GoClever Tab R974.2 problem with Oma CM10.1 v1.3.30
Brightness, touchscreen
Alucard1989pl
Forum Posts: 21
31
2013/11/22 - 21:39
OK brightness controler already fixed but i can't still fix external sd error mounting on cwm and rom. After 4-5 reboots my tablet can read external sd. i changed vold.fstab from stock 4.1.1 aosp rom but it doesn't fix my problem. Fix for sdcard rw already installed. Another bug is battery usage data. i installed fix but i still get battery usage data isn't available. I must change some scripts on boot.img ramdisk?.
32
2013/11/22 - 22:15
Instal with stock recovery first: http://crewrktablets.arctablet.com/?wpfb_dl=1036
Alucard1989pl
Forum Posts: 21
33
2013/11/22 - 22:18
I doesn't work for me ... i tould you on xda.
Alucard1989pl
Forum Posts: 21
34
2013/11/23 - 13:12
I almost fix my problem with mounting external sd (it's now mounting after every 2nd restart) and usb mass storage(In mass storage i can explore on my PC only externalsd not externalsd and sdcard as stock rom. It's always happen when externalsd is mounted correctly on my tablet) . I want to now fix battery usage data. I decompiled classes.dex from services.jar and i want to know which smali file/s respond to correclty battery usage data information on settings.
96 Guest(s)
Devices in use: Desktop (81), Phone (15)
heftpflaster
rk.13
