E10316 has a 3.0.36+ kernel, so maybe a rk31 build will work.
Build: http://crewrktablets.arctablet.com/?p=3591
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1306
Change the kernel in folder rockdev/Images and flash incl. eraseIDB. Do NOT flash the loader.
After first boot into CWM do a factory reset and install this fix (copy to external sdcard before start): http://crewrktablets.arctablet.com/?wpfb_dl=1803
2013/03/10
Doesn't work. When i turn on wifi, the screen will go black and shutdown.
RK3188: Lollipop has landed on Odys Iron Works on E10316! (but no bluetooth and screen rotation)
Screen rotation works!!
Used: CrewRKTablets_RK31_CM10.1_analyse_sensor.zip and CrewRKTablets_RK31_CM10.1_sensor_x=y_y=-x_z=z.zip
No sound please help
Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2390
pimpbunnyPer aspera ad astra, we rock the Tablets !
Well, we do only have the precompiled blobs from the stock image. Doesn't work means we are without any chance here. Sorry.
Ok, I guess we miss here something due to our server crash. I tried to rebuild the fix. Can you pls test? http://crewrktablets.arctablet.com/?wpfb_dl=2415
2019/06/29
Dear,
please send me new link for CM11 android 4.4. for Medion e10316 lifetab.
This links are not working:
Build:Â http://crewrktablets.arctablet.com/?p=3591
Kernel:Â http://crewrktablets.arctablet.com/?wpfb_dl=1306
After first boot into CWM do a factory reset and install this fix (copy to external sdcard before start):Â http://crewrktablets.arctablet.com/?wpfb_dl=1803
69 Guest(s)
Devices in use: Desktop (59), Phone (9), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
