2014/11/02
After CM10.1 I reflashed the tablet with AOSP 4.2.2, flashing the boot.img and system.img, and formatting the necessary nand partitions. Again I needed to install the CM10.1 model fix for PMP5880D to fix touch and wifi. With the original installation the screen is always upside down.
USB 3G works with AOSP 4.2.2, while it didn't work with CM10.1.
However I ran into problems with the screen rotation fix. The same fix that worked on CM10.1 doesn't work the same way on AOSP 4.2.2. After installing the same fix that worked on CM10.1, the screen is always off by 90 degrees no matter how I rotate the tablet, e.g. I can read the tablet if I turn my head to the left by 90 degrees.
I've tried all the other screen rotation fixes, and none of them solved it, one was close, if I held the tablet portrait, the screen was ok, but not in landscape mode.
I installed the sensor analyser, and androsensor. What data should I provide? Should I screenshot? Or photo the whole tablet?
Thanks for the help.
Where can I find the stock rom?
2014/11/02
The stock ROM for this tablet:
Thank you for your help.
Pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2255
2015/06/30
Hello i downloaded aosp 4.2.2 and i did try to do like instructions say but it doesnt work as my win 8.1 refuses to install drivers, so how about this if its possible.
As I have cwm on tab can i flash trough it pmp7280c nand format fix
Then to put all imgs from aosp in orginal update zip and again flash trough cwm?
Doesn't work this way. Here is the latest Driver Assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2398. It includes a Win8.1 usb fix.
If it still doesn't work use a PC with win7.
2015/06/30
Doesn't work this way. Here is the latest Driver Assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2398. It includes a Win8.1 usb fix.If it still doesn't work use a PC with win7.
hay again.
I dont know if i'm doing something wrong or not but damn thing doesnt wanna work.
I power off tablet and press vol up button then I connect it to pc and nothing happens, if then i press power for secondÂ
i hear sound in win like i hooked something but still drivers dont recognize that as RK3066 it say unknown device, tryed that multiple times.
but when i try again vol up + power tablet goes in CWM but there my pc recognize device as RK3066 but neither RKdevelop tool or batchtool recognize device.
I tryed this on win 8.1 with drivers given then i Installed win 7 in Virtualbox and tryed again with no success.
so can you please verify that im trying to get update mode right way
ofc tab is PMP7280c rooted+cwm stock wich is damn laggy and not enough space  for apps as it takes portion of storage 5gb and uses that as virtual sd..
what can I do to flash that AOSP
Thank you
Do you have the power supply plugged? Starting the CWM is the same key combination without all cables plugged.
Win7 in a Virtualbox won't solve the driver issue. I guess you can find a PC with Win7.
2015/06/30
Do you have the power supply plugged? Starting the CWM is the same key combination without all cables plugged.Win7 in a Virtualbox won't solve the driver issue. I guess you can find a PC with Win7.
Sorry for that i forgot to mention this tab doesnt have power cable separate it has only one micro usb that serves as power and connection point to pc.
Well as win 7 pc goes i really unlucky atm as no one oround me uses win 7 everybody on 8.1 lol.
If i dont manage to do it this way ill pobably do dual boot win 7 on my pc but i just cant do it now maybe in few feeks when ill have more time.
Thank you for fast repys and all your help.
2015/06/30
Hay again im putting it here as its abot pmp7280c
I failed to put AOSP 4.2.2 on it
After while i did manage to install win 7. I did install drivers and rkflash recognized my tab everything ok there but when start clearing everything goes well then when it starts flash first i think it flashes system as its the biggest file check i seen?? And everything goes well there but after that it says error failed..
I tryed like few times and i think its boot.img , misc.img or partition file i dont know wich it fails.
I did replace kernel as in instructions. So any idea what im doing wrong? Or should i try as first post with cm then flash aosp just kernel and system.
Oh yea almost forgot i get to recovery but it is size of half screen and all messed up. Whatever i do it cant mount chache, sdcard.. But it mounts external sd.
2015/06/30
Few days later i managed to install CM10.1 instalation goes flawlessly but after applying all fixes only
thing that is not working properly is locscreen its allways turned that way that power and vol buttons have to be down facing me or ground, when im turning tab its allways in same position. But when i unlock it everything is ok.Â
I dont know why only thing is that i see icon for signal bars and this is not tab with sim support so that could be a battery drainer.
On AOSP front i managed to install it finnaly in that way that i only copy boot.img and system.img to cm flash files
But it has little more issues it feels better then cm but whatever fix i apply it has no free space on internal storage and it mounts ext sd to nand and virtual sd to sdcard so i cant install any apps i did try to put cm vold.fstab file in aosp and reboot it didnt help.Â
Is there a way to repair aosp as it just feels lil more polished and better?
 Edit: i try to make aosp backup so i can flash it without pc but backup faild as it said there isnt data partition and cwm allways logging no chache partition .
Edit2: flashing ver 3.3 goes with no problem but still same issue with fixes flashed no internal memory or chache. Can't install anything. Â
Flashed fixes are nand format. Tab fixes and kernel.img replaced.
Thank you
In CM builds you can rotate lock screen separately via setting.
Don't mix up things, use the packs as they are. Change the kernel and install the fixes.
If you have issues formatting the NAND pls use the generic stock recovery (link see here) first.
70 Guest(s)
Devices in use: Desktop (64), Phone (6)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
