2015/09/19
Hi Oma, I tried your CM10.1 roms (all 3 versions, 1.3.4, 1.3.5 and 1.4) with both Kernel 308 A10 Teclast & RK30 Kernel 308 A10 8dm1 Teclast downloaded from the website, it turns out that my pad stops booting at the teclast logo.
Then I tried the kernel from teclast, Teclast_A102_8DM1-Android4.1.1-V2.01-2F31(I can share it if you need), your CM10.1 works fine, except that I can't turn wifi on, neither does the brightness adjust work.
I learned from previous posts here and tried cat /sys/class/rkwifi/chip, but the file is empty (Now I'm back on teclast rom and find the file still empty, weird)
and dmesg shows
<6>[ 0.000000] Initializing cgroup subsys cpu
<5>[ 0.000000] Linux version 3.0.8+ (root@sc-development-android) (gcc version 4.4.3 (GCC) ) #324 SMP PREEMPT Wed Oct 31 15:36:48 CST 2012
<4>[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
<4>[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[ 0.000000] Machine: RK30board
<6>[ 0.000000] memory reserve: Memory(base:0x91800000 size:80M) reserved for <ion>
<6>[ 0.000000] memory reserve: Memory(base:0x90c00000 size:12M) reserved for <fb0>
<6>[ 0.000000] memory reserve: Memory(base:0x90000000 size:12M) reserved for <ipp buf>
<6>[ 0.000000] memory reserve: Memory(base:0x8f400000 size:12M) reserved for <fb2>
<6>[ 0.000000] memory reserve: Memory(base:0x8f000000 size:4M) reserved for <camera_ipp_mem>
<6>[ 0.000000] memory reserve: Total reserved 120M
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback
<6>[ 0.000000] bootconsole [earlycon0] enabled
<4>[ 0.000000] CPU SRAM: copied sram code from c0b10000 to fef00100 - fef020e8
<4>[ 0.000000] CPU SRAM: copied sram data from c0b11fe8 to fef03000 - fef0385c
<6>[ 0.000000] L310 cache controller enabled
<6>[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
<4>[ 0.000000] DDR DEBUG: version 1.00 20120608
<4>[ 0.000000] DDR DEBUG: DDR3 Device
<4>[ 0.000000] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB
<4>[ 0.000000] DDR DEBUG: init success!!! freq=360MHz
<4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=0
<4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x5, DGSL=1 extra clock, DGPS=90
<4>[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
<4>[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.000000] rk30_iomux_init
<4>[ 0.000000] Boot mode: 6 flag: 0xc3524200
<7>[ 0.000000] On node 0 totalpages: 231424
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0b0ea60, node_mem_map c1593000
<7>[ 0.000000] Normal zone: 1744 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 190768 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 304 pages used for memmap
<7>[ 0.000000] HighMem zone: 38608 pages, LIFO batch:7
<6>[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1d9b000 s7072 r8192 d13408 u32768
<7>[ 0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 229376
<5>[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x001D0000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00008000@0x00010000(recovery),0x000C0000@0x00018000(backup),0x00040000@0x000D8000(cache),0x00500000@0x00118000(userdata),0x00002000@0x00618000(kpanic),0x00140000@0x0061A000(system),-@0x0075A000(user) bootver=2013-06-20#1.34 firmware_ver=4.1.1
<6>[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Memory: 752MB 152MB = 904MB total
<5>[ 0.000000] Memory: 896764k/896764k available, 151812k reserved, 155648K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
<5>[ 0.000000] vmalloc : 0xf7000000 - 0xfe800000 ( 120 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xf6800000 ( 872 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .init : 0xc0408000 - 0xc04e4000 ( 880 kB)
<5>[ 0.000000] .text : 0xc04e4000 - 0xc0aa35f8 (5886 kB)
<5>[ 0.000000] .data : 0xc0aa4000 - 0xc0b0f580 ( 430 kB)
<5>[ 0.000000] .bss : 0xc0b13024 - 0xc1592658 (10750 kB)
<6>[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:416
<4>[ 0.000000] rk30_gpio_init: 176 gpio irqs in 6 banks
<6>[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<6>[ 0.000000] Console: colour dummy device 80x30
<6>[ 0.004958] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
<6>[ 0.013886] pid_max: default: 32768 minimum: 301
<6>[ 0.019100] Mount-cache hash table entries: 512
<6>[ 0.024586] Initializing cgroup subsys debug
<6>[ 0.029210] Initializing cgroup subsys cpuacct
<6>[ 0.034153] Initializing cgroup subsys freezer
<6>[ 0.038985] CPU: Testing write buffer coherency: ok
<4>[ 0.144983] CPU1: Booted secondary processor
<6>[ 0.145028] Brought up 2 CPUs
<6>[ 0.152868] SMP: Total of 2 processors activated (3262.93 BogoMIPS).
