2013/11/20
I love using this version of CM on my tablet. Everything works well except for the internal storage.
I seem to have a strange situation regarding the internal sd. It works perfectly well in recovery after runing cm10.1 nand fix but when running on cm10.1 the card appears for a second and then it dissapears in which then system tell me the the sd is ready to be removed.
Can someone please help me fix this problem.
Thanks in advance.
The model with a 3.0.8+ kernel?
2013/11/20
Hi Oma,
Thanks for the reply. My kernel is 3.0.36 and im currently using the one from the crewrktablets website. The boot.img is from my stock firmware and the recovery is cwm 6.0.3.1 from crewrktablet website too. the rom that actually using is Oma_RK31_Chuwi_V88_CM10.1_4.2.2_v1.2.3.
Ok, fine. 3.0.36 kernel on rk30board will need the rk31 build.
Mounting in the stock boot.img is different. That's why you have problems with the sdcard.
Use the rk31 build as it is.
2013/11/20
Wow, you are amazing. You fixed it! I have been searching for the solution for days.
Thank you so much!!!
By the way, are you able to also help me fix a com.phone.android error regarding CrewRKTablets_RK30_Genio by Oma_CM10.1_v1.3.3. This rom would work great if you can help me fix this problem.
Thanks again
Which tab? What is the story "behind" that error?
2013/11/20
Its for my tablet sumvision cyclone voyager 8. I used crewrktablet kernel 3.0.36 for voyager 8, tried to use my own boot.img also used cwm 6.0.3.6. Im wondering, is it because im using my boot.img again?
When the tab has completely booted a "com.android.phone has stopped working" message appears. I have tried everything to get rid of this error.
That's what I said before, the rk30 build will not work on a 3.0.36+ kernel.
motionatPer aspera ad astra, we rock the Tablets !
When you flash stock recovery it will format the user partitions. So internal SD should be there.
You can afterwards flash the recovery.img (CWM), which comes with the pack. Just tick parameter und recovery.
81 Guest(s)
Devices in use: Desktop (76), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
