I can mount and unmount my SD-Card without this fix.
Are there any news regarding the mobile data?
netlars
ok, I will test it.
Good luck with mobil data, and please give response.
netlars
2013/10/21
ok, a short summary
Bugs that i still have:
- mounting internal storage as mass storage on PC not working, only external SD is mounting,
- glitches on screen rotation (i use sensors from stock 4.1.1 ROM),
- 3G modems can't connect via android settings, signal indicator works, when i connect via ppp widget it works, signal indicator is blue and there is connection speed letter (E, 3G),
- no battery stats in Settings->Battery,
2013/10/21
problem with mounting internal storage as mass storage is related with "init" from boot.img, when i replace init with init from stock boot.img all storages are mounted ok as mass storage on PC ... BUT (always a 'but'..) storages are not mounted in tablet... i have no acces to them ;/ grrr any idea ?
maybe i will send my stock boot.img to you Oma and you will look at this ? can you do this ?
init or init.rc or init.rk30board.rc ?
At evening I looking that.
The following users say thank you to netlars for this useful post:
Ryrzynetlars
Is this path there? /sys/class/power_supply/battery/capacity
2013/10/21
@netlars
finally i got working 3G connection without 3th party apps like ppp widget !! haaa there is only one bug... when you change something in apn list you must reset device to make changes one more time
but this is not so bad
once you select you apn you do not have made nothing there until you change network sim
aaand this "fix" fixed my mass storage mounting !! and now i have internal and external mass storage on my pc !!!
how did i made this ? I have installed your aosp ROM to look how it works... and i have connect modem... taaadam... and it works... ! i took out files that i think that they are related with ril and copy to cyanogen mod and it work and both mass storages are working now
(this is i think related to bin/vold file).
files that i have used (i think that not all are necessary )
71 Guest(s)
Devices in use: Desktop (65), Phone (6)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
