Wifi could not be out-of-the box. v1.2 should have RTL8723 wifi.
2014/08/02
thanks for the reply ,
when i first ran the system the wifi didn't work and neither did the bluetooth , then i installed this fix via cwm http://crewrktablets.arctablet.com/?wpfb_dl=1226 and the wifi works fine but the bluetooth don't , isn't there a fix for that?
Uff, long time ago the feedback for this fix was negative ...
Anyway, I will look into BT later today.
Can you pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2065
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2065
What do you mean by g-sensor not working?
2014/08/02
still the bluetooth isn't working
for example i turn the tablet to the right and the screen turns upside down , also in games if i turn the tablet to left for instance the game detects mouvement down etc ... the problem is that the tablet doesn't detect correctly the movement i make
So, rotation is working. Only orientaion is not right. Check out all available sensor fixes.
For BT: open a terminal and let me have the output of lsmod.
2014/08/02
i tried all the 7 sensor fixes and none of them worked , yes orientation isn't working . there's an app to test the accelerometer it shows a ball and it moves as you move the tablet , when a put the tablet on an horizontal surface the ball falls down as if i turned down the tablet , did you understand a bit the problem ?
i'll open a terminal for the BT and posts the results in a few minutes
Ok, I am not sure if in this build scripts are on. Pls open Pimp my Rom and enable init.d scripts. Reboot.
62 Guest(s)
Devices in use: Desktop (54), Phone (8)
