Cube U30GT-H AOSP JB 4.2.2 testing
Testing of AOSP JB 4.2.2 on rk30board from http://crewrktablets.arctablet.com/?p=784 on the Cube U30GT-H. What works, what does not, and which fixes to install.
shadoweel
2013/11/05 - 13:56
I got myself a U30GT-H and want to share my experiences of it with various roms. While CM 10.1 is newer, it is functionally inferior to this image, see http://www.arctablet.com/blog/forum/crewrktablets-rk3066-entwicklung-customroms-development-croms/cube-u30gt-h-cm10-1-testing/.
What to install in the image:
What to install in CWM:
What works:
  • Hardware accelerated video playback 1080p
  • Wifi
  • Bluetooth
  • SD Cards
  • HDMI settings out of the box
  • Most other day-to-day functions
What does not work:
  • Device encryption (not even enabled)
  • WiFi ad hoc networking
Other thoughts:
  • There are quite a lot of unnecessary personalization, apps and tweaks that could be installed separately as users see fit
    • Gapps
    • AdAway
    • Awesome BEATS Audio
    • Bluetooth file transfer
    • Bluetooth GPS
    • Chrome
    • Fresh networks
    • Kernel tuner
    • MX Player which works well (arguably needed but still requires separate installation of codec)
    • Nova Launcher, alongside AOSP Launcher
    • Skype
    • USB Host Controller
    • Volume+ FREE
    • Some other less intrusive apps that you can find under Settings-> Apps -> All
  • Beyond that, some tools of choice for arguably necessary system operations are installed
    • RebootMenu, to enable rebooting to recovery which is not available in the Power menu
    • File Manager HD, as the only file manager
The following users say thank you to shadoweel for this useful post:
ri9000
2013/11/05 - 14:38
Thanks for this great summary shadoweel.
I'm planning to make an "update.img" style update of this firmware to make the installation process a little easier for those not familiar with CWM, also thinking about leaving only the necessary apps, the rest could be downloaded from Google Play Store.
shadoweel
2013/11/05 - 15:16
Sounds great!
I also noted that having extra apps that do not have Google Play packages installed in system, will effectively block them from being updated with F-Droid and other repositories. This is due to the fact that the app would need to be uninstalled first because it has a different signature, and uninstalling is not possible as it is installed in system.
In this image, AdAway and TalkBack fall into this category.
Now, if only there was some way to enable device encryption in the image it would be pretty much complete...
85 Guest(s)
Devices in use: Desktop (60), Phone (25)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
