2014/01/14
So... Hi. I'm installed and fixed bugs with wifi, touch, sensor. So, 2D and 3D are slow performance, auto-rotate are buggy(I think the blame for this 2D and 3D Driver/Libs). Okay, how to fix performance of graphic?(Sorry for my bad English) Oma, i need help! P.s i unpacked firmware after mount on ext4(Linux), all funtions are work, many bugs are need fix.
There is a model fix for our CM10.1 build - http://crewrktablets.arctablet.com/?p=1913
I guess it will work with the AOSP, too.
2014/01/14
There is a model fix for our CM10.1 build - http://crewrktablets.arctablet.com/?p=1913I guess it will work with the AOSP, too.
Model Fix installed, auto-rotate not working correctly, and 2D and 3D slow performance
Try sensor fix 6, as descriped.
What is "slow perfprmance"? Please set CPU governor to performance and run Antutu. Post a sreenshot of the details result page.
This is "normal". Benchmarks under 4.2 are lower then under 4.1.
To correct the sensor try to copy over the sensor.rk29board.so from stock rom.
No idea, sorry.
2014/01/14
Well, my firmwares:
Next Day i gonna be make CM 10.1 to this sh*t()
2013/11/10
This is "normal". Benchmarks under 4.2 are lower then under 4.1.To correct the sensor try to copy over the sensor.rk29board.so from stock rom.
Hello Oma!
I tried to change this file (not rk29, rk30), but the result is the same, this file in stock rom is the same as in Your ROM. Which file can I try? I think, the problem is not with the sensor, but with the lcd, because the sreen is flipped until bootscreen too, when the sensor is not used.. What files are for LCD panel? I can try theese files from stock rom, or from other 4.2.2 rom. Thanks!
I tried HDMI too, but the screen is flipped there too, so it can't be sensor problem.
2013/11/10
Hello!
Finally I found the solution for screen orientation. We need to edit build.prop:
ro.fs.rotation=270 to 90
The problem now is with Hwacceleration. The videos are not playable with how acceleration,and the HDMI is not working too. Is it a problem with 5880d only, or it is with AOSP?
CM10.1 has working HW acc. but there I have problem with this rotation fix. I can only rotate screen, but not touchscreen. How can it be? Is it a problem with touchscreen driver in CM10.1?
Thanks..
Currently Online: vonkarayan, astosenix
76 Guest(s)
Devices in use: Desktop (67), Phone (11)
grielgryel
klaus1255
neverever007
favorit
Альфвоф
kevbez
