portrait ones).
Tedi1987
2014/01/20 - 22:16
Hello all, my first post here.
First of all I would like to thank Oma for a great job with the CM. I use it a few days and until today it was all about a few minutes ago I wanted to turn on the my Prestigio 5880D, and I noticed that something is wrong - the tablet caught bootloop.
I do not have a backup, what can I do to try to fix the tablet before I have to flash ROM again?
2014/01/20 - 22:38
System is corrupted somehow.
Run RKAndroidTool and flash system.img (tick parameter and system).
Tedi1987
2014/01/20 - 22:45
Flash like ROM -> EraseIDB and next run or only tick parameter + system and only run?
2014/01/20 - 22:47
Only Run. EraseIDB will kill your partition layout.
Tedi1987
2014/01/20 - 22:59
I did what you wrote and unfortunately it didn't help - tablet still has bootloop.
Currently Online: Daryel
93 Guest(s)
Devices in use: Desktop (85), Phone (8), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
