Pls provide a dmesg log.
12-30 21:45:50.650 D/WifiHW ( 371): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
12-30 21:45:50.700 D/WifiHW ( 371): wifi_load_driver: driver load failed
We can try to load this module: http://crewrktablets.arctablet.com/?wpfb_dl=1331
Hm, as far as I can see the module is loaded.
What is the result of: lsmod?
Hm, try to load it manually:
insmod /system/lib/modules/rkwifi.ko
lsmod
2013/12/30
u0_a54@android:/ $ su
u0_a54@android:/ # insmod /system/lib/modules/rkwifi.ko
insmod: init_module '/system/lib/modules/rkwifi.ko' failed (No such file or directory)
255|u0_a54@android:/ # insmod /system/lib/modules/rkwifi.ko
but when i go to this folder it's exist
Wierd !
2012/11/19
Hmm...
Did you check permissions on that file?
2012/11/19
Unfortunately often rkwifi.ko is only a wrapper module which loads another module by itself.
It seems in your case that this file is not present. I talked to Oma about this, and he said that he takes a look at your StockRom again. Perhaps we can find what module is missing.Â
Currently Online: sadako11
68 Guest(s)
Devices in use: Desktop (64), Phone (5)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