<6>[ 0.160033] devtmpfs: initialized
<6>[ 0.171157] NET: Registered protocol family 16
<4>[ 0.175978] last_log: 0xee900000 0xc0b14620
<6>[ 0.282985] rk29sdk_wifi_bt_gpio_control_init: init finished
<6>[ 0.293521] console [ttyFIQ0] enabled, bootconsole disabled
<6>[ 0.299541] Registered FIQ tty driver ee88fc00
<6>[ 0.311806] bio: create slab <bio-0> at 0
<4>[ 0.316024] wm831x_dcdc_init
<4>[ 0.316206] wm831x_ldo_init
<5>[ 0.316567] SCSI subsystem initialized
<6>[ 0.316759] usbcore: registered new interface driver usbfs
<6>[ 0.316833] usbcore: registered new interface driver hub
<6>[ 0.319050] usbcore: registered new device driver usb
<6>[ 0.319368] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
<6>[ 0.319602] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
<6>[ 0.319918] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
<6>[ 0.320045] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
<6>[ 0.320156] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
<6>[ 0.367936] rk30-adc rk30-adc: rk30 adc: driver initialized
<4>[ 0.368027]
<4>[ 0.368031] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 0.368042] $$$$-->[ DBG_Trace ]--> Battery-charge-->rk30_adc_battery_probe--Ready!!
<4>[ 0.368058] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 0.368063]
<4>[ 0.679046]
<4>[ 0.679050] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 0.679063] $$$$-->[ DBG_Trace ]--> Battery-charge-->rk30_adc_battery_probe--OK!!
<4>[ 0.679079] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 0.679084]
<4>[ 0.679358] timed_gpio_probe
<6>[ 0.679446] Advanced Linux Sound Architecture Driver Version 1.0.24.
<6>[ 0.679845] Bluetooth: Core ver 2.16
<6>[ 0.679893] NET: Registered protocol family 31
<6>[ 0.679905] Bluetooth: HCI device and connection manager initialized
<6>[ 0.679921] Bluetooth: HCI socket layer initialized
<6>[ 0.679934] Bluetooth: L2CAP socket layer initialized
<6>[ 0.679957] Bluetooth: SCO socket layer initialized
<6>[ 0.680152] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.724580]
<4>[ 0.724585] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 0.724596] $$$$-->[ DBG_Trace ]--> Battery_status( 3 ), Real_AD_value( 837 ), Real_vol( 4086V),Disp_vol( 4086V ),
<4>[ 0.724622] Disp_capactiy( 100 ), Real_capacity( 100 ), discharge counts( 1 ), charge counts( 0 ),
<4>[ 0.724629] b_rk30_charged(0),base_var_capacity(1),step_var_capacity(1),total_time(5000),zpp_var_tire(600),DeBUG_CountB(1)
<4>[ 0.724654] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 0.724658]
<4>[ 0.786466] rk fb probe ok!
<4>[ 0.786573] wm831x_i2c_init
<6>[ 0.788548] wm831x 1-0034: WM8326 revision C
<4>[ 0.789202] wm831x 1-0034: Security key had non-zero value 1
<4>[ 0.790911] +++The vbat is too low+++
<4>[ 0.805944] wm831x_irq_init:irq=324,352
<4>[ 0.817355] wm831x_gpio_probe
<4>[ 0.858237] wm831x_post_init:g_pmic_type=1
<4>[ 0.873400] wm831x_post_init set dcdc2 vdd_cpu(vdd_arm)=1100000mV end
<4>[ 0.888909] wm831x_post_init set dcdc1 vdd_core(vdd_log)=1150000mV end
<4>[ 0.919585] wm831x_post_init end
<3>[ 0.920554] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ 0.920826] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ 0.921096] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ 0.921115] tps65910 1-002d: tps65910_set_bits:read from reg 3f failed
<3>[ 0.921384] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ 0.921654] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ 0.921922] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ 0.921939] tps65910 1-002d: read from reg 46 failed
<3>[ 0.921952] tps65910 1-002d: Error in configuring external control EN1
<4>[ 0.921965] tps65910 1-002d: Failed to initialise ext control config
<3>[ 0.922316] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ 0.922587] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ 0.922856] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ 0.922876] tps65910 1-002d: tps65910_set_bits:read from reg 20 failed
<3>[ 0.922890] set_machine_constraints: VIO: failed to enable
<3>[ 0.922956] tps65910 1-002d: failed to register tps65910-pmic regulator
<4>[ 0.922977] tps65910-pmic: probe of tps65910-pmic failed with error -11
<4>[ 0.923121] tps65910_pre_init,line=38
<3>[ 0.923395] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ 0.923666] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ 0.923936] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ 0.923954] tps65910 1-002d: Read from reg 0x40 failed
<3>[ 0.923964] Unable to read TPS65910_DEVCTRL2 reg
<3>[ 0.923976] tps65910 1-002d: pre_init() failed: -11
<4>[ 0.924116] tps65910: probe of 1-002d failed with error -11
<6>[ 0.924335] Switching to clocksource timer1
<6>[ 0.924461] Switched to NOHz mode on CPU #0
<4>[ 0.924678] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf701c000
<4>[ 0.924871] lcdc0: dclk:99750000>>fps:59 rk30_load_screen for lcdc0 ok!
