2014/06/12
Did you find the right rotation fix? I'd like to document this now.- Oma -
Yes. Here it is http://crewrktablets.arctablet.com/?wpfb_dl=1288
Problem with the battery I want to solve having booked a new battery from alixpress. Now I use SetCpu.
What can you say about KitKat for rk3066? Rockhip3066 no longer relevant, but people would like to still see 4.4
Not really a chance without having a 3.0.36+ kernel.
2014/03/15
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1819- Oma -
Well, it does NOT work for me. Wifi is not possible to switch on. It does not do anything if I tap it.
2014/03/15
Well... Sometimes it is just saying "Switching wifi on..." And nothing happens.
2014/03/15
In fact it is like this:
If I do Phalbet fix - tapping on wifi does NOT do anything
if I do Tablet fix - tapping on wifi will lead to never ending "Switching on"
You may missed that you have to change the boot.img, too. See post #23.
Documentation is also here: http://crewrktablets.arctablet.com/?p=1913
2014/03/15
You may missed that you have to change the boot.img, too. See post #23.Documentation is also here: http://crewrktablets.arctablet.com/?p=1913
Unfortunately not. I downloaded this file http://crewrktablets.arctablet.com/?wpfb_dl=1839 , unzip it and a file boot.img put in a rockdev folder (replacing the original one).
I did same with kernel.img (file http://crewrktablets.arctablet.com/?wpfb_dl=1820).
After it I ran RKDevelop_Tool, erase IDB first. When booted in CWM, wipe/reset factory setting and installed this: http://crewrktablets.arctablet.com/?wpfb_dl=920 (NAND_fix) and this: http://crewrktablets.arctablet.com/?wpfb_dl=1819 (model fix) and this: Â http://crewrktablets.arctablet.com/?wpfb_dl=1288Â (as per post 31)
What I am doing wrong?
2014/03/15
Hi Oma!
I have tried about 3 times to flash it, again but no change. Everything is ok but wifi does NOT work. Any advice, help for me? What I am doing wrong?
Thanks a lot in an advance
Boot tab fresh, enable/disable Wlan a few times and do a dmesg log.
2014/03/15
<4>[ 16.587235] Current WiFi chip is MT5931.
<4>[ 16.629346] wlan: Unknown symbol rfkill_unregister (err 0)
<4>[ 16.635288] wlan: Unknown symbol rfkill_destroy (err 0)
<4>[ 16.635332] wlan: Unknown symbol rkwifi_set_firmware (err 0)
<4>[ 16.635482] wlan: Unknown symbol rfkill_alloc (err 0)
<4>[ 16.635552] wlan: Unknown symbol rfkill_register (err 0)
<4>[ 16.635611] wlan: Unknown symbol rkwifi_set_country_code (err 0)
Pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2200
2014/03/15
Oma! It works!! You are genious!! Really!! I am so glad!! What was the problem?
Anyway... One step to be perfect... It looks like the icon for a strengh of a signal is stucked to 100%. It is always full no matter how the wifi signal is strong. But... It is really a small thing and not important.
Oma, thank you a lot! You are really brave!
The wifi module wasn't loaded. I don't think I can correct the overlay issue in the wpa_supplicant.
Enjoy!
44 Guest(s)
Devices in use: Desktop (36), Phone (8)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
