help to fix WiFi on AOSP 4.2.2 for Ampe A78 (wifi works on CM10.1 ROM)
DasBoot
2014/01/16 - 22:02
I tried to install AOSP ROM onto my AMPE A78 RK3066 tablet, it works, except the wifi.
But WiFi works fine on CM10.1 ROM.
I can unpack/rebuild system.img with RK3xxx_firmware_tools, so I need a hint which files should I substitute?
Please help to fix it.
2014/01/16 - 22:40
You can try to copy over parts from the stock rom:
/system/lib/libhardware_legacy.so
/system/lib/modules/wlan.ko, rkwifi.ko & other .ko files your wifi is using
/system/etc/firmware/
/system/bin/wpa_supplicant
/system/bin/wpa_cli
But there is nothing of interest in the AOSP build compared with the CM10.1 build.
DasBoot
DasBoot
2014/01/16 - 23:29
Stock firmware is 4.1.1 - can I still copy the mentioned files or no go?
On CM10.1 I have annoying problem with wifi - it doesn't reconnect after sleep. I hoped AOSP might work better.
2014/01/16 - 23:34
Try it. Don't forget to give sufficient rights.
49 Guest(s)
Devices in use: Desktop (37), Phone (12)
hellander
elousstad
relaytester
revoltown
tdomnic024
