2012/11/19
first step to get such a kernel would be to provide a dmesg and detailed specs of the tablet, then we could look at this and could try to find a config for it.
galgofa, user_mPer aspera ad astra, we rock the Tablets !
2013/03/26
Thank you for reply. Here is th dmseg and link to foum thread here.
2012/11/19
You could always try our CM10.1 build. Only thing to change is the kernel.
To get a custom kernel running is a little bit more complicated. I will look at the dmesg above,.
But keep in mind, our CM10.1 does not need a custom kernel, it should run with every 3.0.8 stock kernel.
Problems are always, the touch and the sensors, but we could try to fix it. Yous should have a StockRFom for flashing back before you try this.
2013/12/15
Hi All!
I try to build kernel for U9GTV from https://github.com/crewrktablets/rk30_kernel
with rk30_hd1_defconfig.
Kernel build successful. And boot successful.
But... display not working... I can connect via adb.
And this tablet have it display.
2012/11/19
Hmm... thats complicated.
Only to know the the real name of the display does not mean that the driver is working for it.
2012/11/19
Looks interesting, I think that one of the parameters of the screen drivers is wrong.
Could you please upload the driver file, so I can look at the content?
vm03Per aspera ad astra, we rock the Tablets !
2013/12/15
Screen driver: https://github.com/crewrktablets/rk30_kernel/blob/master/drivers/video/display/screen/lcd_LP097QX1.c
I don't change it.
I can upload my diff's. But, I basically changed config, Kconfig's and Makefile's.
2012/11/19
Would be nice to see your other changes..
Okay... I have looked at the driver and perhaps I have found your problem..
Look at the Line with:
#define H_FP 150
This is the right margin of your display, perhaps you can change it to higher or lower value and it helps.
2012/11/19
hmm.. not easy I think.
what happens if you change the left offset of the screen (h_PB)?
I think this is a trial and error situation. There are a few parameters to play with..
screen->left_margin = H_BP;
screen->right_margin = H_FP;
screen->hsync_len = H_PW;
screen->upper_margin = V_BP;
screen->lower_margin = V_FP;
screen->vsync_len = V_PW;
I'm sorry that I can give no better advice, you are the only one who could play with this defines.
2013/12/15
I created fork for my work on github. https://github.com/vm03/rk30_hd_308_kernel
76 Guest(s)
Devices in use: Desktop (65), Phone (10), Tablet (1)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
