Help me to fix wifi icon in gray color and not show level signal.
anu2013
Thanks Received: 4
2014/02/24 - 07:40
Hi. Oma and developer.
My tablet is Scopad Hercules SP0718 rebanded from Cube U9GT4
another re-band with same too my tablet are Lava Xtron(not plus), Vivax 7150.
Specification
- RK3066 Dual-Core 1.5 GHz Cortex-A9 Processor.
- OS Android OS Version 4.1.1 (Jelly Bean)
- GPU Mali-400MP
- RAM ( DDR3) 1 GB
- Display IPS TFT LCD Capacitive Touchscreen Resolution 1024x600 Pixels ( Width 7.0 inches ratio 16:9)
- Built-in memory for data storage. 8 GB
- compatible memory card slot. microSD Card (TransFlash) up to size 32 GB
- Body Body made ​​of metal, Aluminum
- supports USB OTG
Now. I just made "JB 4.2.2 SDK2.0 multiUser" custom rom on scopad SP0718.
All worked. Network no problem. It is work good every thing .
Except wifi icon on notification bar in gray color and not show level signal (blue color), but have show 2 little arrow data in-out.
Can you help me to fix wifi icon in gray color and not show level signal?
Thank you so much for to help me.
Anucha.
Sorry for bad English language.
 01-1.pngImage Enlarger02.pngImage Enlarger03.pngImage Enlarger04.pngImage Enlarger05.pngImage Enlarger06.pngImage Enlarger07.pngImage Enlarger08.pngImage Enlarger09.pngImage Enlarger10.pngImage Enlarger11.pngImage Enlarger12.jpgImage Enlarger
srihari210
2014/02/27 - 10:01
Even I had similar problem...
Temporary fix is to use STATIC IP. Go to settings -> Wifi -> Connect ur wifi router -> Long press on your connected wifi -> modify network -> Show advanced Menu -> Change to DHCP to static and provide correct inputs.
If you find permanent fix, do let me know.
anu2013
Thanks Received: 4
2014/02/27 - 11:26
 Thank for reply.
I will try it when I go to home.
1920417_665058266867012_1126118472_n.jpgImage Enlarger
61 Guest(s)
Devices in use: Desktop (55), Phone (6)
jacksonrid
