2014/07/14
Hello, i hope i can get some help here. More from a mistake i flashed the AOSP 4.2.2 in my old ionik grey metal 10.1. I was really surprised how fast it is running ,even with many installed apps. Great Work!!
The only prob i have is with bluetooth. I cant activate it for long and it didn t find any other device.Then the slider in the settings area greys out and deactivates by himself
I used the original kernel and stock recovery for the install.It would be great if anyone has an idea how to fix it.
Pls upload a dmesg and a logcat log.
2014/07/14
Hello OMA,
i hope i did that correct...had to upload it to dropbox https://www.dropbox.com/sh/twh1cnnsnt63283/AAB6RJnsTxBXM0D78qz5-iema
Ok, RK903 wifi/BT:
<4>[Â Â 49.383452] Current WiFi chip is RK903.
<4>[Â Â 50.002345] FW_PATH = /system/etc/firmware/fw_RK903.bin
<4>[Â Â 50.002351] NVRAM_PATH = /system/etc/firmware/nvram_RK903_26M.cal
<4>[Â Â 50.031915] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
<4>[Â Â 50.033519] Fianl fw_path=/system/etc/firmware/fw_RK903b2.bin
<4>[Â Â 50.033531] Fianl nv_path=/system/etc/firmware/nvram_RK903_26M.cal
In the stock firmware there are a few other libs active. Could be very complicated to implement that.
Can you try the CM10.1 build, this was confimred working: http://crewrktablets.arctablet.com/?p=1913
2014/07/14
Thx for the help. I have allready tried the CM10.1 build, it was running very fast in the first days but when i had installed all my apps(round about 60),it was running slower and slower.
So, i think i will run the ASOP without  BT, while its responding much more smooth.Thx again for your effort
78 Guest(s)
Devices in use: Desktop (66), Phone (9), Tablet (3)
melcis
nelcis
sophiajohnson87
Brainticket
mogabi
ryb84
