2016/09/01
Greetings, I am new here and need assistance, I have PMP7280C DUO tablet with RK3066 and want to flash this ROM, but I dont understand the flashing proccess
In the downloaded Oma_DevelopTool_Refresh is used the RK3188Loader(L)_V1.24, but thats not probably for my tablet, should I take it from CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.4 / rockdev the RK30xxLoader(L)_V1.34 and use them?
because the instructions says:
Run the RKDevelopTool:
- load the v1.24 loader
- Erase IDB Block
- Erase All Blocks
- Download
Then run RKAndroidTool:
- untick loader
- EraseIDB
- Run
Thx.
 Prestigio MultiPad 2 PMP7280C ULTRA DUO 8.0 WiFiÂ
RK3066, 8GB, Mail-400MP4, 1024 x 768, 160.2 pixel, MMA7660 3-axis Accelerometer, probably Hardware Designer: Archos, build.prop, modules
There is no need to flash the Loader. What is the current kernel running: 3.0.8+ or 3.0.36+?
2016/09/01
I dont now but, I flashed the version CrewRKTablets_RK30_Genio_by_Oma_CM10.1_v1.4.zip it booted and seems working, and after then I tried to flash this CrewRKTablets_Odys_Iron_CM12.1_LP_5.1.1_v1.1.7z with not choosed loader, but ended with error:
22:09:53 781Â Â Â Load Setting ok
22:09:53 828Â Â Â RKAndroidTool v1.3.7.0 Start Run
22:09:53 828Â Â Â Scan thread:2376
22:09:53 843Â Â Â Info:(thread=500)IoControlProc-->DeviceIoControl In
22:09:53 843Â Â Â ProcessID:876,ThreadID:960,RefCount:0
22:09:53 843Â Â Â Info:(thread=500)IoControlProc-->DeviceIoControl Out,ret=1,err=183
22:09:53 843Â Â Â ProcessID:876,ThreadID:2376,RefCount:0
22:11:47 593Â Â Â INFO:Start to erase IDB
22:11:47 593Â Â Â INFO:Start to lower format
22:11:59 593Â Â Â INFO:Lower format OK
22:11:59 593Â Â Â INFO:Erasing IDB OK
22:12:11 281Â Â Â Image Thread Path(\\?\USB#VID_2207&PID_300A#5&1BBE8508&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=3188
22:12:11 281Â Â Â INFO:Start to run
22:12:11 281Â Â Â INFO:Start to test device
22:12:11 296Â Â Â INFO:Test device OK
22:12:11 296Â Â Â INFO:Start to download file
22:12:11 296Â Â Â INFO: Start to download files to flash,backup offset=0x24000
22:12:11 296Â Â Â INFO:Flash Start to download file to flash
22:12:11 328Â Â Â Info:RKA_File_Download start,file=misc,offset=0x2000
22:12:11 343Â Â Â Info:RKA_File_Download start,file=kernel,offset=0x4000
22:12:12 859Â Â Â Info:RKA_File_Download start,file=boot,offset=0xc000
22:12:13 015Â Â Â Info:RKA_File_Download start,file=recovery,offset=0x14000
22:12:13 515Â Â Â Info:RKA_File_Download start,file=system,offset=0x1c41000
22:12:52 937Â Â Â INFO: Download files to flash finished,Total(1089601632)B
22:12:52 937Â Â Â INFO: Start to check data
22:12:52 937Â Â Â INFO:Start to check download data
22:12:52 984Â Â Â Info:RKA_File_Check start,file=misc,offset=0x2000
22:12:52 984Â Â Â Info:RKA_File_Check start,file=kernel,offset=0x4000
22:12:53 625Â Â Â Info:RKA_File_Check start,file=boot,offset=0xc000
22:12:53 687Â Â Â Info:RKA_File_Check start,file=recovery,offset=0x14000
22:12:53 906Â Â Â Info:RKA_File_Check start,file=system,offset=0x1c41000
22:12:53 984Â Â Â Error:Compare system file failed,Offset(0)
22:12:54 015Â Â Â Error: Check system file failed
22:12:54 015Â Â Â ERROR:Download file failed
22:12:54 015Â Â Â ERROR:Image Thread Failed
22:12:54 015Â Â Â ERROR:Run failed
2016/09/01
and this is the log from flashed CrewRKTablets_RK30_Genio_by_Oma_CM10.1_v1.4.zip which worked:
22:17:15 031Â Â Â Load Setting ok
22:17:15 078Â Â Â RKAndroidTool v1.3.5.0 Start Run
22:17:15 078Â Â Â Scan thread:1628
22:17:15 093Â Â Â ProcessID:3096,ThreadID:3236,RefCount:0
22:17:15 093Â Â Â Info:(thread=2616)IoControlProc-->DeviceIoControl In
22:17:15 093Â Â Â ProcessID:3096,ThreadID:1628,RefCount:0
22:17:15 218Â Â Â Info:(thread=2616)IoControlProc-->DeviceIoControl Out,ret=1,err=183
22:17:40 453Â Â Â INFO:Start to erase IDB
22:17:40 453Â Â Â INFO:Start to lower format
22:17:52 453Â Â Â INFO:Lower format OK
22:17:52 453Â Â Â INFO:Erasing IDB OK
22:17:58 375Â Â Â Loader Device Path(\\?\USB#VID_2207&PID_300A#5&1BBE8508&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=3016
22:17:58 375Â Â Â INFO:Start to run
22:17:58 375Â Â Â INFO:Start to test device
22:17:58 390Â Â Â INFO:Test device OK
22:17:58 390Â Â Â INFO:Start to download IDB
22:17:58 390Â Â Â Flash Chip Information:
22:17:58 390Â Â Â NOÂ Â Â Â Â Â SIZE(MB)Â Â Â Manufacturer
22:17:58 390Â Â Â ----------------------------------------------
22:17:58 390Â Â Â 0Â Â Â Â Â Â 8192MBÂ Â Â HYNIX
22:17:58 390Â Â Â INFO:BuildFlashStateMap start
22:17:58 390Â Â Â INFO: FindAllIDB start
22:17:58 406Â Â Â INFO:UpdateIDBData start
22:17:58 421Â Â Â INFO:Serial Number(14):
22:17:58 421Â Â Â 00000000: 50 4D 50 38 30 34 33 31 39 32 36 32 37 39 00 00
22:17:58 421Â Â Â 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00
22:17:58 437Â Â Â INFO:UID(30):
22:17:58 437Â Â Â 00000000: 52 4F 43 4B 43 48 49 50 5F 7B 72 00 0B 34 FE 6C
22:17:58 437Â Â Â 00000010: A2 7A 16 40 97 BD 41 1A 73 A8 76 15 82 D8
22:17:58 437Â Â Â INFO:BlueTooth(0):
22:17:58 437Â Â Â 00000000: 00 00 00 00 00 00
22:17:58 437Â Â Â INFO:Mac(0):
22:17:58 437Â Â Â INFO:WriteXIDBlock start
22:17:58 437Â Â Â INFO:MakeEccSpareData start
22:17:58 453Â Â Â INFO:WriteXIDBlock start
22:17:58 453   INFO:Writeing the 1th ID Block£¬Pos£º00000000(SEC)
22:17:58 453Â Â Â INFO:Writing sector 00000000 ~ 00000015 ...
22:17:58 453Â Â Â INFO:Reading sector 00000000 ~ 00000015 ...
22:17:58 453Â Â Â INFO:check start
22:17:58 453Â Â Â INFO:Writing sector 00000016 ~ 00000031 ...
22:17:58 468Â Â Â INFO:Reading sector 00000016 ~ 00000031 ...
22:17:58 468Â Â Â INFO:check start
22:17:58 468Â Â Â INFO:Writing sector 00000032 ~ 00000047 ...
22:17:58 468Â Â Â INFO:Reading sector 00000032 ~ 00000047 ...
22:17:58 484Â Â Â INFO:check start
22:17:58 484Â Â Â INFO:Writing sector 00000048 ~ 00000063 ...
22:17:58 484Â Â Â INFO:Reading sector 00000048 ~ 00000063 ...
22:17:58 484Â Â Â INFO:Writing sector 00000064 ~ 00000079 ...
22:17:58 500Â Â Â INFO:Reading sector 00000064 ~ 00000079 ...
22:17:58 500Â Â Â INFO:check start
22:17:58 500Â Â Â INFO:Writing sector 00000080 ~ 00000095 ...
22:17:58 500Â Â Â INFO:Reading sector 00000080 ~ 00000095 ...
22:17:58 500Â Â Â INFO:Writing sector 00000096 ~ 00000111 ...
22:17:58 515Â Â Â INFO:Reading sector 00000096 ~ 00000111 ...
22:17:58 515Â Â Â INFO:check start
22:17:58 515Â Â Â INFO:Writing sector 00000112 ~ 00000127 ...
22:17:58 515Â Â Â INFO:Reading sector 00000112 ~ 00000127 ...
22:17:58 515Â Â Â INFO:Writing sector 00000128 ~ 00000143 ...
22:17:58 531Â Â Â INFO:Reading sector 00000128 ~ 00000143 ...
22:17:58 531Â Â Â INFO:check start
22:17:58 531Â Â Â INFO:Writing sector 00000144 ~ 00000159 ...
22:17:58 531Â Â Â INFO:Reading sector 00000144 ~ 00000159 ...
22:17:58 531Â Â Â INFO:Writing sector 00000160 ~ 00000175 ...
