I think also,
hostapd, hostapd_cli, chat.
libreference-ril-xxx.so is for internal modems.
I working, to add our Images.
Comming soon.
netlars
Just to wrap-up this here. Having wifi issues with above provided solution.
This works with me: http://crewrktablets.arctablet.com/?wpfb_dl=1242
2013/10/21
no problem with wifi for me what did you changed else that me ?
btw. for me without bin/chat file it dosn't work, strange
btw. 2 - i think you hade wifi problems becouse perrmisions for /system/etc/dhcpcd/dhcpcd-run-hooks when i have installed my fix this perrmisions have changed, and i must made chmod 755 i have add this to update script and it is ok
Rights are there. rild3 kills my wifi. chat has no effect so I put it in the fix now.
Can you pls test?
2013/10/21
add this permissions and it will work:
set_perm(0, 0, 00755, "/system/etc/ppp/ip-up");
set_perm(0, 0, 00755, "/system/etc/ppp/ip-down");
set_perm(0, 0, 00755, "/system/etc/ppp/call-pppd");
set_perm(0, 0, 00755, "/system/etc/ppp/ip-up-vpn");
btw. i have rk30 not rk29 i don't know if it changes anything.
OK, now with rild3 and permissions on /ppp: http://crewrktablets.arctablet.com/?wpfb_dl=1242
Seems to work fine now. Which rk device doesn't matter
So, that means the fix works with you?
Can you pls test this fĂĽr the battery-info: http://crewrktablets.arctablet.com/?wpfb_dl=1231
RyrzyPer aspera ad astra, we rock the Tablets !
2013/10/21
yep... it works (3g fix) and battery info fix not
i found something like this: http://dragondevs.com/index.php/topic/1398-fix-for-battery-usage-data-isnt-available/Â i didn't try this, but it is only settings.apk, maybe you will find something there
About 5% of the tabs (mostly yifang) have this issue. Our tabs are all fine.
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1231
106 Guest(s)
Devices in use: Desktop (86), Phone (19), Tablet (1)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
