custom rom and firmware flash for point of view pro tab 3xxl
wess
Forum Posts: 15
2014/08/02 - 16:54
Hello! ,
I have a point of view protab 3xxl v1.2 , my current stock rom is very bad (lags , malfunctions....) i want to change its rom to a new good custom one the problem is i'm a beginner at this so can anyone give me a good custom rom for the tablet and a step by step simple guide how to flash it , please my tablet is new and i can't even use properly
thanks in advance , good day 🙂
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/08/05 - 22:36
I don't know this tab, but I think it's better if I move you're post to a section of crewrktablet.
Oma should be able to help you.
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/08/05 - 22:40
I have found a german blog post that uses our Crew RKTablets Genio by Oma CM10.1 v1.3.5 on a ProTab 3 XXL.
But I have to ask two questions first..
You are sure that it is  v1.2?
And do you have the original stock rom, so you can restore original state?
wess
Forum Posts: 15
2014/08/07 - 02:48
thank you for your answer , yes i'm sure it's v1.2 and the i've looked in the manufacturer's site and the firmware i found is http://downloads.pointofview-online.com/TAB-PROTAB30-IPS10/TAB-PROTAB30-IPS10_V1.2_2013603.zip , the firmware is for upgrade that's all i could find
this is the page i found the link in http://downloads.pointofview-online.com/Tablets/10%20Inch%20Tablets/TAB-PROTAB30%20IPS10%20%28Protab3XXL%29/Firmware%20Upgrade%20Procedure%20PROTAB3XXL%20TAB-PROTAB30%20IPS10.pdf is that enough or i should look for an other one?
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/08/07 - 10:31
That looks for me to be the right firmware.
All upgrades mentioned above are full StockRoms and you will loose all data on your tablet.
This is normal and will also happen if you flash our CustomRoms.
If you never flashed a new Rom to your tablet, I think you should first try to upgrade to the latest StockRom for your protab following the upgrade instructions above.
This has 3 advantages:
1. You have installed the necessary drivers, this drivers have to be installed for our CustomRom too.
2. You know how to get the tablet in flashmode.
3. You know how to make a fallback in the case our CustomRom does not work as expected. You should never try a CustomRom without that knowledge!
wess
Forum Posts: 15
2014/08/07 - 13:51
Hello! ,
ok i'll follow the instructions and upgrade the tablet , i'll post the result in few hours
thanks .
wess
Forum Posts: 15
2014/08/08 - 05:12
Hello!
I successfully updated the tablet , so what's next?
good day!
wess
Forum Posts: 15
2014/08/09 - 20:27
so anybody? Oma , JochenKauz ...?
tekilakos
Forum Posts: 81
Thanks Received: 15
wess
Forum Posts: 15
2014/08/10 - 01:46
thanks tekilakos for your answer , i saw that topic that rom had many problems with the v1.2 w they couldn't fix it and then they changed the language and don't understand german that's the problem :/
Currently Online: djwood1014
74 Guest(s)
Devices in use: Desktop (57), Phone (18)
djwood1014
4ipolino
thomashansmuller11
abro
Yoyoo
sfaris