22:17:58 546Â Â Â INFO:Reading sector 00000160 ~ 00000175 ...
22:17:58 546Â Â Â INFO:check start
22:17:58 546Â Â Â INFO:Writing sector 00000176 ~ 00000191 ...
22:17:58 546Â Â Â INFO:Reading sector 00000176 ~ 00000191 ...
22:17:58 562Â Â Â INFO:check start
22:17:58 562Â Â Â INFO:Writing sector 00000192 ~ 00000207 ...
22:17:58 562Â Â Â INFO:Reading sector 00000192 ~ 00000207 ...
22:17:58 562Â Â Â INFO:Writing sector 00000208 ~ 00000223 ...
22:17:58 562Â Â Â INFO:Reading sector 00000208 ~ 00000223 ...
22:17:58 578Â Â Â INFO:check start
22:17:58 578Â Â Â INFO:Writing sector 00000224 ~ 00000239 ...
22:17:58 578Â Â Â INFO:Reading sector 00000224 ~ 00000239 ...
22:17:58 578Â Â Â INFO:Writing sector 00000240 ~ 00000251 ...
22:17:58 593Â Â Â INFO:Reading sector 00000240 ~ 00000251 ...
22:17:58 593Â Â Â INFO:check start
22:17:58 593   INFO:Writeing the 2th ID Block£¬Pos£º00004096(SEC)
22:17:58 593Â Â Â INFO:Writing sector 00004096 ~ 00004111 ...
22:17:58 593Â Â Â INFO:Reading sector 00004096 ~ 00004111 ...
22:17:58 609Â Â Â INFO:check start
22:17:58 609Â Â Â INFO:Writing sector 00004112 ~ 00004127 ...
22:17:58 609Â Â Â INFO:Reading sector 00004112 ~ 00004127 ...
22:17:58 609Â Â Â INFO:Writing sector 00004128 ~ 00004143 ...
22:17:58 609Â Â Â INFO:Reading sector 00004128 ~ 00004143 ...
22:17:58 625Â Â Â INFO:check start
22:17:58 625Â Â Â INFO:Writing sector 00004144 ~ 00004159 ...
22:17:58 625Â Â Â INFO:Reading sector 00004144 ~ 00004159 ...
22:17:58 625Â Â Â INFO:Writing sector 00004160 ~ 00004175 ...
22:17:58 640Â Â Â INFO:Reading sector 00004160 ~ 00004175 ...
22:17:58 640Â Â Â INFO:check start
22:17:58 640Â Â Â INFO:Writing sector 00004176 ~ 00004191 ...
22:17:58 640Â Â Â INFO:Reading sector 00004176 ~ 00004191 ...
22:17:58 640Â Â Â INFO:Writing sector 00004192 ~ 00004207 ...
22:17:58 656Â Â Â INFO:Reading sector 00004192 ~ 00004207 ...
22:17:58 656Â Â Â INFO:check start
22:17:58 656Â Â Â INFO:Writing sector 00004208 ~ 00004223 ...
22:17:58 656Â Â Â INFO:Reading sector 00004208 ~ 00004223 ...
22:17:58 656Â Â Â INFO:Writing sector 00004224 ~ 00004239 ...
22:17:58 671Â Â Â INFO:Reading sector 00004224 ~ 00004239 ...
22:17:58 671Â Â Â INFO:check start
22:17:58 671Â Â Â INFO:Writing sector 00004240 ~ 00004255 ...
22:17:58 671Â Â Â INFO:Reading sector 00004240 ~ 00004255 ...
22:17:58 687Â Â Â INFO:check start
22:17:58 687Â Â Â INFO:Writing sector 00004256 ~ 00004271 ...
22:17:58 687Â Â Â INFO:Reading sector 00004256 ~ 00004271 ...
22:17:58 687Â Â Â INFO:Writing sector 00004272 ~ 00004287 ...
22:17:58 703Â Â Â INFO:Reading sector 00004272 ~ 00004287 ...
22:17:58 703Â Â Â INFO:check start
22:17:58 703Â Â Â INFO:Writing sector 00004288 ~ 00004303 ...
22:17:58 703Â Â Â INFO:Reading sector 00004288 ~ 00004303 ...
22:17:58 703Â Â Â INFO:Writing sector 00004304 ~ 00004319 ...
22:17:58 718Â Â Â INFO:Reading sector 00004304 ~ 00004319 ...
22:17:58 718Â Â Â INFO:check start
22:17:58 718Â Â Â INFO:Writing sector 00004320 ~ 00004335 ...
22:17:58 718Â Â Â INFO:Reading sector 00004320 ~ 00004335 ...
22:17:58 718Â Â Â INFO:Writing sector 00004336 ~ 00004347 ...
22:17:58 734Â Â Â INFO:Reading sector 00004336 ~ 00004347 ...
22:17:58 734Â Â Â INFO:check start
22:17:58 734   INFO:Writeing the 3th ID Block£¬Pos£º00008192(SEC)
22:17:58 734Â Â Â INFO:Writing sector 00008192 ~ 00008207 ...
22:17:58 750Â Â Â INFO:Reading sector 00008192 ~ 00008207 ...
22:17:58 750Â Â Â INFO:check start
22:17:58 750Â Â Â INFO:Writing sector 00008208 ~ 00008223 ...
22:17:58 750Â Â Â INFO:Reading sector 00008208 ~ 00008223 ...
22:17:58 750Â Â Â INFO:Writing sector 00008224 ~ 00008239 ...
22:17:58 765Â Â Â INFO:Reading sector 00008224 ~ 00008239 ...
22:17:58 765Â Â Â INFO:check start
22:17:58 765Â Â Â INFO:Writing sector 00008240 ~ 00008255 ...
22:17:58 765Â Â Â INFO:Reading sector 00008240 ~ 00008255 ...
22:17:58 765Â Â Â INFO:Writing sector 00008256 ~ 00008271 ...
22:17:58 781Â Â Â INFO:Reading sector 00008256 ~ 00008271 ...
22:17:58 781Â Â Â INFO:check start
22:17:58 781Â Â Â INFO:Writing sector 00008272 ~ 00008287 ...
22:17:58 781Â Â Â INFO:Reading sector 00008272 ~ 00008287 ...
22:17:58 781Â Â Â INFO:Writing sector 00008288 ~ 00008303 ...
22:17:58 796Â Â Â INFO:Reading sector 00008288 ~ 00008303 ...
22:17:58 796Â Â Â INFO:check start
22:17:58 796Â Â Â INFO:Writing sector 00008304 ~ 00008319 ...
22:17:58 796Â Â Â INFO:Reading sector 00008304 ~ 00008319 ...
22:17:58 812Â Â Â INFO:check start
22:17:58 812Â Â Â INFO:Writing sector 00008320 ~ 00008335 ...
22:17:58 812Â Â Â INFO:Reading sector 00008320 ~ 00008335 ...
22:17:58 812Â Â Â INFO:Writing sector 00008336 ~ 00008351 ...
22:17:58 812Â Â Â INFO:Reading sector 00008336 ~ 00008351 ...
22:17:58 828Â Â Â INFO:check start
22:17:58 828Â Â Â INFO:Writing sector 00008352 ~ 00008367 ...
22:17:58 828Â Â Â INFO:Reading sector 00008352 ~ 00008367 ...
22:17:58 828Â Â Â INFO:Writing sector 00008368 ~ 00008383 ...
22:17:58 843Â Â Â INFO:Reading sector 00008368 ~ 00008383 ...
22:17:58 843Â Â Â INFO:check start
22:17:58 843Â Â Â INFO:Writing sector 00008384 ~ 00008399 ...
22:17:58 843Â Â Â INFO:Reading sector 00008384 ~ 00008399 ...
22:17:58 843Â Â Â INFO:Writing sector 00008400 ~ 00008415 ...
22:17:58 859Â Â Â INFO:Reading sector 00008400 ~ 00008415 ...
22:17:58 859Â Â Â INFO:check start
22:17:58 859Â Â Â INFO:Writing sector 00008416 ~ 00008431 ...
22:17:58 859Â Â Â INFO:Reading sector 00008416 ~ 00008431 ...
22:17:58 859Â Â Â INFO:Writing sector 00008432 ~ 00008443 ...
22:17:58 875Â Â Â INFO:Reading sector 00008432 ~ 00008443 ...
22:17:58 875Â Â Â INFO:check start
22:17:58 875   INFO:Writeing the 4th ID Block£¬Pos£º00012288(SEC)
22:17:58 875Â Â Â INFO:Writing sector 00012288 ~ 00012303 ...
22:17:58 890Â Â Â INFO:Reading sector 00012288 ~ 00012303 ...
22:17:58 890Â Â Â INFO:check start
22:17:58 890Â Â Â INFO:Writing sector 00012304 ~ 00012319 ...
22:17:58 890Â Â Â INFO:Reading sector 00012304 ~ 00012319 ...
22:17:58 890Â Â Â INFO:Writing sector 00012320 ~ 00012335 ...
22:17:58 906Â Â Â INFO:Reading sector 00012320 ~ 00012335 ...
22:17:58 906Â Â Â INFO:check start
22:17:58 906Â Â Â INFO:Writing sector 00012336 ~ 00012351 ...
22:17:58 906Â Â Â INFO:Reading sector 00012336 ~ 00012351 ...
22:17:58 906Â Â Â INFO:Writing sector 00012352 ~ 00012367 ...
22:17:58 921Â Â Â INFO:Reading sector 00012352 ~ 00012367 ...
