2015/07/13
Hi, my tablet is an enery sistem i8 dual, 8" 1024x768 screen with rk3066, Mali 400, 1Gb ram, 8gb storage, 2mpx rear camera and vga front camera.
The stock rom android 4.1.1 it's very slooow.
Please can somebody help me with kernel and rom to use with this tablet?.
Here is the Open Source Kernel - i8 Dual - Android 4.1: http://storage.energysistem.com/archivos/drivers_y_actualizaciones/edaioglmgogl_rk-3066-android4.1.1-sdkv1.00-ker-i8-20130916-u.tar.gz?0152NRK3XVZh1yWW
Attached a 903.config extracted from source (renamed extension to .txt to upload it).
Seems that kernel is 308, wifi RK903 and LCD panel seems an wisky lcd???? (i'm not a developer only check some files from source kernel so maybe I uploaded the wrong file)
Thank you very much, I hope somebody can help me.
Is the stock firmware available?
Build: http://crewrktablets.arctablet.com/?p=1913
Kernel/parameter: http://crewrktablets.arctablet.com/?wpfb_dl=2601
Just change kernel in folder rockdev/Image and parameter in folder rockdev before flash.
Fine. Thank you for feedback!
58 Guest(s)
Devices in use: Desktop (47), Phone (11)
cutierogue
