Just flash the kernel (tick parameter and kernel).
TRiGGER80Per aspera ad astra, we rock the Tablets !
Ok, fine.
I will pack the stock firmware and upload them later to our legacy archive.
2013/11/11
Alright.
Will these be the same files that i sent you? If not, i'd be happy about a link. Just in case i ever need that.
I will keep testing the tablet, and i'll let you know how well it behaves. But so far, everything seems to be working nicely!
This was a triumph.
I'm making a note here: Huge success!
The following users say thank you to TRiGGER80 for this useful post:
kapitaen02
TRiGGER80, kapitaen02Per aspera ad astra, we rock the Tablets !
2014/01/19
Hello Trigger & Oma,
thank you both for your good job with the ionik- Tablet. I have a ionik TP10.1-1500DC-KB (with keyboard). I tried, reading this post and downloading the files of OMA from crewrktablets- hp, to install CM10.1 on my tablet too. Unfortunatly it doesn't word
Short Description: First I tried to flash the whole stuff - loader, parameter, misc, kernel, boot, recovery and system.
After the flash, the screen was black and nothing happend! Neither CWM booted, nor the system
After that I tried the workarounds you did in this post. One time after some experiments with other kernels and recoveries, I had a boot. But with the yellow screen I couldn't do anything. The screen width was wrong and the touchscreen wasn't reacting on my gestures!
Can anybody help me with this problem? But not this evening - tired enough...
Good night
CM10.1 build is here: http://crewrktablets.arctablet.com/?p=1913
Kernel for metal modell is here: http://crewrktablets.arctablet.com/?wpfb_dl=1216
Just change the kernel in folder rockdev/Images and flash acc. to instructions.
Kernel YuanDao N70HD is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1422
qwnPer aspera ad astra, we rock the Tablets !
2014/01/19
Thank you for your answer, but I still have problems with this ROM.
What happend:
Like in the instructions I booted the tab by holding Volume+ Button while plugging USB in.
Device was found in RKAndroidTool, the kernel you provided was changed in the folder rockdevimage, as described.
After the flash procedure the no device is found while saying in the info window, that the run was OK
The tablet lies in front of me with a black screen.
I flashed all sections, Loader V1.34, parameter, misc, kernel, boot, recovery and system.
Edit: When I look into the listed Hardware in the PC there is a Fusion device located! So the tab seems to be alive!?!?
Any other possibilities or tips?
To be sure: you have decompressed the kernel?
Black screen and booting OS simply means the kernel does not fit. What tab do you have exactly?
2014/01/19
Yep. Downloaded the zip-File you provided and extracted it with 7zip to the rockdevimage- folder. I have the ionik TP10.1 1500DC KB with keyboard. I have a downloaded kernel of the ionik- hp. But the behaviour is the same...
Link: http://service.i-onik.de/TP10.1-1500DC%20KB/
Edit: I did a new try with the upper linked kernel. Tab was rebooting to CWM, formatted all date and stocks now in Bootmode with the 2 Linux pinguin and 2 shadows of them benind!? A new behaviour...
Edit: I used the stock recovery you provide on the hp crewrktablets!
I did a reboot by pressing OFF for 10 seconds. Booting was normal now, the two penguins for some seconds and now I got a yellwo screen with a lettering on the bottom of the tab. After that the system seems to be ready, but the screen doesn't react to anything and the screen width doesn't match
2014/01/19
What do you think? Will I get a positive result, when I flash the fixes, that are listed under
http://crewrktablets.arctablet.com/?p=1913Â ?
Problem is, that I it seems, I can't get into CWM
Flash the v1.3.4 build together with your kernel and the stock recovery.
69 Guest(s)
Devices in use: Desktop (61), Phone (8)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