22:17:58 921Â Â Â INFO:check start
22:17:58 921Â Â Â INFO:Writing sector 00012368 ~ 00012383 ...
22:17:58 921Â Â Â INFO:Reading sector 00012368 ~ 00012383 ...
22:17:58 937Â Â Â INFO:Writing sector 00012384 ~ 00012399 ...
22:17:58 937Â Â Â INFO:Reading sector 00012384 ~ 00012399 ...
22:17:58 937Â Â Â INFO:check start
22:17:58 937Â Â Â INFO:Writing sector 00012400 ~ 00012415 ...
22:17:58 937Â Â Â INFO:Reading sector 00012400 ~ 00012415 ...
22:17:58 953Â Â Â INFO:check start
22:17:58 953Â Â Â INFO:Writing sector 00012416 ~ 00012431 ...
22:17:58 953Â Â Â INFO:Reading sector 00012416 ~ 00012431 ...
22:17:58 953Â Â Â INFO:Writing sector 00012432 ~ 00012447 ...
22:17:58 968Â Â Â INFO:Reading sector 00012432 ~ 00012447 ...
22:17:58 968Â Â Â INFO:check start
22:17:58 968Â Â Â INFO:Writing sector 00012448 ~ 00012463 ...
22:17:58 968Â Â Â INFO:Reading sector 00012448 ~ 00012463 ...
22:17:58 968Â Â Â INFO:Writing sector 00012464 ~ 00012479 ...
22:17:58 984Â Â Â INFO:Reading sector 00012464 ~ 00012479 ...
22:17:58 984Â Â Â INFO:check start
22:17:58 984Â Â Â INFO:Writing sector 00012480 ~ 00012495 ...
22:17:58 984Â Â Â INFO:Reading sector 00012480 ~ 00012495 ...
22:17:59 000Â Â Â INFO:Writing sector 00012496 ~ 00012511 ...
22:17:59 000Â Â Â INFO:Reading sector 00012496 ~ 00012511 ...
22:17:59 000Â Â Â INFO:check start
22:17:59 000Â Â Â INFO:Writing sector 00012512 ~ 00012527 ...
22:17:59 000Â Â Â INFO:Reading sector 00012512 ~ 00012527 ...
22:17:59 015Â Â Â INFO:check start
22:17:59 015Â Â Â INFO:Writing sector 00012528 ~ 00012539 ...
22:17:59 015Â Â Â INFO:Reading sector 00012528 ~ 00012539 ...
22:17:59 015   INFO:Writeing the 5th ID Block£¬Pos£º00016384(SEC)
22:17:59 015Â Â Â INFO:Writing sector 00016384 ~ 00016399 ...
22:17:59 031Â Â Â INFO:Reading sector 00016384 ~ 00016399 ...
22:17:59 031Â Â Â INFO:check start
22:17:59 031Â Â Â INFO:Writing sector 00016400 ~ 00016415 ...
22:17:59 031Â Â Â INFO:Reading sector 00016400 ~ 00016415 ...
22:17:59 046Â Â Â INFO:Writing sector 00016416 ~ 00016431 ...
22:17:59 046Â Â Â INFO:Reading sector 00016416 ~ 00016431 ...
22:17:59 046Â Â Â INFO:check start
22:17:59 046Â Â Â INFO:Writing sector 00016432 ~ 00016447 ...
22:17:59 046Â Â Â INFO:Reading sector 00016432 ~ 00016447 ...
22:17:59 062Â Â Â INFO:check start
22:17:59 062Â Â Â INFO:Writing sector 00016448 ~ 00016463 ...
22:17:59 062Â Â Â INFO:Reading sector 00016448 ~ 00016463 ...
22:17:59 062Â Â Â INFO:Writing sector 00016464 ~ 00016479 ...
22:17:59 078Â Â Â INFO:Reading sector 00016464 ~ 00016479 ...
22:17:59 078Â Â Â INFO:check start
22:17:59 078Â Â Â INFO:Writing sector 00016480 ~ 00016495 ...
22:17:59 078Â Â Â INFO:Reading sector 00016480 ~ 00016495 ...
22:17:59 078Â Â Â INFO:Writing sector 00016496 ~ 00016511 ...
22:17:59 093Â Â Â INFO:Reading sector 00016496 ~ 00016511 ...
22:17:59 093Â Â Â INFO:check start
22:17:59 093Â Â Â INFO:Writing sector 00016512 ~ 00016527 ...
22:17:59 093Â Â Â INFO:Reading sector 00016512 ~ 00016527 ...
22:17:59 093Â Â Â INFO:Writing sector 00016528 ~ 00016543 ...
22:17:59 109Â Â Â INFO:Reading sector 00016528 ~ 00016543 ...
22:17:59 109Â Â Â INFO:check start
22:17:59 109Â Â Â INFO:Writing sector 00016544 ~ 00016559 ...
22:17:59 109Â Â Â INFO:Reading sector 00016544 ~ 00016559 ...
22:17:59 109Â Â Â INFO:Writing sector 00016560 ~ 00016575 ...
22:17:59 125Â Â Â INFO:Reading sector 00016560 ~ 00016575 ...
22:17:59 125Â Â Â INFO:check start
22:17:59 125Â Â Â INFO:Writing sector 00016576 ~ 00016591 ...
22:17:59 125Â Â Â INFO:Reading sector 00016576 ~ 00016591 ...
22:17:59 140Â Â Â INFO:check start
22:17:59 140Â Â Â INFO:Writing sector 00016592 ~ 00016607 ...
22:17:59 140Â Â Â INFO:Reading sector 00016592 ~ 00016607 ...
22:17:59 140Â Â Â INFO:Writing sector 00016608 ~ 00016623 ...
22:17:59 156Â Â Â INFO:Reading sector 00016608 ~ 00016623 ...
22:17:59 156Â Â Â INFO:check start
22:17:59 156Â Â Â INFO:Writing sector 00016624 ~ 00016635 ...
22:17:59 156Â Â Â INFO:Reading sector 00016624 ~ 00016635 ...
22:17:59 156Â Â Â INFO:start to erase system disk
22:17:59 156Â Â Â INFO:Download IDB OK
22:17:59 156Â Â Â INFO:Start to reset device
22:17:59 171Â Â Â INFO:Reset device OK
22:17:59 171Â Â Â INFO:LoaderThread Finish
22:18:01 125Â Â Â Image Thread Path(\\?\USB#VID_2207&PID_300A#5&1BBE8508&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=2872
22:18:01 140Â Â Â INFO:Start to test device
22:18:01 140Â Â Â ERROR:TestUnitReady failed,Errcode(-1)
22:18:02 140Â Â Â INFO:Test device OK
22:18:02 140Â Â Â INFO:Start to download file
22:18:02 140Â Â Â INFO: Start to download files to flash,backup offset=0x1c000
22:18:02 140Â Â Â INFO:Flash Start to download file to flash
22:18:02 187Â Â Â Info:RKA_File_Download start,file=misc,offset=0x2000
22:18:02 203Â Â Â Info:RKA_File_Download start,file=kernel,offset=0x4000
22:18:04 500Â Â Â Info:RKA_File_Download start,file=boot,offset=0xc000
22:18:04 734Â Â Â Info:RKA_File_Download start,file=recovery,offset=0x14000
22:18:06 031Â Â Â Info:RKA_File_Download start,file=system,offset=0x5e2000
22:19:37 421Â Â Â INFO: Download files to flash finished,Total(698934675)B
22:19:37 421Â Â Â INFO: Start to check data
22:19:37 421Â Â Â INFO:Start to check download data
22:19:37 468Â Â Â Info:RKA_File_Check start,file=misc,offset=0x2000
22:19:37 484Â Â Â Info:RKA_File_Check start,file=kernel,offset=0x4000
22:19:38 437Â Â Â Info:RKA_File_Check start,file=boot,offset=0xc000
22:19:38 546Â Â Â Info:RKA_File_Check start,file=recovery,offset=0x14000
22:19:39 093Â Â Â Info:RKA_File_Check start,file=system,offset=0x5e2000
22:20:17 953Â Â Â INFO:Download file OK,Elapsed(135797MS)
22:20:17 953Â Â Â INFO:Run OK
21:43:45 375Â Â Â Info:wait for exiting scan thread start
21:43:45 531Â Â Â Info:wait for exiting main thread start
21:43:45 531Â Â Â ProcessID:3096,ThreadID:3236,RefCount:0
Doesn't work that way. You should not flash a strange kernel into your tab!
Pls use this build with the 7280C kernel, as it is confirmed working: http://crewrktablets.arctablet.com/?p=2315
2016/09/01
I flashed the RK30 Genio by Oma rocks – AOSP 4.2.2 two times (without errors), but cant get the cwm recovery to start, the tablet lights on and stays in black screen and in device manager I see new two linux file-cd gadget usb devices, could you help me out please?
Did you use the 7280C kernel?
