2013/11/10
Hi all!
I tried CD10.1 rom on my PMP5880D with stock kernel. It boots up, but I have some problems. The display auto-rotation not working properly, the touch screen works, but I have a white circle, what I can move with touches, like a laptops touchpad, an the wifi is not working. Can anybody help me with porting? Thanks!
Touch config: http://crewrktablets.arctablet.com/?wpfb_dl=1018
For wifi use the autoloader http://crewrktablets.arctablet.com/?wpfb_dl=981 and copy over the .ko's from stock firmware. Oftern the modules has been renamed by the manufacturer ...
See also discussion here http://forum.xda-developers.com/showpost.php?p=46583859&postcount=622 or at 4pda.ru
Use as it is. Maybe we have luck.
If not cpoy files over.
2013/11/10
Simply running the zip is not working. In stock /system/lib/modules I have theese files:
8188eu.ko
8192cu.ko
mali.ko
mali.ko.3.0.36+
mlan.ko
rk29-ipp.ko
rk29-ipp.ko.3.0.36+
rkwifi.ko
rkwifi.ko.3.0.36+
ump.ko
ump.ko.3.0.36+
usb8xxx.ko
vpu_service.ko
vpu_service.ko.3.0.36+
Which files to use? I need to copy files only from /system/lib/modules, or from /etc too?
Try all 5 ... otherwise: http://forum.xda-developers.com/showpost.php?p=46532663&postcount=619
2013/11/10
Okay, main functions working, I'm starting to test it now.Â
The working configuration for PMP5880D:
- Flash Crew RKTablets Genio CM10.1 v1.3 – 03.10.2013
- Flash CrewRKTablets_CM10.1_v1.3.2_model fix_pmp5880d.zip - Touch screen fix
- Flash CrewRKTablets_CM10.1_v1.3.2_model fix_pmp5880d_2.zip - WiFi fix
- Flash CrewRKTablets_RK30_CM10.1_sensor_x=y_y=-x_z=z.zip - Screen rotation fix
Great thanks Oma!!!
PS.:
The PMP5880D's stock rom has it's main position is 180 degrees turned, so the lockscreen is 180 degrees turned. Is it possible to change this position? Thanks!
2013/11/10
I have problem with screen rotation. When I turn out screen-auto rotation, the screen goes to its base position (landscape), so I can't fix screen in Portrait mode.Â
I installed the androsensor app, and flashed CrewRKTablets_RK30_CM10.1_analyse_sensor.zip
When I hold the tablet landscape, the screen is flipped 90 degrees to left.
I get theese numbers:
- tab vertical, landscape (x=+9.6)
- turn left to portrait (y=-8.5)
- turn right to portrait (y=9.8)
- tab horizontal screen up (x=+9.1)
Thanks!
Hm, there is something wrong. Could you pls do screenshots per position?
http://forum.xda-developers.com/attachment.php?attachmentid=2028938&d=1370777945
2013/11/10
Hi Oma!
I made screenshots and pictures, I hope it helps. The screenshots are flipped, so iI made photos so You can see, how it is is real life.
I used CrewRKTablets_RK30_CM10.1_analyse_sensor.zip
Use please, this Dropbox link, there are all files:Â
https://www.dropbox.com/s/kr2p274oflzrrz8/screenshots.rar
2013/11/10
The portraits are ok. The Landscape-s are flipped, the device boots upside down, if in Settings - Display I disable Auto-rotate screen, i get the flipped landscape, and the lockscreen is flipped too (the Power and Sonud keys are at the bottom of the tablet), so apps, what are landscape only are running upside down.
Still can't fix screen in Portrait mode.
Edit:
Orientation lock works, my fault...
45 Guest(s)
Devices in use: Desktop (35), Phone (10)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
