kapitaen02,
I think that for history purpose, JochenKauz just mentioned he moved your initial topic to the proper forum section, as you initial topic was posted here which in not the most appropriate place in the CrewRKTablets forum section. Hope it clarifies.
kapitaen02 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/11/19
Hi kapitaen02,
admin was right, it was only to make the forum more readable that I moved your topic in this forum section, cause it is related to CustomRom development.
Regards
JochenKauz
kapitaen02Per aspera ad astra, we rock the Tablets !
2014/01/19
Ok, thank you for the explanation, but now back to the technical issues
I made a download of the firmware source code from the ionik hp
http://service.i-onik.de/TP10.1-1500DC%20KB/
and searched in the folders for the keyboard.
I found a file named Generic.kl. In the header of this file there is the following description
# Generic key layout file for full alphabetic US English PC style external keyboards.
# This file is intentionally very generic and is intended to support a broad rang of keyboards.
# Do not edit the generic key layout to support a specific keyboard; instead, create
# a new key layout file with the required keyboard configuration.
So my question is, if this or a similar file integrated in the recocery, could help to solve the issue with my non- functional keyboard
Another thing, that came up yesterday by playing around ist, that I can't reboot in recovery mode! The reboot ends with the lying android an the red triangle
Again any ideas, dear experts?
You need to flash the CWM recovery (the recovery.img from the CM10.1 pack).
Tick parameter and recovery.
For the keyboard: I've already checked, what is in der stock firmware. But nothing. No kernel module, no vendor firmware, no keylayouts. A miracle.
2014/01/19
That is not correct, Oma. A layout of a (generic) keyboard is in the generic.kl- file. But I have another interesting thing: the power button of the keyboard works!? I pressed this evening the button on the keyboard and the tab went to standby. Then I tried pressing longer and I got the restart menu. So the docking interface seems to work. But the touchpad, the keys and the USB slots don't work. I'm really confused
In another forum I read something about legacy hardware!?
Sorry, as I mentioned bevor: I'm a rookie! But one question about programming: How can I convert the source code of the stock firmware? What development tool, converter, debugger or what do I need? And how can I compare the recovery flashfiles to the flashfiles generated with the Debugger?
2014/01/19
I screened the whole firmware again for the keyboard file. I found something that could be the one
Airis_3066_411_TRA\external\qemu\pc-bios\keymaps\
in this folder there is in the file 'common' a description of a QWERTY- keyboard.
The other files I found are named 'Generic.kcm' and 'Generic.kl' in the folder
Airis_3066_411_TRA\frameworks\base\data\keyboards\
And last but not least there is the file 'keyboard.h' in the folder
Airis_3066_411_TRA\bionic\libc\kernel\common\linux\
Additionally I found a description file 'keyboard-devices.md' under Airis_3066_411_TRA\docs\source.android.com\src\tech\input
but can't find any useful information for my prob
2014/01/30
I'm trying this with my i-onik TP10.1-1500DC-metal. I downloaded the CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.5.7z, unpacked that and replaced the kernel.img with the stock one from the file RK30_kernel_308_tp10.1_1500dc_metal_ionik.7z.
As I open RKAndroidTool c1.3.5 it says "Found RKAndroid MaskRom Rock Usb". I can also do the EraseIDB successfully, but when I click "Run" it downloads boot OK then proceeds to Test Device which is also OK. But then it says "Start to download IDB" and I get "Error: Download IDB failed" and "ERROR: Run failed".
Any pointers on what I can try next. The tablet is shaky, I can sometimes get it to show the android robot, but never boot into the os. Is it bricked completely?
2014/01/19
Hello again, after a lot oft reboots and no kitkat for rk3066 tabs available, I would like to flash the stock firmware on my ionik tp 10.1 1500 DC -kb. Can anybody brew me the relevant images or zip-files? Source is available under the service link in the post above. I have only probs, no benefits! No keyboard, probs with reboots and shut downs... 🙁 Thanks in advance
2016/05/23
Please help with my i.onik TP10.1-1500 KB
I have installed the firmware - CM 10.1 on rk30board. After reboot I Have black screen.
