CM10.1 on Cube U9GT3 : Bootloop on Recovery
stefstef
2013/10/17 - 22:56
I tried to install build "Crew RKTablets Genio CM10.1 v1.3.2" on U9GT3 (U9GT3, not the U9GT3-S version) with no success.
I used kernel "RK30 Kernel 308 U9gt3 Cube" but I boot only on recovery after wipe and restart.
I miss something ?
Thanks in advance for answer.
netlars
Forum Posts: 149
Thanks Received: 29
2013/10/18 - 13:20
bevor you flash, klick on Erase IDB in the rkflashtool!
Please tray again.
stefstef
2013/10/18 - 19:42
It doesn't work.
Seems that there is no /system.
Any ideas ?
Thanks.
stefstef
2013/10/20 - 01:32
I tried extract "parameter" from stock rom with no success.
Recovery seems to search /cache on mtdblock6 but in stock rom /cache is on mtdblock5.
Is the CrewRKTablets_CM10.1_Format_NAND_Fix.zip incorrect for U9GT3 ?
stefstef
2013/10/24 - 23:40
:( Someone can help me ?
netzeens
2013/10/26 - 21:00
I have the same problem whit Go Clever Terra 70.
Edit:  Oma7144 mentioned that stock RK30 recovery might help and it did for me. http://crewrktablets.arctablet.com/?wpfb_dl=1036
stefstef
2013/10/27 - 22:34
It works with generic rk3066 CWM :)
But no Wifi :(
I tried to copy wlan.ko from stock rom without success.
What can i do now ?
stefstef
2013/10/30 - 00:19
Wifi works, solution is strange but it works :
  • I copy rkwifi.ko, wlan.ko and 8188eu.ko from stock rom
  • Rename "8188eu.ko" to "8192cu.ko" (module load by default in CM10.1)
  • Flash in recovery (using androtab recovery)
Just two things don't work yet :
  • Glitch during rotation animation
  • Ambient sensor not recognize
2013/10/31 - 22:33
Can you pls test this wifi loader? http://forum.xda-developers.com/showpost.php?p=46191771&postcount=501
pssecretajent
stefstef
2013/11/24 - 21:58
Do you know how configure light sensor cm3202 ?
Thanks in advance.
2013/11/24 - 22:25
Pls flash this boot.img: http://crewrktablets.arctablet.com/?wpfb_dl=1227
stefstef
stefstef
2013/11/24 - 23:46
It doesn't work : bootloop on bootanimation.
But thank you to answer my question :)
Another thing : I have glitch on rotation animation, my tabs is 8 inch 1024/768 and the glitch is not present on the 1024/600 surface (it's just a strip). There is a relation ?
61 Guest(s)
Devices in use: Desktop (55), Phone (6)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
