Is a stock firmware available?
sebiks, EligosPer aspera ad astra, we rock the Tablets !
Ok. Please upload boot.img and kernel.img. I will check.
sebiksPer aspera ad astra, we rock the Tablets !
2013/10/14
here is https://docs.google.com/file/d/0BzVY3gkGHSWjMTFrRmVLS0VHYkk/edit?usp=sharing
and thanks for your support
Ok. Kernel 3.0.36+ NTT 528 is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1007
It is bigger then the 8 KB standard so use this parameter: http://crewrktablets.arctablet.com/?wpfb_dl=934
Due to the 3.0.36+ kernel we have to use a test build first: http://crewrktablets.arctablet.com/?wpfb_dl=868
Download the pack and change kernel and parameter. Flash acc. to instructions incl. eraseIDB.
2013/10/14
Ok. Kernel 3.0.36+ NTT 528 is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1007It is bigger then the 8 KB standard so use this parameter: http://crewrktablets.arctablet.com/?wpfb_dl=934
After flash im geting error from CWM
"E:Invalid command argument
e:Cant't mount /cache/recovery/log
e:can't open /cache/recovery/log
e:can't mount /cache/recovery/last_log
e:can't open /cache/recovery/last_log
Asfter CWM>reboot now, tablet stuck at ntt logo.
CWM can't load log from last run, because it is not there.
Wait a bit for boot-up. If tab hangs reset and boot again.
You need also to replace parameter in /rockdev.
Hm, maybe there is a mismatch in the parameter.
Try again with this one, incl. eraseIDB: http://crewrktablets.arctablet.com/?wpfb_dl=1008
2013/10/14
Hm, maybe there is a mismatch in the parameter.Try again with this one, incl. eraseIDB: http://crewrktablets.arctablet.com/?wpfb_dl=1008
Do I need to flash loader?
No. One time is enough.
Loader is ticked by default to make sure you have the latest version.
90 Guest(s)
Devices in use: Desktop (81), Phone (9)
hans41
rickybk
soniya07
ironmangitar
