PMP7280C DUO
mrobo
Forum Posts: 13
2016/09/03 - 21:21
Do you have a backup of the stock firmware or is the firmware available elsewhere?
yes stock is no problem for me,
http://www.prestigio.com/catalogue/Archive_products/Multipads/MultiPad_2_Ultra_Duo_8.0#/product-support/firmware
I flash it and it works, but that is one 400MB file.img and when I tried to dump with yours tool not worked for me
prestigio_multipad_2_ultra_8_0_duo-2.jpg Prestigio MultiPad 2 PMP7280C ULTRA DUO 8.0 WiFi
RK3066, 8GB, Mail-400MP4, 1024 x 768, 160.2 pixel, MMA7660 3-axis Accelerometer, probably Hardware Designer: Archos, build.prop, modules
Thanks Received: 1383
2016/09/03 - 21:47
Ok, same kernel.
Do a clean install, incl. eraseIDB. Use the parameter file and the 7280C kernel.
Copy the model fix on the external sdcard: http://crewrktablets.arctablet.com/?wpfb_dl=2255
In CWM install the model fix, directly after the format_NAND fix.
mrobo
Forum Posts: 13
2016/09/03 - 22:02
Ok, same kernel.
Clean install which? stock rom?
2016/09/03 - 22:05
No, the Genio build.
mrobo
Forum Posts: 13
2016/09/04 - 11:14
I've done clean install and as I say after flashing it reboots, I see prestigio logo and after then black screen I cant see the CWM recovery menu on display
2016/09/04 - 11:24
Not really an idea. Can you pls check with an other build?
http://crewrktablets.arctablet.com/?p=1913
Just replace the kernel as a first step.
EDIT: pls install this in CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2052
mrobo
Forum Posts: 13
2016/09/04 - 12:08
now i flashed stock and when rebooted to stock recovery choosed adb sideload and it does not works???
adb devices cant see my device in stock recovery mode.
 could not be the problem that in stock is FW Ver: 4.1.01 BOOT Ver:1.22 ??
2016/09/04 - 12:10
Stock recovery is simply good to format user partitons. There is by fact no more functionallity.
smrkc
2016/11/12 - 18:25
Hopefully nobody will blame me for borrowing this thread. I have difficulties installing CM on my pmp 7280c.
Before flash, tablet was running 3.08+ kernel.
I used genio v3.4 bundle. I replaced the kernel.img from /rockdev/image/ with kernel found in CrewRKTablets_RK30_kernel_308_genio_jk17_odys.7z.
I erased IDB and ran the rkandroidtool (v1.35). The procedure completed successfully (at least that's the log message I got).
Capture.PNGImage Enlarger
However, tablet doesn't reboot to recovery. Tried all sorts of buttons and I can't make it to CWM.
Tablet doesn't boot to stock rom either. The only sign that tablet is alive is when I press power button I see slight led backlight.
Can anybody suggest what I can do?
Thanks!
mmasco
2016/12/08 - 22:55
I solved this problem. Need another recovery. I picked it from some custom ROM.
Summarize:
1) replace kernel.img to stock
2) replace parameter file to kernel_16kb
3) replace recovery.img to attachment
Sorry for my english.
72 Guest(s)
Devices in use: Desktop (60), Phone (12)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
