GoClever Tab R974.2 problem with Oma CM10.1 v1.3.30
Brightness, touchscreen
Alucard1989pl
Forum Posts: 21
2013/11/18 - 15:53
@DmlC which sensor fix did you use and which hwrotation you set in build.prop 180 or 90?.
DmIC
2013/11/18 - 16:03
I don't use hwrotation because it change orientaion only for display, not for touch. About fix - I downloaded all of them and tryed one by one.
Alucard1989pl
Forum Posts: 21
2013/11/18 - 16:10
@up eekh ... i thought it change multitouch too not only screen orientation.
2013/11/18 - 16:51
Do not use build.prop commands as they will not work in the CM10.1 build.
So, setting ro.hwrotation is your touch problem.
@DmIC: can you pls link the right sensor fix?
DmIC
2013/11/18 - 17:03
It is "sensor fix 2". What about global change orientation? GoClever put display upside down, so we have a problem - right position by gsensor but cameras work upside down...
Alucard1989pl
Forum Posts: 21
2013/11/18 - 17:31
I must use whrotation 180 in build.prop because front camera on stock rom is on top not at the bottom like in yours cm10.1. Any news about brightness control?.
2013/11/18 - 17:34
Ok, I see you like the reverted touch ...
For cam try the apk in post #21.
Alucard1989pl
Forum Posts: 21
2013/11/18 - 17:40
No, i don't like inverted touch screen, but must be fix for this ...
2013/11/18 - 17:43
Simple. Pls leave the build-prop untouched. Install sensor fix 2 and try the gallery.apk.
DmIC
2013/11/18 - 18:09
Thanks. Cameras are working correct. It is only one question - brightness
Alucard1989pl
Forum Posts: 21
2013/11/19 - 12:47
Oma7144 which file on boot.img, kernel.img or in system,etc from system.img respond to brightness control?.
2013/11/19 - 20:12
Can you pls test: http://crewrktablets.arctablet.com/?wpfb_dl=1227
Just flash (tick parameter and boot).
Alucard1989pl
Forum Posts: 21
2013/11/19 - 20:36
@up nope ... i doesn't work.
Alucard1989pl
Forum Posts: 21
2013/11/22 - 10:27
Any news about brightness controler?.
Currently Online: swan12
87 Guest(s)
Devices in use: Desktop (76), Phone (11), Tablet (1)
swan12
heftpflaster