2016/09/01
now yes, but get error download failed
EraseIDB went o.k.
writing went (668311)K went o.k.
but checking download data size (668311)K Checked(8244)K = failed
now I can see only the Class for rockusb devices RK30 Device in the device manager
2016/09/01
21:55:53 937Â Â Â Load Setting ok
21:55:53 968Â Â Â RKAndroidTool v1.3.5.0 Start Run
21:55:53 968Â Â Â Scan thread:4032
21:55:53 984Â Â Â Info:(thread=3560)IoControlProc-->DeviceIoControl In
21:55:53 984Â Â Â Info:(thread=3560)IoControlProc-->DeviceIoControl Out,ret=1,err=183
21:55:53 984Â Â Â ProcessID:3060,ThreadID:2052,RefCount:0
21:55:53 984Â Â Â ProcessID:3060,ThreadID:4032,RefCount:0
21:56:04 218Â Â Â INFO:Start to erase IDB
21:56:04 234Â Â Â INFO:Start to lower format
21:56:18 234Â Â Â INFO:Lower format OK
21:56:18 234Â Â Â INFO:Erasing IDB OK
21:56:26 062Â Â Â Loader Device Path(\\?\USB#VID_2207&PID_300A#5&1BBE8508&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=2308
21:56:26 062Â Â Â INFO:Start to run
21:56:26 062Â Â Â INFO:Start to test device
21:56:26 062Â Â Â INFO:Test device OK
21:56:26 062Â Â Â INFO:Start to download IDB
21:56:26 062Â Â Â Flash Chip Information:
21:56:26 062Â Â Â NOÂ Â Â Â Â Â SIZE(MB)Â Â Â Manufacturer
21:56:26 062Â Â Â ----------------------------------------------
21:56:26 078Â Â Â 0Â Â Â Â Â Â 8192MBÂ Â Â HYNIX
21:56:26 078Â Â Â ----------------------------------------------
21:56:26 078Â Â Â INFO:BuildFlashStateMap start
21:56:26 078Â Â Â INFO: FindAllIDB start
21:56:26 078Â Â Â INFO:UpdateIDBData start
21:56:26 109Â Â Â INFO:Serial Number(14):
21:56:26 109Â Â Â 00000000: 50 4D 50 38 30 34 33 31 39 32 36 32 37 39 00 00
21:56:26 109Â Â Â 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00
21:56:26 109Â Â Â INFO:UID(30):
21:56:26 109Â Â Â 00000000: 52 4F 43 4B 43 48 49 50 5F 7B 72 00 0B 34 FE 6C
21:56:26 109Â Â Â 00000010: A2 7A 16 40 97 BD 41 1A 73 A8 76 15 82 D8
21:56:26 109Â Â Â INFO:BlueTooth(0):
21:56:26 109Â Â Â 00000000: 00 00 00 00 00 00
21:56:26 109Â Â Â INFO:Mac(0):
21:56:26 109Â Â Â INFO:WriteXIDBlock start
21:56:26 109Â Â Â INFO:MakeEccSpareData start
21:56:26 125Â Â Â INFO:WriteXIDBlock start
21:56:26 125   INFO:Writeing the 1th ID Block£¬Pos£º00000000(SEC)
21:56:26 125Â Â Â INFO:Writing sector 00000000 ~ 00000015 ...
21:56:26 140Â Â Â INFO:Reading sector 00000000 ~ 00000015 ...
21:56:26 140Â Â Â INFO:check start
21:56:26 140Â Â Â INFO:Writing sector 00000016 ~ 00000031 ...
21:56:26 140Â Â Â INFO:Reading sector 00000016 ~ 00000031 ...
21:56:26 140Â Â Â INFO:Writing sector 00000032 ~ 00000047 ...
21:56:26 156Â Â Â INFO:Reading sector 00000032 ~ 00000047 ...
21:56:26 156Â Â Â INFO:check start
21:56:26 156Â Â Â INFO:Writing sector 00000048 ~ 00000063 ...
21:56:26 156Â Â Â INFO:Reading sector 00000048 ~ 00000063 ...
21:56:26 171Â Â Â INFO:Writing sector 00000064 ~ 00000079 ...
21:56:26 171Â Â Â INFO:Reading sector 00000064 ~ 00000079 ...
21:56:26 171Â Â Â INFO:check start
21:56:26 171Â Â Â INFO:Writing sector 00000080 ~ 00000095 ...
21:56:26 171Â Â Â INFO:Reading sector 00000080 ~ 00000095 ...
21:56:26 187Â Â Â INFO:check start
21:56:26 187Â Â Â INFO:Writing sector 00000096 ~ 00000111 ...
21:56:26 187Â Â Â INFO:Reading sector 00000096 ~ 00000111 ...
21:56:26 187Â Â Â INFO:Writing sector 00000112 ~ 00000127 ...
21:56:26 203Â Â Â INFO:Reading sector 00000112 ~ 00000127 ...
21:56:26 203Â Â Â INFO:check start
21:56:26 203Â Â Â INFO:Writing sector 00000128 ~ 00000143 ...
21:56:26 203Â Â Â INFO:Reading sector 00000128 ~ 00000143 ...
21:56:26 203Â Â Â INFO:Writing sector 00000144 ~ 00000159 ...
21:56:26 218Â Â Â INFO:Reading sector 00000144 ~ 00000159 ...
21:56:26 218Â Â Â INFO:check start
21:56:26 218Â Â Â INFO:Writing sector 00000160 ~ 00000175 ...
21:56:26 218Â Â Â INFO:Reading sector 00000160 ~ 00000175 ...
21:56:26 234Â Â Â INFO:check start
21:56:26 234Â Â Â INFO:Writing sector 00000176 ~ 00000191 ...
21:56:26 234Â Â Â INFO:Reading sector 00000176 ~ 00000191 ...
21:56:26 234Â Â Â INFO:Writing sector 00000192 ~ 00000207 ...
21:56:26 250Â Â Â INFO:Reading sector 00000192 ~ 00000207 ...
21:56:26 250Â Â Â INFO:check start
21:56:26 250Â Â Â INFO:Writing sector 00000208 ~ 00000223 ...
21:56:26 250Â Â Â INFO:Reading sector 00000208 ~ 00000223 ...
21:56:26 250Â Â Â INFO:Writing sector 00000224 ~ 00000239 ...
21:56:26 265Â Â Â INFO:Reading sector 00000224 ~ 00000239 ...
21:56:26 265Â Â Â INFO:check start
21:56:26 265Â Â Â INFO:Writing sector 00000240 ~ 00000251 ...
21:56:26 265Â Â Â INFO:Reading sector 00000240 ~ 00000251 ...
21:56:26 281   INFO:Writeing the 2th ID Block£¬Pos£º00004096(SEC)
21:56:26 281Â Â Â INFO:Writing sector 00004096 ~ 00004111 ...
21:56:26 281Â Â Â INFO:Reading sector 00004096 ~ 00004111 ...
21:56:26 281Â Â Â INFO:check start
21:56:26 281Â Â Â INFO:Writing sector 00004112 ~ 00004127 ...
21:56:26 296Â Â Â INFO:Reading sector 00004112 ~ 00004127 ...
21:56:26 296Â Â Â INFO:check start
21:56:26 296Â Â Â INFO:Writing sector 00004128 ~ 00004143 ...
21:56:26 296Â Â Â INFO:Reading sector 00004128 ~ 00004143 ...
21:56:26 296Â Â Â INFO:Writing sector 00004144 ~ 00004159 ...
21:56:26 312Â Â Â INFO:Reading sector 00004144 ~ 00004159 ...
21:56:26 312Â Â Â INFO:check start
21:56:26 312Â Â Â INFO:Writing sector 00004160 ~ 00004175 ...
21:56:26 312Â Â Â INFO:Reading sector 00004160 ~ 00004175 ...
21:56:26 328Â Â Â INFO:check start
21:56:26 328Â Â Â INFO:Writing sector 00004176 ~ 00004191 ...
21:56:26 328Â Â Â INFO:Reading sector 00004176 ~ 00004191 ...
21:56:26 328Â Â Â INFO:Writing sector 00004192 ~ 00004207 ...
21:56:26 343Â Â Â INFO:Reading sector 00004192 ~ 00004207 ...
21:56:26 343Â Â Â INFO:check start
21:56:26 343Â Â Â INFO:Writing sector 00004208 ~ 00004223 ...
21:56:26 343Â Â Â INFO:Reading sector 00004208 ~ 00004223 ...
21:56:26 343Â Â Â INFO:Writing sector 00004224 ~ 00004239 ...
21:56:26 359Â Â Â INFO:Reading sector 00004224 ~ 00004239 ...
21:56:26 359Â Â Â INFO:check start
21:56:26 359Â Â Â INFO:Writing sector 00004240 ~ 00004255 ...
21:56:26 359Â Â Â INFO:Reading sector 00004240 ~ 00004255 ...
21:56:26 375Â Â Â INFO:Writing sector 00004256 ~ 00004271 ...
21:56:26 375Â Â Â INFO:Reading sector 00004256 ~ 00004271 ...
21:56:26 375Â Â Â INFO:check start
21:56:26 375Â Â Â INFO:Writing sector 00004272 ~ 00004287 ...
21:56:26 390Â Â Â INFO:Reading sector 00004272 ~ 00004287 ...
21:56:26 390Â Â Â INFO:check start
21:56:26 390Â Â Â INFO:Writing sector 00004288 ~ 00004303 ...
21:56:26 390Â Â Â INFO:Reading sector 00004288 ~ 00004303 ...
21:56:26 390Â Â Â INFO:Writing sector 00004304 ~ 00004319 ...
21:56:26 406Â Â Â INFO:Reading sector 00004304 ~ 00004319 ...
21:56:26 406Â Â Â INFO:check start
21:56:26 406Â Â Â INFO:Writing sector 00004320 ~ 00004335 ...
21:56:26 406Â Â Â INFO:Reading sector 00004320 ~ 00004335 ...
