2013/07/20
Hi
I had a look at the Rk3066 tablets with CM10.1 and I found the Archos 70 Titanium succesfully running it. I've compared the hardware between the 70 Titanium and 80 Titanium and they only seem to have a different sized screen, same cpu and gpu. Could I safely try to install 70 Titanium's CM10.1 into the 80 Titanium? Will the kernel work given the fact the only difference seems to be in the size of the screen? If not, could anyone make a few changes to the 70 Titanium kernel for it to work in the 80 Titanium? I'm a total newbie
Thank you very much
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1708
Build: http://crewrktablets.arctablet.com/?p=1913
Let me know how it works.
2013/07/20
Tha major issue is that the touchscreen seems to be recognized as a touchpad and it shows the mouse pointer and I have to drag it to the icon or whatever I want to click, it works like a mouse and not like a touchscreen, very annoying, I don't know how to fix it
Front camera is not recognized
Wifi works
I haven't played wery much with it because I'd like to fix the touchscreen problem first.
Are the sensor fixes zip's meant to solve this issue?
Many thanks for your time and effort
Here is a fix for the touch (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1711
2014/06/25
Hi Oma7144
I guess that an Archos 101 titanium (with the devoted kernel) should have just minor similar bug(s?). Are all the fix available at http://crewrktablets.arctablet.com/?p=1913 , or there are other sources?
thks?
Edit: I have the complete list I guess:
http://crewrktablets.arctablet.com/?page_id=433
But should I apply all th fixes just in case, or wait the problem to show up?
References are here: http://crewrktablets.arctablet.com/?p=1913
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1037
Just the format_NAND. Other we will see when the build is running.
2013/04/03
Hi Oma I know this is an old thread but hopefully you can help. I have successfully installed CM 10.1 on my archos 80 titanium but the tablet won't auto rotate the screen, it stays in landscape mode. I can force it to portrait mode either by selecting it in nova settings or by launching an app which requires it, but even then it is upside down. I have tried the fix involving androsensor and also another app to try and calibrate the sensor but both either state "waiting for event" or just hang until i close the app. Have you got any suggestions what i can try next? Cheers
Ok, so I guess the latest model fix works? http://crewrktablets.arctablet.com/?wpfb_dl=1730
Sensor fixes are here, you need to check: http://crewrktablets.arctablet.com/?p=1913
61 Guest(s)
Devices in use: Desktop (50), Phone (11)
cutierogue
