2014/03/26
Hey guys,
i wanna ROM for my tablet
but i cant find
Tablet is http://piranha.com.tr/product.php?product_id=379
PIRANHA ULTRA 2 TAB
RK3066 1.6 GHz Dual Core
+ 8 GB + 1 GB DDR3 RAM +
 HDMI + 3G WIFI
Resoulation 800x480Â
UPDATE.IMG :Â https://disk.yandex.com.tr/public/?hash=St5fP71/33%2B/AC5JJY4dgbeIZD71FeBwqQbcxp5AMV8%3D
Build: http://crewrktablets.arctablet.com/?p=1913
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1744
2014/03/26
Before, thanks for build and kernelÂ
i solved problem with the CWM but
i have problem with wifi
wifi and bt is not working.Â
 WIFI PLATFORM : http://www.mediatek.com/en/products/connectivity/wifi/mobile-handset/abcd/
pls help me
Are you sure? There is no mt5931.ko in the stock build.
Can you pls flash stock back and do a dmesg log?
2014/07/05
I have an Overmax Dualdrive II tablet, which is renamed from some chinese product. How can I find the original manufacturer? I would like to load it's original rom or CM. Rkbatchtool cannot test the device (but it starts with green icon), and Rkandroidtool can not low level format it to load Oma's CM. However I was able to install CWM with arctool, before rooted with Vroot.
Thanks in advance.
Update: it was the problem with the windows drivers. Now flashed winth CM 10.1 1.3.5, but I only see lines on the screen.
Update2: Today tried with Odys Genio Beta v1.3.4 It only boots to Oma's CWM, with the following error messages on the lower left side:
e:can't mount /cache/recovery/command
e:can't mount /cache/recovery/log
e:can't open /cache/recovery/log
e:can't mount /cache/recovery/last_log
e:can't open /cache/recovery/last_log
Only the vol+ button works, the vol- and the power are not. Can anybody help?
Currently Online: portvein
78 Guest(s)
Devices in use: Desktop (66), Phone (13)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