21:56:26 406Â Â Â INFO:Writing sector 00004336 ~ 00004347 ...
21:56:26 421Â Â Â INFO:Reading sector 00004336 ~ 00004347 ...
21:56:26 421Â Â Â INFO:check start
21:56:26 421   INFO:Writeing the 3th ID Block£¬Pos£º00008192(SEC)
21:56:26 421Â Â Â INFO:Writing sector 00008192 ~ 00008207 ...
21:56:26 437Â Â Â INFO:Reading sector 00008192 ~ 00008207 ...
21:56:26 437Â Â Â INFO:check start
21:56:26 437Â Â Â INFO:Writing sector 00008208 ~ 00008223 ...
21:56:26 437Â Â Â INFO:Reading sector 00008208 ~ 00008223 ...
21:56:26 437Â Â Â INFO:Writing sector 00008224 ~ 00008239 ...
21:56:26 453Â Â Â INFO:Reading sector 00008224 ~ 00008239 ...
21:56:26 453Â Â Â INFO:check start
21:56:26 453Â Â Â INFO:Writing sector 00008240 ~ 00008255 ...
21:56:26 453Â Â Â INFO:Reading sector 00008240 ~ 00008255 ...
21:56:26 468Â Â Â INFO:check start
21:56:26 468Â Â Â INFO:Writing sector 00008256 ~ 00008271 ...
21:56:26 468Â Â Â INFO:Reading sector 00008256 ~ 00008271 ...
21:56:26 468Â Â Â INFO:Writing sector 00008272 ~ 00008287 ...
21:56:26 484Â Â Â INFO:Reading sector 00008272 ~ 00008287 ...
21:56:26 484Â Â Â INFO:check start
21:56:26 484Â Â Â INFO:Writing sector 00008288 ~ 00008303 ...
21:56:26 484Â Â Â INFO:Reading sector 00008288 ~ 00008303 ...
21:56:26 484Â Â Â INFO:Writing sector 00008304 ~ 00008319 ...
21:56:26 500Â Â Â INFO:Reading sector 00008304 ~ 00008319 ...
21:56:26 500Â Â Â INFO:check start
21:56:26 500Â Â Â INFO:Writing sector 00008320 ~ 00008335 ...
21:56:26 500Â Â Â INFO:Reading sector 00008320 ~ 00008335 ...
21:56:26 515Â Â Â INFO:Writing sector 00008336 ~ 00008351 ...
21:56:26 515Â Â Â INFO:Reading sector 00008336 ~ 00008351 ...
21:56:26 515Â Â Â INFO:check start
21:56:26 515Â Â Â INFO:Writing sector 00008352 ~ 00008367 ...
21:56:26 531Â Â Â INFO:Reading sector 00008352 ~ 00008367 ...
21:56:26 531Â Â Â INFO:check start
21:56:26 531Â Â Â INFO:Writing sector 00008368 ~ 00008383 ...
21:56:26 531Â Â Â INFO:Reading sector 00008368 ~ 00008383 ...
21:56:26 531Â Â Â INFO:Writing sector 00008384 ~ 00008399 ...
21:56:26 546Â Â Â INFO:Reading sector 00008384 ~ 00008399 ...
21:56:26 546Â Â Â INFO:check start
21:56:26 546Â Â Â INFO:Writing sector 00008400 ~ 00008415 ...
21:56:26 546Â Â Â INFO:Reading sector 00008400 ~ 00008415 ...
21:56:26 546Â Â Â INFO:Writing sector 00008416 ~ 00008431 ...
21:56:26 562Â Â Â INFO:Reading sector 00008416 ~ 00008431 ...
21:56:26 562Â Â Â INFO:check start
21:56:26 562Â Â Â INFO:Writing sector 00008432 ~ 00008443 ...
21:56:26 562Â Â Â INFO:Reading sector 00008432 ~ 00008443 ...
21:56:26 578Â Â Â INFO:check start
21:56:26 578   INFO:Writeing the 4th ID Block£¬Pos£º00012288(SEC)
21:56:26 578Â Â Â INFO:Writing sector 00012288 ~ 00012303 ...
21:56:26 578Â Â Â INFO:Reading sector 00012288 ~ 00012303 ...
21:56:26 578Â Â Â INFO:Writing sector 00012304 ~ 00012319 ...
21:56:26 593Â Â Â INFO:Reading sector 00012304 ~ 00012319 ...
21:56:26 593Â Â Â INFO:check start
21:56:26 593Â Â Â INFO:Writing sector 00012320 ~ 00012335 ...
21:56:26 593Â Â Â INFO:Reading sector 00012320 ~ 00012335 ...
21:56:26 609Â Â Â INFO:check start
21:56:26 609Â Â Â INFO:Writing sector 00012336 ~ 00012351 ...
21:56:26 609Â Â Â INFO:Reading sector 00012336 ~ 00012351 ...
21:56:26 609Â Â Â INFO:Writing sector 00012352 ~ 00012367 ...
21:56:26 625Â Â Â INFO:Reading sector 00012352 ~ 00012367 ...
21:56:26 625Â Â Â INFO:check start
21:56:26 625Â Â Â INFO:Writing sector 00012368 ~ 00012383 ...
21:56:26 625Â Â Â INFO:Reading sector 00012368 ~ 00012383 ...
21:56:26 625Â Â Â INFO:Writing sector 00012384 ~ 00012399 ...
21:56:26 640Â Â Â INFO:Reading sector 00012384 ~ 00012399 ...
21:56:26 640Â Â Â INFO:check start
21:56:26 640Â Â Â INFO:Writing sector 00012400 ~ 00012415 ...
21:56:26 640Â Â Â INFO:Reading sector 00012400 ~ 00012415 ...
21:56:26 656Â Â Â INFO:check start
21:56:26 656Â Â Â INFO:Writing sector 00012416 ~ 00012431 ...
21:56:26 656Â Â Â INFO:Reading sector 00012416 ~ 00012431 ...
21:56:26 656Â Â Â INFO:Writing sector 00012432 ~ 00012447 ...
21:56:26 671Â Â Â INFO:Reading sector 00012432 ~ 00012447 ...
21:56:26 671Â Â Â INFO:check start
21:56:26 671Â Â Â INFO:Writing sector 00012448 ~ 00012463 ...
21:56:26 671Â Â Â INFO:Reading sector 00012448 ~ 00012463 ...
21:56:26 671Â Â Â INFO:Writing sector 00012464 ~ 00012479 ...
21:56:26 687Â Â Â INFO:Reading sector 00012464 ~ 00012479 ...
21:56:26 687Â Â Â INFO:check start
21:56:26 687Â Â Â INFO:Writing sector 00012480 ~ 00012495 ...
21:56:26 687Â Â Â INFO:Reading sector 00012480 ~ 00012495 ...
21:56:26 687Â Â Â INFO:Writing sector 00012496 ~ 00012511 ...
21:56:26 703Â Â Â INFO:Reading sector 00012496 ~ 00012511 ...
21:56:26 703Â Â Â INFO:check start
21:56:26 703Â Â Â INFO:Writing sector 00012512 ~ 00012527 ...
21:56:26 703Â Â Â INFO:Reading sector 00012512 ~ 00012527 ...
21:56:26 718Â Â Â INFO:check start
21:56:26 718Â Â Â INFO:Writing sector 00012528 ~ 00012539 ...
21:56:26 718Â Â Â INFO:Reading sector 00012528 ~ 00012539 ...
21:56:26 718   INFO:Writeing the 5th ID Block£¬Pos£º00016384(SEC)
21:56:26 718Â Â Â INFO:Writing sector 00016384 ~ 00016399 ...
21:56:26 734Â Â Â INFO:Reading sector 00016384 ~ 00016399 ...
21:56:26 734Â Â Â INFO:check start
21:56:26 734Â Â Â INFO:Writing sector 00016400 ~ 00016415 ...
21:56:26 734Â Â Â INFO:Reading sector 00016400 ~ 00016415 ...
21:56:26 750Â Â Â INFO:check start
21:56:26 750Â Â Â INFO:Writing sector 00016416 ~ 00016431 ...
21:56:26 750Â Â Â INFO:Reading sector 00016416 ~ 00016431 ...
21:56:26 750Â Â Â INFO:Writing sector 00016432 ~ 00016447 ...
21:56:26 765Â Â Â INFO:Reading sector 00016432 ~ 00016447 ...
21:56:26 765Â Â Â INFO:check start
21:56:26 765Â Â Â INFO:Writing sector 00016448 ~ 00016463 ...
21:56:26 765Â Â Â INFO:Reading sector 00016448 ~ 00016463 ...
21:56:26 765Â Â Â INFO:Writing sector 00016464 ~ 00016479 ...
21:56:26 781Â Â Â INFO:Reading sector 00016464 ~ 00016479 ...
21:56:26 781Â Â Â INFO:check start
21:56:26 781Â Â Â INFO:Writing sector 00016480 ~ 00016495 ...
21:56:26 781Â Â Â INFO:Reading sector 00016480 ~ 00016495 ...
21:56:26 796Â Â Â INFO:check start
21:56:26 796Â Â Â INFO:Writing sector 00016496 ~ 00016511 ...
21:56:26 796Â Â Â INFO:Reading sector 00016496 ~ 00016511 ...
21:56:26 796Â Â Â INFO:Writing sector 00016512 ~ 00016527 ...
21:56:26 812Â Â Â INFO:Reading sector 00016512 ~ 00016527 ...
