2013/02/12
Hi, i am familiar with rkflashtool and adb commands and so on and i decided to try your latest 4.2.2 build for RK30 based tablets, but i dont know how to do it.
I tried RKAndroid tool with the latest 4.2.2 cROM, but the screen was out of display and colors were awfull so i decided to try the 10.1 voyager kernell, then the 308 u30gth kernel but still with the same output.
But i can allways go to recovery you provided in the CROM (6.0.3.1).
so what exatly i have to flash to get the 4.2.2. cROM work on my cube U30GT-h?
thanx a lot for your reply.
Please replace the kernel.img in the folder rockdev/Image with your kernel from tablet.
The following users say thank you to netlars for this useful post:
cappybobnetlars
2013/05/22
Have had success running both 4.2.2 builds (AOSP & CMOD) on my rk30 cube 30. Trying now to add (ad _hoc support) to either build with no success. Just out of curiosity, has anyone else had success in this adventure. By the way THANKS to the Crew at RKTablets for their efforts and knowledge. Thanks to Netlars and Oma for their dedication.
cappybobPer aspera ad astra, we rock the Tablets !
2013/05/22
Good Evening OMA. This is the posted adhoc that has been around. I've tried it, maybe I have not done it properly. I have tried an ABD push, CWM ext-sd (not from a download int), su, and have not done a busybox yet. As far as trying, I am game, retired, and enjoy trashing systems, why I LUV LINUX.
cappybob - You don't own it until you break it.
2013/05/22
Added the supplement.zip through external/sd and internal download with system folder set to r/w, the installs was the same result. There was an install though: the macaddress is "00:00-------". Now where do we go. Tried to enter the adhoc in as static and dhcp,  no luck either way. I think here is where I am screwed up.  Thanks for your assistance in this matter. Let me know if you want to try differently.
 Did another install after rebuild with the etc/system set at r/w. lost scan capabilities. Still have wifi if manually entered, but adhoc not yet. Changed kernel to 308 only this build, previous builds were 3066 and 308.
Rebuilt reinstalled again, right this time , but not working. Looking for adhoc supplement, instead of new wifi supplement. Macaddress (00:00:----), new wifi supplement installed, scan, and wifi working correct, but sadly no wifi adhoc in scan. Tried static no help there either. Don't worry about rebuilds, it keeps me off the streets.
2013/02/12
thanx Cappybob and netlars now i have the omas AOSP 4.2.2 latest build working (i had the wrong kernel replaced in the install zip). But now when i connect my cube to the pc i cant access neither the tablet flash or the sdcard. My hardware manager says that two "OMA_USB_USB_device"s are loaded, but it says that there are empty(i cant see the disks in "my computer" and wincommander sees the two drives but cant access it). When I unplug my scdacrd from tablet and connect it with my PC I can normally access it.
p.s. i accidentally installed also the second fix, which wasnt mentioned in the instructions file from here http://crewrktablets.arctablet.com/?m=201304 (intSD_to_NAND_fix).
2013/05/22
Yo Dallas just checked mine and same here, working on something else (adhoc). I have noticed that there are exactly 3 different usb drivers. the systemui (which is disabled) think because of the unrecognized format. The Nexus 7 drivers and finally Oma usb. I have had it working off and on but forgot how. Checked systemui app and it is out of service. I believe this is where the problem is. At a loss right now, but want this to work for sure.
2013/05/22
Dallas, found It . Go to settings, tap storage, plug in usb to computer and tablet, tap upper right corner to get usb computer connection, tap (MTP), goto computer screen and get busy. Haven't figured the what is going on here, but will try the ext_nand fix, next to see if all shows as nand. Will do later today for will rebuild to cmod10.1 to check if I can get to adhoc today. But your files will be there in nand.
107 Guest(s)
Devices in use: Desktop (95), Phone (12)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
