2014/10/07
Hello!
I have a Ployer Momo 12 tablet with the touchscreen from U30GTH (101028-01A-V1). With the stock ployer kernel (http://crewrktablets.arctablet.com/?wpfb_dl=1198) I have working only left half of touchscreen rotated counterclockwise. With this stock U30GTH kernel or HB U30GT kernel touch works pretty fine, but no sound and autorotate. Is it possible to port ft5x0x_ts module to original ployer kernel?
dmesg with stock ployer kernel:
<4>[ 1.453556] w++++++goodix_ts_probe gt28x goodix_init_platform_hw:0x0,0x0
<4>[ 1.563086] <--GT msg-->TOUCH_MAX_WIDTH : 0x800
<4>[ 1.563118] <--GT msg-->TOUCH_MAX_HEIGHT : 0x1280
<6>[ 1.563725] input: Goodix TouchScreen of Guitar as /devices/virtual/input/input1
<4>[ 1.564093] <--GT msg-->Register input device successfully!
<4>[ 1.564126] <--GT msg-->Request int port successfully!
<6>[ 1.564208] Goodix-TS-82X 2-005d: Start Goodix TouchScreen of Guitar in interrupt mode
<3>[ 1.633532] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
<3>[ 1.634035] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
<3>[ 1.634532] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
<3>[ 1.663544] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
<3>[ 1.664043] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
<3>[ 1.664536] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
<3>[ 1.693536] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
<3>[ 1.694033] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
<3>[ 1.694526] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
<3>[ 1.723082] Goodix-TS-82X 2-005d: Warnning: I2C communication might be ERROR!
<4>[ 1.723120] <--GT msg-->I2C test failed. I2C addr:5d
<5>[ 1.723152] Goodix-TS-82X 2-005d: The driver is removing...
<4>[ 1.813433] Goodix-TS-82X: probe of 2-005d failed with error -1
<6>[ 1.813602] SSL Touchscreen driver, (c) 2011 Solomon Systech Ltd.
<4>[ 1.813635] Version =ssd253x_20121020_16:20 SSD_For_RK3066 IPS LCD.Charles@Raysens
<4>[ 1.813746] [FT5X0X] file(drivers/input/touchscreen/ft5x0x_i2c_ts.c), function (fts_ts_probe), --probe start
<4>[ 1.813922] ft5x0x_init_platform_hw:0x0,0x0
<4>[ 2.554090] [FT5X0X] firmware version = 0x21
<4>[ 2.554486] [FT5X0X] firmware report rate = 100Hz
<4>[ 2.554881] [FT5X0X] firmware threshold = 100
<4>[ 2.555271] [FT5X0X] nosie mode = 0x 4
<6>[ 2.555808] input: ft5x0x_ts as /devices/virtual/input/input2
<4>[ 2.556183] [FT5X0X] file(drivers/input/touchscreen/ft5x0x_i2c_ts.c), function (fts_ts_probe), -- end
<4>[ 2.556531] ssd253x_init_hw:0x0,0x0
<4>[ 2.556557] ssd253x reset error
<4>[ 2.556577] ssd253x gpio_request error
<6>[ 2.556707] sis_ts_init
<6>[ 2.556967] sis_ts_probe
<4>[ 2.557119] sis_init_platform_hw:0x0,0x0
<4>[ 2.557143] sis gpio_request error
<4>[ 2.557163] si init_platform_hw failed
<4>[ 2.557208] sis_i2c_ts: probe of 2-0008 failed with error -5
<6>[ 2.559233] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-004c-1/input/input3
<6>[ 2.559889] mma7660 probe ok
dmesg with U30GTH kernel, touchscreen works properly:
<6>[ 1.367557] android_usb gadget: android_usb ready
<6>[ 1.367798] input: rk29-keypad as /devices/platform/rk29-keypad/input/input1
<6>[ 1.368043] input: ft5x0x_ts as /devices/platform/rk30_i2c.2/i2c-2/2-0038/input/input2
<6>[ 1.881586] ft5x0x_ts 2-0038: ft5x0x_probe : TP lib version 0x8 vendor ID 0x1
<6>[ 1.882014] ft5x0x_ts 2-0038: ft5x0x_probe : TP firmware version 0x21
<4>[ 1.882342] 465,ct36x_init_platform_hw,gpio request error!
<3>[ 1.882391] ct36x_ts 2-0001: Platform HW Init Failed.
<4>[ 1.882450] ct36x_ts: probe of 2-0001 failed with error -5
This is not a problem of the driver. The strange kernel flashed its touch controller firmware into your chip. The Momo stock kernel does this obviously not. So this is a dead end.
77 Guest(s)
Devices in use: Desktop (72), Phone (5)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