21:56:26 812Â Â Â INFO:check start
21:56:26 812Â Â Â INFO:Writing sector 00016528 ~ 00016543 ...
21:56:26 812Â Â Â INFO:Reading sector 00016528 ~ 00016543 ...
21:56:26 812Â Â Â INFO:Writing sector 00016544 ~ 00016559 ...
21:56:26 828Â Â Â INFO:Reading sector 00016544 ~ 00016559 ...
21:56:26 828Â Â Â INFO:check start
21:56:26 828Â Â Â INFO:Writing sector 00016560 ~ 00016575 ...
21:56:26 828Â Â Â INFO:Reading sector 00016560 ~ 00016575 ...
21:56:26 843Â Â Â INFO:Writing sector 00016576 ~ 00016591 ...
21:56:26 843Â Â Â INFO:Reading sector 00016576 ~ 00016591 ...
21:56:26 843Â Â Â INFO:check start
21:56:26 843Â Â Â INFO:Writing sector 00016592 ~ 00016607 ...
21:56:26 859Â Â Â INFO:Reading sector 00016592 ~ 00016607 ...
21:56:26 859Â Â Â INFO:check start
21:56:26 859Â Â Â INFO:Writing sector 00016608 ~ 00016623 ...
21:56:26 859Â Â Â INFO:Reading sector 00016608 ~ 00016623 ...
21:56:26 859Â Â Â INFO:Writing sector 00016624 ~ 00016635 ...
21:56:26 875Â Â Â INFO:Reading sector 00016624 ~ 00016635 ...
21:56:26 875Â Â Â INFO:check start
21:56:26 875Â Â Â INFO:start to erase system disk
21:56:26 875Â Â Â INFO:Download IDB OK
21:56:26 875Â Â Â INFO:Start to reset device
21:56:26 875Â Â Â INFO:Reset device OK
21:56:26 875Â Â Â INFO:LoaderThread Finish
21:56:28 890Â Â Â Image Thread Path(\\?\USB#VID_2207&PID_300A#5&1BBE8508&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=3468
21:56:28 906Â Â Â INFO:Start to test device
21:56:28 906Â Â Â ERROR:TestUnitReady failed,Errcode(-1)
21:56:29 906Â Â Â INFO:Test device OK
21:56:29 906Â Â Â INFO:Start to download file
21:56:29 906Â Â Â INFO: Start to download files to flash,backup offset=0x18000
21:56:29 906Â Â Â INFO:Flash Start to download file to flash
21:56:29 953Â Â Â Info:RKA_File_Download start,file=misc,offset=0x2000
21:56:29 968Â Â Â Info:RKA_File_Download start,file=kernel,offset=0x4000
21:56:31 453Â Â Â Info:RKA_File_Download start,file=boot,offset=0x8000
21:56:31 718Â Â Â Info:RKA_File_Download start,file=recovery,offset=0x10000
21:56:32 015Â Â Â Info:RKA_File_Download start,file=system,offset=0x61a000
21:58:03 250Â Â Â INFO: Download files to flash finished,Total(684351328)B
21:58:03 250Â Â Â INFO: Start to check data
21:58:03 250Â Â Â INFO:Start to check download data
21:58:03 296Â Â Â Info:RKA_File_Check start,file=misc,offset=0x2000
21:58:03 312Â Â Â Info:RKA_File_Check start,file=kernel,offset=0x4000
21:58:03 843Â Â Â Error:Compare kernel file failed,Offset(8388608)
21:58:03 875Â Â Â Error: Check system file failed
21:58:03 875Â Â Â ERROR:Download file failed
21:58:03 875Â Â Â ERROR:Image Thread Failed
21:58:03 875Â Â Â ERROR:Run failed
Did you unpack the kernel.img?
2016/09/01
Did you unpack the kernel.img?- Oma -Â Â
I dont understand, what you mean by unpacking kernel.img?
If you mean unpacking the kernel.img from RK30_kernel_308_pmp7280c_prestigio.7z and put it in CrewRKTablets_RK30_Genio by Oma_AOSP_4.2.2_v3.4.7z
ockdev\Image\ folder, while overwriting the previous one, then yes.
 by the way is there any Lolipop rom for RK30xx tablets which works on PM7280C?
I am asking because the kernel does not write. But I see it is bigger than the standard partiton size. Pls replace also the parameter file in folder /rockdev: http://crewrktablets.arctablet.com/?wpfb_dl=934
As the tabs kernel is 3.0.8+ development stops with JB 4.2.2.
2016/09/01
this one with new parameter file went correct, but it does not booted to CWM recovery"
22:00:02 468Â Â Â Load Setting ok
22:00:02 515Â Â Â RKAndroidTool v1.3.5.0 Start Run
22:00:02 515Â Â Â Scan thread:2812
22:00:02 531Â Â Â Info:(thread=3080)IoControlProc-->DeviceIoControl In
22:00:02 531Â Â Â ProcessID:3292,ThreadID:3308,RefCount:0
22:00:02 531Â Â Â Info:(thread=3080)IoControlProc-->DeviceIoControl Out,ret=1,err=183
22:00:02 531Â Â Â ProcessID:3292,ThreadID:2812,RefCount:0
22:00:08 328Â Â Â INFO:Start to erase IDB
22:00:08 343Â Â Â INFO:Start to lower format
22:00:22 343Â Â Â INFO:Lower format OK
22:00:22 343Â Â Â INFO:Erasing IDB OK
22:00:40 625Â Â Â Loader Device Path(\\?\USB#VID_2207&PID_300A#5&1BBE8508&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=2340
22:00:40 625Â Â Â INFO:Start to run
22:00:40 625Â Â Â INFO:Start to test device
22:00:40 625Â Â Â INFO:Test device OK
22:00:40 625Â Â Â INFO:Start to download IDB
22:00:40 625Â Â Â Flash Chip Information:
22:00:40 625Â Â Â NOÂ Â Â Â Â Â SIZE(MB)Â Â Â Manufacturer
22:00:40 625Â Â Â ----------------------------------------------
22:00:40 625Â Â Â 0Â Â Â Â Â Â 8192MBÂ Â Â HYNIX
22:00:40 625Â Â Â INFO:BuildFlashStateMap start
22:00:40 640Â Â Â INFO: FindAllIDB start
22:00:40 640Â Â Â INFO:UpdateIDBData start
22:00:40 656Â Â Â INFO:Serial Number(14):
22:00:40 671Â Â Â 00000000: 50 4D 50 38 30 34 33 31 39 32 36 32 37 39 00 00
22:00:40 671Â Â Â 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00
22:00:40 671Â Â Â INFO:UID(30):
22:00:40 671Â Â Â 00000000: 52 4F 43 4B 43 48 49 50 5F 7B 72 00 0B 34 FE 6C
22:00:40 671Â Â Â 00000010: A2 7A 16 40 97 BD 41 1A 73 A8 76 15 82 D8
22:00:40 671Â Â Â INFO:BlueTooth(0):
22:00:40 671Â Â Â 00000000: 00 00 00 00 00 00
22:00:40 671Â Â Â INFO:Mac(0):
22:00:40 671Â Â Â INFO:WriteXIDBlock start
22:00:40 671Â Â Â INFO:MakeEccSpareData start
22:00:40 687Â Â Â INFO:WriteXIDBlock start
22:00:40 687   INFO:Writeing the 1th ID Block£¬Pos£º00000000(SEC)
22:00:40 687Â Â Â INFO:Writing sector 00000000 ~ 00000015 ...
22:00:40 687Â Â Â INFO:Reading sector 00000000 ~ 00000015 ...
22:00:40 687Â Â Â INFO:check start
22:00:40 703Â Â Â INFO:Writing sector 00000016 ~ 00000031 ...
22:00:40 703Â Â Â INFO:Reading sector 00000016 ~ 00000031 ...
22:00:40 703Â Â Â INFO:check start
22:00:40 703Â Â Â INFO:Writing sector 00000032 ~ 00000047 ...
22:00:40 718Â Â Â INFO:Reading sector 00000032 ~ 00000047 ...
22:00:40 718Â Â Â INFO:check start
22:00:40 718Â Â Â INFO:Writing sector 00000048 ~ 00000063 ...
22:00:40 718Â Â Â INFO:Reading sector 00000048 ~ 00000063 ...
22:00:40 718Â Â Â INFO:Writing sector 00000064 ~ 00000079 ...
22:00:40 734Â Â Â INFO:Reading sector 00000064 ~ 00000079 ...
22:00:40 734Â Â Â INFO:check start
22:00:40 734Â Â Â INFO:Writing sector 00000080 ~ 00000095 ...
22:00:40 734Â Â Â INFO:Reading sector 00000080 ~ 00000095 ...
22:00:40 750Â Â Â INFO:Writing sector 00000096 ~ 00000111 ...
22:00:40 750Â Â Â INFO:Reading sector 00000096 ~ 00000111 ...
22:00:40 750Â Â Â INFO:check start
22:00:40 750Â Â Â INFO:Writing sector 00000112 ~ 00000127 ...
22:00:40 750Â Â Â INFO:Reading sector 00000112 ~ 00000127 ...
22:00:40 765Â Â Â INFO:check start
22:00:40 765Â Â Â INFO:Writing sector 00000128 ~ 00000143 ...
22:00:40 765Â Â Â INFO:Reading sector 00000128 ~ 00000143 ...
22:00:40 765Â Â Â INFO:Writing sector 00000144 ~ 00000159 ...
