CUBE U9GT4
Jelly Bean 4.2.2 and CM10 and CM10.1
Ashish
Forum Posts: 23
2013/09/12 - 16:39
   I installed "Oma RK30 3.0.36+ CWM" (http://crewrktablets.arctablet.com/?wpfb_dl=682), it works. All functions work. I flashed CM10(from another site thaiscopad.com) using this recovery and the CM10 was flashed correctly and it worked.
   BUT when I downloaded CM10(Oma Odys Genio CM10) from YOUR site(http://crewrktablets.arctablet.com), it did not work(tablet does not start).
   ALSO JB 4.2.2 ROMs are not working(tablet does not start). Can you build or tell me what should I do to make it work on my tablet? ... ... ... Thanks  🙂 :)
    ( I think 3.0.36+ kernel is working on my tablet because "Oma RK30 3.0.36+ CWM" is working. )
netlars
Forum Posts: 149
Thanks Received: 29
2013/09/13 - 13:01
Do you use the right kernel?
Please describe your problem.
The following users say thank you to netlars for this useful post:
Ashish
Ashish
Forum Posts: 23
2013/09/13 - 13:51
I downloaded Following ROMs from crewtablets.arctablet.com
1)CrewRKTablets_RK30_Genio by Oma_AOSP_4.2.2_20130518
2)CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.2.1
3)Oma_Odys_Genio_CM10_v1.2
4)Oma_Pipo_M1_JB_v2.4
 I flashed using the RkDevelop tool provided with these ROMs. But after flashing my tablet does not start. Nothing appears on the screen. My tablet is "CUBE U9GT4".
Ashish
Forum Posts: 23
2013/09/13 - 14:12
The problem is "Tablet does not start, nothing appears on the screen, screen is black, no boot animation, nothing .... ....". I used the kernel which was inside the zip archives of the ROMs ( I mentioned above i.e 1, 2, 3, 4).
netlars
Forum Posts: 149
Thanks Received: 29
2013/09/13 - 14:56
Ashish
Forum Posts: 23
2013/09/13 - 15:25
       Hey netlars, what happened? Why did you repeat my post? ... ... ... You did not like my post?
netlars
Forum Posts: 149
Thanks Received: 29
2013/09/13 - 15:45
Sorry I'm quote  your post, but lost my answer.
Replace the kernel in this packages with your kernel from U9GT4.
The kernel in this packages are for Genio.
Ashish
Ashish
Forum Posts: 23
2013/09/13 - 16:39
       My U9GT4 has kernel 3.0.8+ and android version 4.1.1. Will this work for JB 4.2.2 and CM 10.1 OR it will ONLY work for CM10?
      Thanks for your replies and support ... ... ... :) :)
( I am trying first "CrewRKTablets_RK30_Genio by Oma_AOSP_4.2.2_20130518" and will tell you if it works, in few minutes. )
netlars
Forum Posts: 149
Thanks Received: 29
2013/09/13 - 20:28
Kernel's work in all versions.
ser63
Russia
2013/09/22 - 11:56
Ashish, CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.2.4 working on my u9gt4 with stock cube kernel.
2013/10/12 - 21:06
Can you pls upload the kernel for the archive? Many thanks.
ser63
Russia
2013/10/18 - 13:35
Bugs:
camera is turned on 180°
artifacts when the screen is rotated
ser63
Russia
2014/02/01 - 14:37
Hi, who can port 3.0.36+ kernel to this crap tab? I try to compile from https://github.com/crewrktablets/rk3x_kernel_3.0.36 sources with odys genio defconfig, but tablet does not start.
JochenKauz
Forum Posts: 450
Thanks Received: 76
2014/02/01 - 15:34
You need the exact specifications of your tablet to compile an own kernel.
And with exact specifications I mean you need the internal kernel config, GPIO's, battery tables, I2C configuration and so on.
Without such knowledge it is impossible to build a working kernel.
57 Guest(s)
Devices in use: Desktop (46), Phone (11)
cutierogue
