2013/03/06
Hi !
I have a strange Question
As i have a Pipo S1 with broken display, i am using it via HDMI out...
But of course, whatever HDMI Resolution i select, its always the crappy 840x480 scaled up to whatever...
From the Rk3066 USB Stick Development i learned that Android ALWAYS used the LCD Resolution for HDMI Output, it can be scaled to any Resolution but its just scaling, not native. And so there are 720p and 1080p kernels for the Rk3066 USB Sticks.
So i thought -> Okay you can change the Resolution in the kernel...
So i flashed a Pipo S3 ( = Odys Genio) Kernel to my S1.
AND: guess what: the Pipo S1 now "tries" to display the 1024x600 of the Pipo S3 -> The LCD only shows the upper left 840x480 corner but the HDMI output is MUCH sharper...
Thats fine but i have 2 Problems that need a solution:
-I would love a 1280x720 Resolution -> I tried to flash a MK808 720p kernel but that ended in a 1024x720 (!!!) Resolution, whyever...
-The Pipo S3 kernel works stable but i do not have wifi, of course there are more differences than LCD Resolution between S1 & S3.
What i would need is a S1 kernel with 1280x720p Resoution (if that is not possible because of a Hardware limit to 1024px max (?!?) then i would be fine with 1024x600).
Of course BEST would be something like the Omega Moon kernels for the MK808 Stick where you can CHANGE the internal Resolution with simple commands & reboot...
Is there someone out there who can help me out ? I guess it must be someone who can compile kernels for the S1...
If i did not make myself clear, please do not hesitate to ask.
And please do not mix up the native internal Resolution with the ones slectable in the HDMI panel, that only adjusts the SCALING of the native 840x480 px ...
Greetings,
Ender
2012/11/19
I'm not sure if I understand what you wrote correctly, cause I've never heard of this scaling feature you mention.
Astralix is the man who is working on a RK stick at the moment, I can only say what I have found in the "normal" kernels, but I may be wrong.
If you talk about the launcher of android, yes I think it is scaled from the native lcd panel resolution, and thats because it is a mirror of the launcher picture on the lcd panel and even if you connect a full hd screen, the rendering of the launcher was made for the lcd panel, not for the HDMI resolution. But if you use something like XBMC, it should give you a higher resolution on HDMI, not a scaled output of the video. That's the reason that the Pipo S3 kernel gives you a sharper launcher picture on the HDMI, it was rendered for the bigger screen resolution.
Greetings
JochenKauz
2013/03/06
Hi Jochen,
sorry für das posting auf Englisch, hatte nicht dran gedacht als ich die Post auf mehreren BBS gepostet habe !!!
Hmmm, was Du schreibst ist ja das normale Apps eben die native LCD Auflösung nutzen (alle möglichen Info Tools sagen eben 840x480, egal was man bei HDMI out angibt) und das Hardware decoding die Videos WIRKLICH in der HDMI Auflösung rendern.
Das ist zumindest nicht bei allen Video Playern so, aber ich werde das nochmal kritisch prüfen
(eingebauter Video Player & MX Player)...
Wenn das auf dem S1 so klappt wäre es natürlich toll, schaun wir mal...
Aber es wäre natürlich in jedem Falle auch toll Webbrowser & Android Spiele von einer höheren Auflösung profiieren zu lassen, der Rk3066 ist ja auf jeden Fall schnell genug für 1280x720 und bei meinem MK808 nutze ich oft eben jenen OmegaMoon Kernel um aus meinem billig-LG einen SmartTV zu machen und da sieht 1080p sehr gut aus wenn natürlich auch hi & da etwas ruckelig...
So Leute wie OmegaMoon & Finnless wissen auf jeden Fall wie man die "native" Auflösung in den kernel "haut", wie gesagt mit derern Kerneln zeigt sich dann ja auch der S1 auf HDMI mit höherer Launcher Auflösung als 840x480, aber ich dachte ich frage erst mal in der S1 / Rk3066 Community allgemein bevor ich die S3 Leute anhaue
Grüße,
Ender
P.S. wer weiss, vielelicht muss ich endlich mal genug lernen um selber einen kernel zu bauen, seufz, bis jetzt war ich immer zu faul
2012/11/19
also einen Kernel mit höherer Auflösung zu bauen, das ist kein Problem, denn das LCD muss ja nicht beachtet werden, was normalerweise immer schwierig ist.
Interessanter ist dann das drumherum, wie die restlichen Treiber, Sound, Wifi etc.
Da könnte man dann mal sehen ob es Kernel gibt, die bei Dir bestimmte Funktionen anschalten. Wenn wir dann Glück haben kennen wir dann den Treiber und die Parameter. Ansonsten ist auch ein dmesg sinnvoll, denn kann man sehen was so alles initialisiert wird.
Viele Grüße
JochenKauz
2013/03/06
Hallo Jochen,
die Frage ist wer / wo einen S1 kernel gebaut hat der funktioniert...
Denn DER hat ja dann die ganze Arbeit schon geleistet...
Derjenige müsste natürlich "nur mal" die "gefühlte" Auflösung erhöhen und rekompilieren.
Denn ich würde bei meinem S1 ja auch nur den kernel ersetzen...
Grüße,
Nils
2012/11/19
Stimmt, man muss sich die Arbeit ja nicht 2 Mal machen.
Eventuell findest Du ja eine Source, ich habe noch keine für ein Pipo S1 gesehen.
Viel Grüße
JochenKauz
61 Guest(s)
Devices in use: Desktop (52), Phone (9)