22:00:40 781Â Â Â INFO:Reading sector 00000144 ~ 00000159 ...
22:00:40 781Â Â Â INFO:check start
22:00:40 781Â Â Â INFO:Writing sector 00000160 ~ 00000175 ...
22:00:40 781Â Â Â INFO:Reading sector 00000160 ~ 00000175 ...
22:00:40 781Â Â Â INFO:Writing sector 00000176 ~ 00000191 ...
22:00:40 796Â Â Â INFO:Reading sector 00000176 ~ 00000191 ...
22:00:40 796Â Â Â INFO:check start
22:00:40 796Â Â Â INFO:Writing sector 00000192 ~ 00000207 ...
22:00:40 796Â Â Â INFO:Reading sector 00000192 ~ 00000207 ...
22:00:40 812Â Â Â INFO:check start
22:00:40 812Â Â Â INFO:Writing sector 00000208 ~ 00000223 ...
22:00:40 812Â Â Â INFO:Reading sector 00000208 ~ 00000223 ...
22:00:40 812Â Â Â INFO:Writing sector 00000224 ~ 00000239 ...
22:00:40 828Â Â Â INFO:Reading sector 00000224 ~ 00000239 ...
22:00:40 828Â Â Â INFO:check start
22:00:40 828Â Â Â INFO:Writing sector 00000240 ~ 00000251 ...
22:00:40 828Â Â Â INFO:Reading sector 00000240 ~ 00000251 ...
22:00:40 828   INFO:Writeing the 2th ID Block£¬Pos£º00004096(SEC)
22:00:40 828Â Â Â INFO:Writing sector 00004096 ~ 00004111 ...
22:00:40 843Â Â Â INFO:Reading sector 00004096 ~ 00004111 ...
22:00:40 843Â Â Â INFO:check start
22:00:40 843Â Â Â INFO:Writing sector 00004112 ~ 00004127 ...
22:00:40 843Â Â Â INFO:Reading sector 00004112 ~ 00004127 ...
22:00:40 859Â Â Â INFO:check start
22:00:40 859Â Â Â INFO:Writing sector 00004128 ~ 00004143 ...
22:00:40 859Â Â Â INFO:Reading sector 00004128 ~ 00004143 ...
22:00:40 859Â Â Â INFO:Writing sector 00004144 ~ 00004159 ...
22:00:40 875Â Â Â INFO:Reading sector 00004144 ~ 00004159 ...
22:00:40 875Â Â Â INFO:check start
22:00:40 875Â Â Â INFO:Writing sector 00004160 ~ 00004175 ...
22:00:40 875Â Â Â INFO:Reading sector 00004160 ~ 00004175 ...
22:00:40 875Â Â Â INFO:Writing sector 00004176 ~ 00004191 ...
22:00:40 890Â Â Â INFO:Reading sector 00004176 ~ 00004191 ...
22:00:40 890Â Â Â INFO:check start
22:00:40 890Â Â Â INFO:Writing sector 00004192 ~ 00004207 ...
22:00:40 890Â Â Â INFO:Reading sector 00004192 ~ 00004207 ...
22:00:40 906Â Â Â INFO:check start
22:00:40 906Â Â Â INFO:Writing sector 00004208 ~ 00004223 ...
22:00:40 906Â Â Â INFO:Reading sector 00004208 ~ 00004223 ...
22:00:40 906Â Â Â INFO:Writing sector 00004224 ~ 00004239 ...
22:00:40 921Â Â Â INFO:Reading sector 00004224 ~ 00004239 ...
22:00:40 921Â Â Â INFO:check start
22:00:40 921Â Â Â INFO:Writing sector 00004240 ~ 00004255 ...
22:00:40 921Â Â Â INFO:Reading sector 00004240 ~ 00004255 ...
22:00:40 921Â Â Â INFO:Writing sector 00004256 ~ 00004271 ...
22:00:40 937Â Â Â INFO:Reading sector 00004256 ~ 00004271 ...
22:00:40 937Â Â Â INFO:check start
22:00:40 937Â Â Â INFO:Writing sector 00004272 ~ 00004287 ...
22:00:40 937Â Â Â INFO:Reading sector 00004272 ~ 00004287 ...
22:00:40 937Â Â Â INFO:Writing sector 00004288 ~ 00004303 ...
22:00:40 953Â Â Â INFO:Reading sector 00004288 ~ 00004303 ...
22:00:40 953Â Â Â INFO:check start
22:00:40 953Â Â Â INFO:Writing sector 00004304 ~ 00004319 ...
22:00:40 953Â Â Â INFO:Reading sector 00004304 ~ 00004319 ...
22:00:40 968Â Â Â INFO:check start
22:00:40 968Â Â Â INFO:Writing sector 00004320 ~ 00004335 ...
22:00:40 968Â Â Â INFO:Reading sector 00004320 ~ 00004335 ...
22:00:40 968Â Â Â INFO:Writing sector 00004336 ~ 00004347 ...
22:00:40 984Â Â Â INFO:Reading sector 00004336 ~ 00004347 ...
22:00:40 984Â Â Â INFO:check start
22:00:40 984   INFO:Writeing the 3th ID Block£¬Pos£º00008192(SEC)
22:00:40 984Â Â Â INFO:Writing sector 00008192 ~ 00008207 ...
22:00:41 000Â Â Â INFO:Reading sector 00008192 ~ 00008207 ...
22:00:41 000Â Â Â INFO:check start
22:00:41 000Â Â Â INFO:Writing sector 00008208 ~ 00008223 ...
22:00:41 000Â Â Â INFO:Reading sector 00008208 ~ 00008223 ...
22:00:41 015Â Â Â INFO:check start
22:00:41 015Â Â Â INFO:Writing sector 00008224 ~ 00008239 ...
22:00:41 015Â Â Â INFO:Reading sector 00008224 ~ 00008239 ...
22:00:41 015Â Â Â INFO:Writing sector 00008240 ~ 00008255 ...
22:00:41 031Â Â Â INFO:Reading sector 00008240 ~ 00008255 ...
22:00:41 031Â Â Â INFO:check start
22:00:41 031Â Â Â INFO:Writing sector 00008256 ~ 00008271 ...
22:00:41 046Â Â Â INFO:Reading sector 00008256 ~ 00008271 ...
22:00:41 046Â Â Â INFO:check start
22:00:41 046Â Â Â INFO:Writing sector 00008272 ~ 00008287 ...
22:00:41 062Â Â Â INFO:Reading sector 00008272 ~ 00008287 ...
22:00:41 062Â Â Â INFO:check start
22:00:41 062Â Â Â INFO:Writing sector 00008288 ~ 00008303 ...
22:00:41 078Â Â Â INFO:Reading sector 00008288 ~ 00008303 ...
22:00:41 078Â Â Â INFO:check start
22:00:41 078Â Â Â INFO:Writing sector 00008304 ~ 00008319 ...
22:00:41 078Â Â Â INFO:Reading sector 00008304 ~ 00008319 ...
22:00:41 093Â Â Â INFO:Writing sector 00008320 ~ 00008335 ...
22:00:41 093Â Â Â INFO:Reading sector 00008320 ~ 00008335 ...
22:00:41 093Â Â Â INFO:check start
22:00:41 093Â Â Â INFO:Writing sector 00008336 ~ 00008351 ...
22:00:41 109Â Â Â INFO:Reading sector 00008336 ~ 00008351 ...
22:00:41 109Â Â Â INFO:check start
22:00:41 109Â Â Â INFO:Writing sector 00008352 ~ 00008367 ...
22:00:41 109Â Â Â INFO:Reading sector 00008352 ~ 00008367 ...
22:00:41 109Â Â Â INFO:Writing sector 00008368 ~ 00008383 ...
22:00:41 125Â Â Â INFO:Reading sector 00008368 ~ 00008383 ...
22:00:41 125Â Â Â INFO:check start
22:00:41 125Â Â Â INFO:Writing sector 00008384 ~ 00008399 ...
22:00:41 125Â Â Â INFO:Reading sector 00008384 ~ 00008399 ...
22:00:41 140Â Â Â INFO:Writing sector 00008400 ~ 00008415 ...
22:00:41 140Â Â Â INFO:Reading sector 00008400 ~ 00008415 ...
22:00:41 140Â Â Â INFO:check start
22:00:41 140Â Â Â INFO:Writing sector 00008416 ~ 00008431 ...
22:00:41 156Â Â Â INFO:Reading sector 00008416 ~ 00008431 ...
22:00:41 156Â Â Â INFO:check start
22:00:41 156Â Â Â INFO:Writing sector 00008432 ~ 00008443 ...
22:00:41 156Â Â Â INFO:Reading sector 00008432 ~ 00008443 ...
22:00:41 156   INFO:Writeing the 4th ID Block£¬Pos£º00012288(SEC)
22:00:41 156Â Â Â INFO:Writing sector 00012288 ~ 00012303 ...
22:00:41 171Â Â Â INFO:Reading sector 00012288 ~ 00012303 ...
22:00:41 171Â Â Â INFO:check start
22:00:41 171Â Â Â INFO:Writing sector 00012304 ~ 00012319 ...
22:00:41 171Â Â Â INFO:Reading sector 00012304 ~ 00012319 ...
22:00:41 187Â Â Â INFO:check start
22:00:41 187Â Â Â INFO:Writing sector 00012320 ~ 00012335 ...
22:00:41 187Â Â Â INFO:Reading sector 00012320 ~ 00012335 ...
