2014/01/19
So I did it! I only flashed the v134 system.img with the stock recovery and the Ionik- Kernel. Run and Check was OK and the tab booted nromally with the crewrktablets- writing! After the apps were optimized, there was a warning, that the process com.android.phone was finished!?!? I tried to click 20 times OK, but the window doesn't appear
Apps optimized? Try again incl. eraseIDB.
kapitaen02Per aspera ad astra, we rock the Tablets !
EraseIDB will wipe the partition layout. So you need to flash all images.
Stopp for now and try again tomorrow.
2014/01/19
OK, I didn't realize that the EraseIDB is wiping the whole partition layout I flash again all the images and will inform you tomorrow, oh later I mean
Flash is still started...
This time the writing came while booting for a few minutes, the apps weren't opitmized and afterwards the same warning
I stop for today, you are right! Perhaps tomorrow more success Thank you for your support...
2014/01/19
Back again - give it a new try!
OK, I got it! Â Yesterday it was perhaps really a little too late for this stuff!?!? I analyzed again the files I flashed yesterday. Therefore I recognized, that the boot.img was not the same one as in OMAs package! So I did another clean flash with the original boot.img and
TATA it works
The WiFi connects without problems and the performance seems to be very good!!! Thank you OMA and the other developers of Crew RKTablets for your good work and you OMA especially for your time you spent to solve my problem!
Now, by playing around, I found a few problems:
- My keyboard doesn't work
- screen blackout, when orientation changes
Perhaps anybody a result for these topics?
2014/01/21
Thank youÂ
Kernel YuanDao N70HD is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1422Â
Fine.
If anything works, no need for a fix.
You mean the hardware keyboard? What kind of keyborad is it?
2014/01/19
It is the original one, that is delivered together with the tab. Sorry, can't paste the picture, so here is the link to the hp
http://www.i-onik.de/tablet_pcs_10.1_zoll
It is hardly connected to the tab an has a seperate battery in it, that reloads the tab. I thougt there would be no problem with the original kernel!? Wrong again...
Hm, what is or what is not? When the keyboard is plugged what is shown under settings/input method?
Is the soft keyboard showing up or nothing? ....
2012/11/19
One question, what modell do you own?
1. TP10.1-1500DC-dark grey-metal
2. TP10.1-1500DC-KB
Regards
JochenKauz
2014/01/19
I have the second one
2. TP10.1-1500DC-KB
and I will look this evening, what input method is listed under settings.
EDIT: I had a look in the setting list of the input methods. There is only the Android AOSP and Google Speech listed.
Another thins I recognized now: The keyboard has a accu inside and had loaded the tab with the firmware. Now the tab is not loaded and under settings/accu the second accu of the keyboard isn't listed! So the tablet- SW has no support for the docking interface inside, I think!?
2012/11/19
Moved to correct forum.
69 Guest(s)
Devices in use: Desktop (61), Phone (8)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
