As desribed you will need a 3.0.36+ kernel. As far as I know only 3.0.8+ kernel is availabe for U30GT-H.
2013/01/19
thank you once again Oma.
One last question if you dont mind..
I have got the 4.2.2 update working ok. The internal SD card is wiped clean/erased. Debugging mode is set to on. When I plug the usb connection to the PC , 2 new drives appear but I cannot enter into them, to copy files/images etc. I tried unmounting and had the same issue.Â
Before I updated the firmware, I was one 4.1 stock release. I could access the internal SD card as I copied some pictures and files over to my PC. It looks like any other drive that I could click into .
Any advice on accessing the internal SD card via my pc?
thank you
Disable usb-debugging and set storage to mass-storage.
Currently Online: andre92
74 Guest(s)
Devices in use: Desktop (61), Phone (13), Tablet (1)
andre92
firmwarefile
mongol
country822
vovandolgan
kenjakenjavitis
