2013/10/12
Hallo,and sorry for my very bad english) I'm from Ukraine,most the same as russia))
I had one of this tabs,they used linux kernel 3.0.8+Â
i'm very want to get 4.2.2 multi-window for this tabs,but multi-window needs kernel 3.0.36+ i didn't know how to compilate kernels((
Can any one help me with this???
Negativ, not enough sources to compile a 3.0.36+ kernel for an tab.
Is this your tabs 3.0.8+ kernel attached to the post? Check out the latest CM10.1 build.
Ok, thanks. Kernel is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=999
CM10.1 build is here: http://crewrktablets.arctablet.com/?p=1913
Give it a try.
ntfs.ko is running in the system: http://crewrktablets.arctablet.com/wp-content/uploads/2013/09/016.png
So, you should be able to mount external usb devices.
To swap the mounts: http://crewrktablets.arctablet.com/?wpfb_dl=1002
Use directly after first boot, otherwise android will get confused.
Android doesn't know about ntfs. Fat32 is the format for internal and external SD.
Mounting an ntfs formatted device is only possible via USB.
2013/10/12
@@Android doesn't know about ntfs. Fat32 is the format for internal and external SD.@@
This is something new)) Stock firmware,all yours previous roms,official CM10.1 are works with ntfs formatted sdcard)
I'm use this SD long time ago=) because our tabs sometimes create corrupted files and create errors on filesystem on fat32 formated cards(
2013/10/16
Oma, thank you very much for your firmware!
Build 1.3.2 works almost fine! But there are one very annoying bug When i rotate device (change orientation) on display appears some garbage for a moment. It is possible to fix it?
If you need I can give you some system information (specs, logs and etc)
I have tried with original kernel (3.0.8)
Thanks.
66 Guest(s)
Devices in use: Desktop (52), Phone (13), Tablet (1)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
