PocketBook SurfPad 2 CM 10.1
2013/11/03 - 19:47
Install this: http://crewrktablets.arctablet.com/?wpfb_dl=1045
Load Androsensor from Play-Store and post axis with highest value (example) for:
– tab vertical, landscape (y=+9.8)
– turn left to portrait (x=+9.8)
– turn right to portrait (x=-9.8)
– tab horizontal screen up (z=+9.8)
2013/11/03 - 20:01
For sound pls test this: http://crewrktablets.arctablet.com/?wpfb_dl=1165
ghost
Forum Posts: 21
2013/11/03 - 20:05
– tab vertical, landscape (y=-0.8; x=+10)
– turn left to portrait (x=+0.4; y=-10)
– turn right to portrait (x=-0.4; y=+10)
– tab horizontal screen up (z=+1.4)
ghost
Forum Posts: 21
2013/11/03 - 20:20
90 right. Now 0 = 90, 90 = 180 180 = 270 270 = 0.
No sound, error in DSP Manager, the music does not play.
ghost
Forum Posts: 21
2013/11/03 - 20:43
2013/11/03 - 20:46
The same as in post #20?
ghost
ghost
Forum Posts: 21
2013/11/03 - 20:53
Yes
2013/11/03 - 20:59
Can't be. Pls install fix from post #16 and give values again.
ghost
ghost
Forum Posts: 21
2013/11/03 - 21:03
fix from post #16
Now upside down 0 = 270, 90 = 180, 180 = 90, 270 = 0.ori.jpgImage Enlarger,
StepanBeloglazov
2013/11/03 - 23:18
how to make a greater sensitivity in this file?
http://crewrktablets.arctablet.com/?wpfb_dl=1060
ghost
Forum Posts: 21
2013/11/03 - 23:23
I don't know...This inversion rotate the screen...In build.prop is a string ro.sf.fakerotation=true
ghost
Forum Posts: 21
2013/11/23 - 00:57
Finally managed to fix the Auto-rotate. Thank you.
I applied sensor fix 5 CrewRKTablets_RK30_CM10.1_sensor_x =-z_y = y_z =-x.zip and now it works almost as required.
What to do with the sound? The sound is only in headphones? Help me please.
2013/11/23 - 08:40
Pls do a clean installation incl. eraseIDB. Install the sensor fix, so that you can use the tab.
Use Terminal Emulator to provide logs:
su
dmesg >/mnt/sdcard/dmesg.txt
ghost
Currently Online: swan12
92 Guest(s)
Devices in use: Desktop (82), Phone (10), Tablet (1)
swan12
heftpflaster
