Which kernel do you use? Is a stock firmware available?
Can you pls upload or link the stock firmware?
No, I'd like to see boot.img and kernel.img.
The kernel is bigger then the standard of 8 MB. http://crewrktablets.arctablet.com/?wpfb_dl=1064
Try again (incl. earsIDB) with this parameter: http://crewrktablets.arctablet.com/?wpfb_dl=934
You should have the stock parameter within the stock firmware pack.
2013/11/03
Now I have 3 GB of device memory instead of 1 GB. Do not see and mounts the internal memory. But if you replace the seats cd and external_sd then we can leave and so.
How to fix sound? He played only in headphones. And I have also a problem auto rotate. In CM sensors.rk30board wrong turn at 90, the stock sensors.rk30board on 180. How do I fix this?
Sorry for the terrible English.
126 Guest(s)
Devices in use: Desktop (110), Phone (15), Tablet (1)
JozekPL
Nobrubbr
pall668
Debilai1234
senaslapinas
WINL
