2014/01/27
Oma first thanks for your work!! than can you help me to fix the hdmi function with your rom cm 10.1??
When I Connect the tablet to the TV it will trasmits the first screen on the TV and than Frezee but the audio still work.... There is some chance to fix it???
Thanks a lot!!!
Is it the same when you boot the tab with the cable already plugged?
Hm, which build and kernel?
Maybe this is not the right kernel. There are three in the archive:
http://crewrktablets.arctablet.com/?wpfb_dl=1043
http://crewrktablets.arctablet.com/?wpfb_dl=1173
http://crewrktablets.arctablet.com/?wpfb_dl=1230
Try them all. Tick parameter and kernel in the RKAndroidTool.
Just to be sure: HDMI works before with stock firmware?
No idea why. Sorry. Works fine with me.
Can you try another resolution?
2014/01/27
Hi Oma,
Please can I ask you a BIG pleasure???
Because I found this new kernel for my tab and maybe is without hdmi problem but is not compatible with your rom (bootloop) and has also a bug during the bootanimation (there are two fuzzies jellyrobot), please can you remove it and make compatible with your rom????
Thank you very much
Where can I find the firmware and is it fully working with you?
2014/01/27
yes it is fully compatible with my tab.
https://mega.co.nz/#!ypoXzT4K!FXRKmHtSHETDMnjmin8inUNospNSaghCqyDNr0ZYtjM
Currently Online: astosenix
69 Guest(s)
Devices in use: Desktop (61), Phone (9)
grielgryel
klaus1255
neverever007
favorit
Альфвоф
kevbez
