2013/11/15
Installed this rom with another charger "Rkandroid-1.35" and loader "Rk30xxloader (L) _v1.18.bin, the other was the 1.35.bin.
Wifi works, when you rotate the screen goes dark for a moment and turns, camera mode, to save photos extsd not detected, the touch screen is white circle and need to move the circle to the application, restarting to recovery only see a robot with a red triangle ...
Sorry for my English I am Spanish and this is the translator of google.
Thanks for the rom.
Greetings, Oma.
What is the exact name of the Tab?
Why didn't you use the RKAndroidTool in the pack?
Robot with a red triangle means you have used stock recovery?
Use an USB-mouse and provide a dmesg log.
-Viewsonic-Per aspera ad astra, we rock the Tablets !
2013/11/15
Well, now i install Arctool and download cwm 6.0.3.1 and...work!!!
My tab is an Nevir, Brand Spanish,
Original:
ro.product.model=NVR-TAB97 S1 (4GB)
ro.build.display.id=rk30sdk-eng 4.1.1 JRO03H 20130226.121105 release-keys
kernel version 3.0.8+ (EM3066-911B@V02) (gcc version 4.4.3 (GCC) ) #204 SMP PREEMPT Thu Feb 28 11:32:21 CST 2013
Now send dmesg:
Greets.
Tab 97 or Tab 8 ? I guess the link is not right.
Install format_NAND and model fix via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=1219
2013/11/15
Tab 97 or Tab 8 ? I guess the link is not right.Â
Tab 97 is the model, my tab is 9.7 inchs, sorry its wrong link.  http://www.nevir.es/TAB97-S1-4GB.html
That makes format_nand?.
format_NAND: http://crewrktablets.arctablet.com/?wpfb_dl=920
Will format the user partitions. Cam should also work then.
model fix: http://crewrktablets.arctablet.com/?wpfb_dl=1219
Will (hopefully) give you touch. Pls download again.
2013/11/15
Thanks, but i change your "ft5.idc" and i put my "sis_touch.idc" in system/usr/idc and now work.
The camera is telling me to put a ext-sd to save photos.
Thanks.
Perfect!!!!, and now i can save photos in etx-sd.
You are a big Genius.
Thanks a lot and sorry for the incovenience.
There it is my "idc" if someone can help.
I can not believe, 9600 in AnTuTu. In my original rom 14400 ...
JB 4.2 uses an other governor. For Antutu set the governor to performance.
Updated model fix: http://crewrktablets.arctablet.com/?wpfb_dl=1219
Can you pls compile some instructions, so that user users can participate. Many thanks!
2013/11/15
Well, after doing some performance testing, I see that it is something "poor".
In NenaMark2 gives me 44 FPS, and in my Original Rom gives me 56.3 FPS.
In 9500-9600 Antutu 4.1.1 gives me and my Original Rom 14411 ...
I see the graphics somewhat slow, no, there is something out there that freezes performance.
What will?.
Thank you.
PS The ROM itself is good.
Greets.
69 Guest(s)
Devices in use: Desktop (61), Phone (8)
