CM10.1 has landed on Prestigio PMP5780D
Le-Wiza
Forum Posts: 18
2014/06/15 - 14:53
Try this build: http://crewrktablets.arctablet.com/?wpfb_dl=1041
nothing has changed with this build
Le-Wiza
Forum Posts: 18
2014/06/15 - 15:36
Just guessing ... try this fixes:
http://crewrktablets.arctablet.com/?wpfb_dl=988
http://crewrktablets.arctablet.com/?wpfb_dl=987
Not changed
2014/06/15 - 15:38
Ok, then we do not have a chance without changing the kernel. Sorry.
Le-Wiza
Forum Posts: 18
2014/06/15 - 16:21
Why?Frown Maybe it is possible to still fix it? This last problem.
About WiFi you also said that you can not fix it, and yet fix...
Le-Wiza
Forum Posts: 18
2014/06/15 - 17:08
One person with same tablet, wrote that he entitled to some kind of line in init.rc, which boot.I'm, tried to contact him, but he does not respond
2014/06/15 - 17:37
Flash back (incl. eraseIDB) build v1.3.5 incl. this boot.img: http://crewrktablets.arctablet.com/?wpfb_dl=1839
Le-Wiza
Le-Wiza
Forum Posts: 18
2014/06/15 - 19:16
Thaks, it's workLaugh I have few questions:
  • Why paragraph battery consumption statistics are not displayed?
  • Fixes of rotation a many and so I ask: What you need to install fix to fix it? This screens are some examples of artifacts when the screen is rotated
2014/06/15 - 19:26
Fine.
Comsumption by app is not implemented in google code.
Build v1.3.5 have no rotation artifacts. Pls check the build.
If the screen is not in the right orientaion check out the rotation fixes, starting with fix 1.
Le-Wiza
Forum Posts: 18
2014/06/18 - 19:31
No, you probably do not understand. I have a problem with this:Screenshot_2014-06-18-20-25-06.pngImage Enlarger
2014/06/18 - 19:34
Yes, it is not implemented.
Le-Wiza
Forum Posts: 18
2014/06/18 - 19:44
OK... Can you tell me any good tweaks for battery life and performance?More interested tweaks battery life, because the battery is bad, even stock. Another this:
ro.rill.disable.power.collapse=0
pm.sleep_mode=1
he.nothing=true
Le-Wiza
Forum Posts: 18
2014/06/19 - 13:38
Small question: Do you plan KitKat for RK3066?
2014/06/19 - 15:25
Did you find the right rotation fix? I'd like to document this now.
Do not think too much about akku performance. The tab is old, so the akku. Charge it, use it and enjoy.
Currently Online: Daryel
94 Guest(s)
Devices in use: Desktop (86), Phone (8), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
