2013/10/21
hi all,
i need some help
I try to port RK30 Genio By Oma CM10.1 1.3.2 for my RK30 prestigio pmp5870c and for now i have working camera, accelerometr sensor (rotation works ok,) the problem is with wifi and storages, wifi don't work never (look at dmesg, modules i think are ok) and sdcard and build in memory are not working (once time they where active and they work, i dont know how did i do this )... but when i connect tab to pc i can mount sdcard as mass storage... strange...
I use stock 4.1.1 kernel from this device, maybe this is the problem ?
I had test old cm10 4.1.2 roms and when i use modules from stock ROM the wifi was working ok...
here is dmesg:
if somebody can help it would be great
btw. sorry for my poor english
2013/10/21
another try to make wifi work
E/wpa_supplicant( 1934): wlan0: Unsupported driver 'nl80211'  this is strange... wifi still not working.... maybe the problem is with BT (prestigio dont have bt)....
second problem - internal/external memory... still not working... sometime i see them, they work, sometime (most) not ;/
please help... this cm10.1 is realy good ROM, and it will be awsom to get it working on my pmp5870c
2013/10/14
Try this for fix storage problem http://crewrktablets.arctablet.com/?wpfb_dl=648
Install from cwm
2013/10/21
and this is logcat with phone.apk FC's
sebiks - if there would be format problem it would be not working all the time... but this is somethimes working the problem is i think in mounting partitions
netlars
The best way to learn
Could you pls compile instructions so that other user can participate?
RyrzyPer aspera ad astra, we rock the Tablets !
2013/10/21
hehe true
so... the main problem was that i didn't flash boot.img with cm10.1 changes... after flash that boot file the phone.apk and wifi was working.... but wifi dhcp didn't work.... problem was in my install script (i dont install cm from system.img, i have made cwm zip). i have no give permissions to dhcp files in my updater-script:
set_perm(1014, 2000, 0550, "/system/etc/dhcpcd/dhcpcd-run-hooks");
now wifi works
now i have to fix/change:
- mounting mass storage to pc - only sdcard is mounting on PC
- remove bluetooth menu from settings - my prestigio dont have bt,
maybe i will try to compile this cm from Your sources and remove bt from config but i dont know how long it takes on my i5
2013/10/21
btw
Oma/netlars, can you add support for bluetooth usb dongles ? i found something like that:
http://stackoverflow.com/questions/17608727/does-android-4-2-2-support-usb-bluetooth-dongle
maybe it will work on tablets without bt on board
btw. in settings -> battery i don't have info with app battery usage... - fix from download didn't fix this ... it's not real problem but you should know this
2013/10/21
hi
i'm trying to make working mobile data menu in settings, i have made changes in /overlay/frameworks/base/core/res/res/values/config.xml like this:
ril.pppchannel=/dev/ttyUSB2
rild.libpath=/system/lib/libril-rk29-dataonly.so
ril.function.dataonly=1
Currently Online: sadako11
68 Guest(s)
Devices in use: Desktop (63), Phone (6)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