Maybe I Have error with replaced kernel? Please help
update: when I connect tablet to PC without keyboard - no response
when connect tablet with keyboard to PC - test defice failed (version 1.3.4)
2016/05/13
Hi hooky,
as far as I can tell, it really is a problem with your kernel.
If you replaced the kernel included with the CM 10.1 1.3.4 build with either the metal or darkgray metal versions of the tp10.1-1500, the black screen is likely caused by the wrong display driver(they use a 1280x800 panel, rather than the 1024x600 Panel from the keyboard version).
Regarding the pc connection problems, try to charge your tablet a bit, so it gets detected even without keyboard with it. If you get a driver installation notification, your good to go.( since it behaves as a new device in fastboot/download mode after formating its idb)
if it isn't recognized after recharging it, try reinstalling the drivers. After that, force shutdown the tablet(as it may or may not be in another boot state). While the Tablet is off, hold the Volume + button and plug in the usb cable while still holding volume+ wait until a device connection sound is played. Your Tablet should now appear in the flash tool.
To fix the kernel you just need to replace the kernel with the one you( hopefully) backed up before flashing. in your flash tool, you can uncheck anything but the kernel, otherwise the whole rom would be flashed again( it doesn't hurt though). No need to erase idb this time(unless you want to reflash the whole rom)
And while we are at it: If you did do a complete backup of the stock rom, could you provide me your system.img(the complete stock system.img is roughly 940 MB large)?
2016/05/23
KuraiNoOni said
Hi hooky,as far as I can tell, it really is a problem with your kernel.
no backup!!! (((
2016/05/13
@hooky:
ouch that's a problem.
Your Keyboard will probably not work with this rom and the akku life is reduced by half, since the keyboard is softswitched. ( in the stock rom, namely in the fuelgauge package of the settings app, there is a function that switches the extra akku, including the whole keyboard dock, off)
I'll upload my kernel, as soon as I'm home, so you can try if this works for you.
@Oma7144:
the driver for the keyboard is compiled into the kernel, so you couldn't find it in the android sources. As stated above the keyboard is softswitched through the battery menu in the settings. It utilizes both an interface to JBSService.apk and libjbs, which interfaces with the Keyboard. The keyboard will cease any input, but the powerbutton, while it is switched off.
It seems that the keyboard is initialized some time during boot on compatible firmwares( stock rom and airis transbook tra01 stock rom, and possibly even the airis exilis N1300 stock roms). This step is missing in both AOSP 4.2 and CM10.1 roms, as they were built for a larger palette of Rockchip devices, which don't usually have hardware keyboards. I can provide you with the necessary files, as soon, as I'm home.
2016/05/13
Here are the libraries and services for the keyboard support
Here is the kernel for the Tablet. Note: it's possible that it won't work with this kernel, since it is padded to 8mb(original kernel is about 6.7mb) If it does not work, I'll extract the non padded version from the boot partition as well.
2019/03/11
kapitaen02 said
Yep. Downloaded the zip-File you provided and extracted it with 7zip to the rockdevimage- folder. I have the ionik TP10.1 1500DC KB with keyboard. I have a downloaded kernel of the ionik- hp. But the behaviour is the same...Link: http://service.i-onik.de/TP10.1-1500DC%20KB/
Edit: I did a new try with the upper linked kernel. Tab was rebooting to CWM, formatted all date and stocks now in Bootmode with the 2 Linux pinguin and 2 shadows of them benind!? A new behaviour...
Edit: I used the stock recovery you provide on the hp crewrktablets!
I did a reboot by pressing OFF for 10 seconds. Booting was normal now, the two penguins for some seconds and now I got a yellwo screen with a lettering on the bottom of the tab. After that the system seems to be ready, but the screen doesn't react to anything and the screen width doesn't match
Hay , may i have stock firmware for ionik TP10.1 1500DC KB with keyboard
Please help me to get it It is so hard to find today
67 Guest(s)
Devices in use: Desktop (60), Phone (7)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
