2013/11/10
Hello all,
Could you please tell me if / what custom ROM 4.2.2 I can use for the below tablet ?
Model : iTAB 1012 3G ( as the name states - 3g modem Builtin )
The link for it : http://www.itab.ro/tablete-101-inchi/tablete-10-inchi-itab/tableta-itab1012-3g-pack1.html
and at "Specificatii tehnice" you will find its specs .
• CPU :1.6 Ghz, ARM Cortex A9 RK3066 Dual Core, GPU MALI400 MP4
• RAM : 1024 Mb
• Internal memory : 16 GB
Android version : 4.1.1
At about device I have :
- Kernel version :
3.0.8+
root@wzq-G41M-ES2L #454
SMP PREEMPT Sun Jan 6 17:15:17 CST 2013
- Build Number :
RK30_ANDROID4.1.1-SDK-V1.00.00
RK30XX-eng 4.1.1 JRO03H 20130129.151352 release-keys
Stock firmware : https://www.dropbox.com/s/iz075pnhq68cwk5/update%20itab1012%203g.img
Thank you very much !!
Build: http://crewrktablets.arctablet.com/?p=1913
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1184
Did you execute eraseIDB?
2013/11/10
Yes. I've executed EraseIDB , then RUN .
be aware: it is your own risk! Â
decompress with 7zip (change kernel in folder rockdev/Image)Â
copy format_NAND_fix (and other fixes) to sd-card
boot tab into flash mode
run RKAndroidTool as admin: EraseIDB, Run
first boot into CWM: install format_NAND_fix (and other fixes) from sd-card
reboot, wait 4 min
have fun!
I haven't run the format_NAND_FIX .... Is that mandatory ? Or should I retry the flash ?
Could be that eraseIDB was not successful. Try again and review that current counts up to 4096.
The format_NAND is necessary to format the user partitions.
2013/11/10
Tried already 2 times, same result
What I've done :
- Download CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3.7z
- Download RK30_kernel_308_1012_3g_itab.7z
- Replace kernel.img in \rockdev\Image
Run RKAndroidTool . EraseIDB -> goes to 4096 -> SuccessfullÂ
- RUN -> Everything ok
Reboots in CWM , apply Oma RK30 CM10.1 Format NAND.zip from SDcard , then reboot .
-> reboots again in CWM over and over again
I've attached the printscreen with the procedure I've done . Please have a look and advise .
Maybe the kernel.img is not the correct one , or ?
Kernel works. System is not properly on the NAND.
To verify pls do an update.img: http://crewrktablets.arctablet.com/?wpfb_dl=1048
2013/11/10
I've done this, but same results
D:\flo\CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3\rockdev>mkupdate.bat
D:\flo\CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3\rockdev>Afptool -pack ./ Im
age\update.img
------ PACKAGE ------
Add file: ./\package-file
Add file: ./\RK30xxLoader(L)_V1.34.bin
Add file: ./\parameter
Add file: ./\Image/misc.img
Add file: ./\Image/kernel.img
Add file: ./\Image/boot.img
Add file: ./\Image/recovery.img
Add file: ./\Image/system.img
Add file: ./\update-script
Add file: ./\recover-script
Add CRC...
Make firmware OK!
------ OK ------
D:\flo\CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3\rockdev>RKImageMaker.exe -R
K30 RK30xxLoader(L)_V1.11.bin Image\update.img update.img -os_type:androidos
Generating new image, please wait...
Writing head info...
Writing boot file...
Writing firmware...
Generating MD5 data...
MD5 data generated successfully!
New image generated successfully!
D:\flo\CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3\rockdev>rem update.img is n
ew format, Image\update.img is old format, so delete older format
D:\flo\CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3\rockdev>del Image\update.i
mg
D:\flo\CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3\rockdev>pause
Press any key to continue . . .
Afterwards I wrote the new firmware img using RKBatchTool.exe .
**********Upgrade Action**********
**********Upgrade Start Total<1>**********
<Layer 1-3> Test Device Start
<Layer 1-3> Test Device Success
<Layer 1-3> Check Chip Start
<Layer 1-3> Check Chip Success
<Layer 1-3> Get FlashInfo Start
<Layer 1-3> Get FlashInfo Success
<Layer 1-3> Prepare IDB Start
<Layer 1-3> Prepare IDB Success
<Layer 1-3> Download IDB Start
<Layer 1-3> Download IDB Success
<Layer 1-3> Reset Device Start
<Layer 1-3> Reset Device Success
<Layer 1-3> Wait For Loader Start
<Layer 1-3> Wait For Loader Success
<Layer 1-3> Download Firmware Start
<Layer 1-3> Download Firmware Success
**********Upgrade Done Success<1> Fail<0> Time<139282>ms**********
It goes in CWM Recovery -> I choose reboot system now -> again in CWM Recovery ...
OK, pls try with original parameter. Copy to /rockdev and do an update.img.
2013/11/10
I've done that, but nothing changed.
One question , where is this file used ? Because I don't see in the mkupdate.bat that file being used :
Afptool -pack ./ Image\update.img
RKImageMaker.exe -RK30 RK30xxLoader(L)_V1.11.bin Image\update.img update.img -os_type:androidos
rem update.img is new format, Image\update.img is old format, so delete older format
del Image\update.img
pause
Also, I see it is using the RK30xxLoader(L)_V1.11.bin , but in the .img it is adding the 1.34 :
—— PACKAGE ——
Thank you again for your support and time !
Hm, make update.img fails. Anyway.
Flash stock firmware first. If this works then flash CM10.1 with RKAndroidTool with this parameter: http://crewrktablets.arctablet.com/?wpfb_dl=934
2013/11/10
I've flashed with the stock firmware and it is working again .Â
Could you please guide me step by step ? Just to be sure that I'm not doing anything wrong . SO :
What do I do next ? Where do I place / replace the "parameter_kernel 16kb" file ?
Thanks !
Unzip and copy parameter to folder /rockdev. Then run RKAndroidTool acc. to instrections.
72 Guest(s)
Devices in use: Desktop (60), Phone (10), Tablet (2)
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
THEDRACk
