Please help: Enable sleep and auto rotate on Oma RK31 Radxa Rock Box JB 4.2.2 v2.4
motionat
Forum Posts: 22
2013/12/01 - 14:19
I would just like to find out whether it is possible to enable sleep settings and auto rotate on this amazing rom.
I find it to be really fast on my cyclone voyager 8.
Thanks in advance
2013/12/01 - 16:35
There are a lot of RK31 builds for tabs which you can use with Cyclone Voyager 8 on the 3.0.36+ kernel.
motionat
Forum Posts: 22
2013/12/01 - 17:23
I am actually trying to use Oma RK31 Chuwi V88 JB 4.2.2 windoof v5.3a with the voyager 8 3.0.36+ kernel from the crewrktablets website. But I am uable to get wifi or bluetooth to work.
The rom is extremely smooth have a very nice benchmark. Can you at least help me to get this rom wifi enabled?
I have tried every wifi fix on crewrktablets website and none seem to work.
I have done everything as instructed.
changed kernel to voyager 8 3.0.36+ (downloaded from crewrktablets)
erased idb
flashed rom
flashed nand fix
The only rk31 rom which seems to have wifi working is Oma RK31 Chuwi V88 CM10.1 4.2.2 v1.3.
I will greatly appreciate any help on this topic.
2013/12/01 - 17:42
Try this one: http://crewrktablets.arctablet.com/?wpfb_dl=891
motionat
motionat
Forum Posts: 22
2013/12/01 - 18:15
Thanks Oma!! You have helped me again!! This rom works great!!!
Though is there a way to fix the auto rotate in this rom? Everything seems to be rotating in the opposite direction.
motionat
Forum Posts: 22
2013/12/01 - 18:44
This did not seem to work.
Do i need to unmount system and data CWM manually? Or do I need to apply this when flashing the rom for this first time?
2013/12/01 - 18:46
Just install via CWM. Same orientation or nothing?
motionat
Forum Posts: 22
2013/12/01 - 18:51
Nothing has changed. flashing the zip via CWM has unfortunately not fixed the problem.
2013/12/01 - 18:56
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1265
motionat
Forum Posts: 22
2013/12/01 - 19:10
The problem still seems to be there.
Maybe the fix did change orientation. but it is not the correct orientation.
2013/12/01 - 19:23
Ok, can you point me to the stock build working with you?
How is the orientation of bootanimation, lockscreen and launcher?
motionat
Forum Posts: 22
2013/12/01 - 19:30
The stock firmware that I use is from this site: http://sumvision.com/?p=newsitem&id=76
The orientation of the boot animation is portrait instead of landscape. the lockscreen and launcher immediately rotate to the right.
motionat
Forum Posts: 22
2013/12/01 - 19:45
Nothing has changed after flashing this zip. I will try and reflash the rom from scratch and try to flash the zips again.
72 Guest(s)
Devices in use: Desktop (68), Phone (4)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