22:00:41 187Â Â Â INFO:Writing sector 00012336 ~ 00012351 ...
22:00:41 203Â Â Â INFO:Reading sector 00012336 ~ 00012351 ...
22:00:41 203Â Â Â INFO:check start
22:00:41 203Â Â Â INFO:Writing sector 00012352 ~ 00012367 ...
22:00:41 203Â Â Â INFO:Reading sector 00012352 ~ 00012367 ...
22:00:41 203Â Â Â INFO:Writing sector 00012368 ~ 00012383 ...
22:00:41 218Â Â Â INFO:Reading sector 00012368 ~ 00012383 ...
22:00:41 218Â Â Â INFO:check start
22:00:41 218Â Â Â INFO:Writing sector 00012384 ~ 00012399 ...
22:00:41 218Â Â Â INFO:Reading sector 00012384 ~ 00012399 ...
22:00:41 234Â Â Â INFO:check start
22:00:41 234Â Â Â INFO:Writing sector 00012400 ~ 00012415 ...
22:00:41 234Â Â Â INFO:Reading sector 00012400 ~ 00012415 ...
22:00:41 234Â Â Â INFO:Writing sector 00012416 ~ 00012431 ...
22:00:41 250Â Â Â INFO:Reading sector 00012416 ~ 00012431 ...
22:00:41 250Â Â Â INFO:check start
22:00:41 250Â Â Â INFO:Writing sector 00012432 ~ 00012447 ...
22:00:41 250Â Â Â INFO:Reading sector 00012432 ~ 00012447 ...
22:00:41 250Â Â Â INFO:Writing sector 00012448 ~ 00012463 ...
22:00:41 265Â Â Â INFO:Reading sector 00012448 ~ 00012463 ...
22:00:41 265Â Â Â INFO:check start
22:00:41 265Â Â Â INFO:Writing sector 00012464 ~ 00012479 ...
22:00:41 265Â Â Â INFO:Reading sector 00012464 ~ 00012479 ...
22:00:41 265Â Â Â INFO:Writing sector 00012480 ~ 00012495 ...
22:00:41 281Â Â Â INFO:Reading sector 00012480 ~ 00012495 ...
22:00:41 281Â Â Â INFO:check start
22:00:41 281Â Â Â INFO:Writing sector 00012496 ~ 00012511 ...
22:00:41 281Â Â Â INFO:Reading sector 00012496 ~ 00012511 ...
22:00:41 296Â Â Â INFO:check start
22:00:41 296Â Â Â INFO:Writing sector 00012512 ~ 00012527 ...
22:00:41 296Â Â Â INFO:Reading sector 00012512 ~ 00012527 ...
22:00:41 296Â Â Â INFO:Writing sector 00012528 ~ 00012539 ...
22:00:41 312Â Â Â INFO:Reading sector 00012528 ~ 00012539 ...
22:00:41 312Â Â Â INFO:check start
22:00:41 312   INFO:Writeing the 5th ID Block£¬Pos£º00016384(SEC)
22:00:41 312Â Â Â INFO:Writing sector 00016384 ~ 00016399 ...
22:00:41 312Â Â Â INFO:Reading sector 00016384 ~ 00016399 ...
22:00:41 328Â Â Â INFO:check start
22:00:41 328Â Â Â INFO:Writing sector 00016400 ~ 00016415 ...
22:00:41 328Â Â Â INFO:Reading sector 00016400 ~ 00016415 ...
22:00:41 328Â Â Â INFO:Writing sector 00016416 ~ 00016431 ...
22:00:41 343Â Â Â INFO:Reading sector 00016416 ~ 00016431 ...
22:00:41 343Â Â Â INFO:check start
22:00:41 343Â Â Â INFO:Writing sector 00016432 ~ 00016447 ...
22:00:41 343Â Â Â INFO:Reading sector 00016432 ~ 00016447 ...
22:00:41 343Â Â Â INFO:Writing sector 00016448 ~ 00016463 ...
22:00:41 359Â Â Â INFO:Reading sector 00016448 ~ 00016463 ...
22:00:41 359Â Â Â INFO:check start
22:00:41 359Â Â Â INFO:Writing sector 00016464 ~ 00016479 ...
22:00:41 359Â Â Â INFO:Reading sector 00016464 ~ 00016479 ...
22:00:41 375Â Â Â INFO:Writing sector 00016480 ~ 00016495 ...
22:00:41 375Â Â Â INFO:Reading sector 00016480 ~ 00016495 ...
22:00:41 375Â Â Â INFO:check start
22:00:41 375Â Â Â INFO:Writing sector 00016496 ~ 00016511 ...
22:00:41 390Â Â Â INFO:Reading sector 00016496 ~ 00016511 ...
22:00:41 390Â Â Â INFO:check start
22:00:41 390Â Â Â INFO:Writing sector 00016512 ~ 00016527 ...
22:00:41 390Â Â Â INFO:Reading sector 00016512 ~ 00016527 ...
22:00:41 390Â Â Â INFO:Writing sector 00016528 ~ 00016543 ...
22:00:41 406Â Â Â INFO:Reading sector 00016528 ~ 00016543 ...
22:00:41 406Â Â Â INFO:check start
22:00:41 406Â Â Â INFO:Writing sector 00016544 ~ 00016559 ...
22:00:41 406Â Â Â INFO:Reading sector 00016544 ~ 00016559 ...
22:00:41 406Â Â Â INFO:Writing sector 00016560 ~ 00016575 ...
22:00:41 421Â Â Â INFO:Reading sector 00016560 ~ 00016575 ...
22:00:41 421Â Â Â INFO:check start
22:00:41 421Â Â Â INFO:Writing sector 00016576 ~ 00016591 ...
22:00:41 421Â Â Â INFO:Reading sector 00016576 ~ 00016591 ...
22:00:41 437Â Â Â INFO:check start
22:00:41 437Â Â Â INFO:Writing sector 00016592 ~ 00016607 ...
22:00:41 437Â Â Â INFO:Reading sector 00016592 ~ 00016607 ...
22:00:41 437Â Â Â INFO:Writing sector 00016608 ~ 00016623 ...
22:00:41 453Â Â Â INFO:Reading sector 00016608 ~ 00016623 ...
22:00:41 453Â Â Â INFO:check start
22:00:41 453Â Â Â INFO:Writing sector 00016624 ~ 00016635 ...
22:00:41 453Â Â Â INFO:Reading sector 00016624 ~ 00016635 ...
22:00:41 453Â Â Â INFO:start to erase system disk
22:00:41 453Â Â Â INFO:Download IDB OK
22:00:41 468Â Â Â INFO:Start to reset device
22:00:41 468Â Â Â INFO:Reset device OK
22:00:41 468Â Â Â INFO:LoaderThread Finish
22:00:43 484Â Â Â Image Thread Path(\\?\USB#VID_2207&PID_300A#5&1BBE8508&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=2348
22:00:43 500Â Â Â INFO:Start to test device
22:00:43 500Â Â Â INFO:Test device OK
22:00:43 500Â Â Â INFO:Start to download file
22:00:43 500Â Â Â INFO: Start to download files to flash,backup offset=0x1c000
22:00:43 515Â Â Â INFO:Flash Start to download file to flash
22:00:43 546Â Â Â Info:RKA_File_Download start,file=misc,offset=0x2000
22:00:43 562Â Â Â Info:RKA_File_Download start,file=kernel,offset=0x4000
22:00:45 062Â Â Â Info:RKA_File_Download start,file=boot,offset=0xc000
22:00:45 343Â Â Â Info:RKA_File_Download start,file=recovery,offset=0x14000
22:00:45 640Â Â Â Info:RKA_File_Download start,file=system,offset=0x61e000
22:02:16 968Â Â Â INFO: Download files to flash finished,Total(684351328)B
22:02:16 968Â Â Â INFO: Start to check data
22:02:16 968Â Â Â INFO:Start to check download data
22:02:17 015Â Â Â Info:RKA_File_Check start,file=misc,offset=0x2000
22:02:17 031Â Â Â Info:RKA_File_Check start,file=kernel,offset=0x4000
22:02:17 593Â Â Â Info:RKA_File_Check start,file=boot,offset=0xc000
22:02:17 703Â Â Â Info:RKA_File_Check start,file=recovery,offset=0x14000
22:02:17 812Â Â Â Info:RKA_File_Check start,file=system,offset=0x61e000
22:02:56 953Â Â Â INFO:Download file OK,Elapsed(133453MS)
22:02:56 953Â Â Â INFO:Run OK
2016/09/01
but I think that tablet is in recovery mode but I cant see anything on display, like cwm recovery,
when I hold power it turns off and after then with power turns on and rom normaly boots on only touch axis are mirrored i think so?
when in recovery (blank screen) I give adb devices I get:
List of devices attached
0123456789ABCDEFÂ Â Â Â Â Â Â recovery
even when try adb reboot recovery it wokrs I hear sound it restarts see the prestigio logo and after then blank screen no cwm
adb reboot same see blank screen, but i found out that can see the touch s when I touch the digitizer
and adb devices give me:
E3FZH56HFE device
when I power on the tablet with power switch it turn on rom starts, but after adb devices I get:
24EP0QDIYG device
that is strange to me
and
C:\tmp>adb sideload PMP7280C.zip
loading: 'PMP7280C.zip'
error: closed
Do you have a backup of the stock firmware or is the firmware available elsewhere?
77 Guest(s)
Devices in use: Desktop (68), Phone (8), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
