2013/12/26
Hi OMA!
I need you help, i am began porting http://crewrktablets.arctablet.com/?p=1727 to my GoClever r83.2.
Kernel.img from your CM 10.1 firmware. All is good, but not working Wi-fi, Bluetooth and camera.
Your CM10.1 4.2.2 worked fully is OK.
Please help me.
Stock firmware - http://www.mediacomeurope.it/ZeusInc/PressRoom/Documents/875S2new.zip
Please make FIX for my device...
UDP: on http://crewrktablets.arctablet.com/?p=2315 wi-fi is work. BT and Camera not working
2012/11/19
You need a specific kernel for your device. If you use the Odys Genio kernel.img it would only work with your tablet if the tablet is a clone of Odys Genio.
Try the Rom with this kernel:
2013/10/12
JochenKauz said
You need a specific kernel for your device. If you use the Odys Genio kernel.img it would only work with your tablet if the tablet is a clone of Odys Genio.Try the Rom with this kernel:
is this a 3.0.36 kernel???
2012/11/19
No, I think 3.0.8.
82 Guest(s)
Devices in use: Desktop (70), Phone (12)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