<6>[ 0.925023] Switched to NOHz mode on CPU #1
<4>[ 0.948783] fb0:phy:90c00000>>vir:f8000000>>len:0xc00000
<4>[ 0.948946] rk_fb_register>>>>>fb0
<4>[ 0.949082] rk_fb_register>>>>>fb1
<4>[ 0.949095] lcdc0 wakeup from stanby
<6>[ 0.949104] lcdc0 win1 open
<4>[ 0.955723] rk30 lcdc0 probe ok!
<4>[ 0.955768] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xf7028000
<4>[ 0.955834] lcdc1: dclk:74250000>>fps:60 rk30_load_screen for lcdc1 ok!
<4>[ 0.981582] fb2:phy:8f400000>>vir:f9000000>>len:0xc00000
<4>[ 0.981753] rk_fb_register>>>>>fb2
<4>[ 0.981890] rk_fb_register>>>>>fb3
<4>[ 0.981900] rk30 lcdc1 probe ok!
<4>[ 0.981956] boot with wm831x dont need pwm_regultor
<6>[ 0.988574] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
<6>[ 1.184641] NET: Registered protocol family 2
<6>[ 1.184763] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 1.185096] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
<6>[ 1.186930] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>[ 1.187990] TCP: Hash tables configured (established 131072 bind 65536)
<6>[ 1.188003] TCP reno registered
<6>[ 1.188016] UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 1.188055] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 1.188400] NET: Registered protocol family 1
<4>[ 1.427619] rk30 Backlight Driver Initialized.
<6>[ 3.434031] Unpacking initramfs...
<6>[ 3.530883] Freeing initrd memory: 1856K
<6>[ 3.531075] rk30-tsadc rk30-tsadc: initialized
<6>[ 3.531852] Loaded driver for PL330 DMAC-1 rk29-pl330
<6>[ 3.531869] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
<6>[ 3.532016] Loaded driver for PL330 DMAC-2 rk29-pl330
<6>[ 3.532031] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
<4>[ 3.538652] highmem bounce pool size: 64 pages
<6>[ 3.538828] ashmem: initialized
<6>[ 3.543832] fuse init (API version 7.16)
<6>[ 3.545331] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ 3.545350] io scheduler noop registered
<6>[ 3.545360] io scheduler deadline registered
<6>[ 3.545414] io scheduler cfq registered (default)
<6>[ 3.551330] rga: Driver loaded succesfully
<6>[ 3.552060] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
<6>[ 3.594426] rk_serial rk_serial.0: membase 0xf704c000
<6>[ 3.594490] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
<6>[ 3.694488] rk_serial rk_serial.3: membase 0xf7050000
<6>[ 3.695358] Rockchip ion module(version: 1.0) is successfully loaded
<6>[ 3.703333] loop: module loaded
<6>[ 3.703648] Android kernel panic handler initialized (bind=kpanic)
<6>[ 3.705941] PPP generic driver version 2.4.2
<6>[ 3.706573] PPP Deflate Compression module registered
<6>[ 3.706616] PPP BSD Compression module registered
<6>[ 3.708401] PPP MPPE Compression module registered
<6>[ 3.708447] NET: Registered protocol family 24
<6>[ 3.708645] usbcore: registered new interface driver asix
<6>[ 3.708797] usbcore: registered new interface driver cdc_ether
<6>[ 3.708938] usbcore: registered new interface driver dm9620
<6>[ 3.709105] usbcore: registered new interface driver SR9700_android
<6>[ 3.709251] usbcore: registered new interface driver net1080
<6>[ 3.709394] usbcore: registered new interface driver cdc_subset
<6>[ 3.709532] usbcore: registered new interface driver zaurus
<6>[ 3.709601] cdc_ncm: 04-Aug-2011
<6>[ 3.709737] usbcore: registered new interface driver cdc_ncm
<4>[ 3.709774] Rockchip WiFi SYS interface (V2.00) ...
<6>[ 3.709895] Initializing USB Mass Storage driver...
<6>[ 3.710077] usbcore: registered new interface driver usb-storage
<6>[ 3.710115] USB Mass Storage support registered.
<6>[ 3.710457] usbcore: registered new interface driver usbserial
<6>[ 3.710592] USB Serial support registered for generic
<6>[ 3.710756] usbcore: registered new interface driver usbserial_generic
<6>[ 3.710796] usbserial: USB Serial Driver core
<6>[ 3.710917] USB Serial support registered for GSM modem (1-port)
<6>[ 3.711089] usbcore: registered new interface driver option
<6>[ 3.711127] option: v0.7.2:USB Driver for GSM modems
<6>[ 3.923787] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
<6>[ 3.923807] usb20_otg usb20_otg: DWC OTG Controller
<6>[ 3.923829] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
<6>[ 3.923861] usb20_otg usb20_otg: irq 48, io mem 0x00000000
<6>[ 3.923869] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
<6>[ 3.923913] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 3.923923] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 3.923932] usb usb1: Product: DWC OTG Controller
<6>[ 3.923939] usb usb1: Manufacturer: Linux 3.0.8+ dwc_otg_hcd
<6>[ 3.923946] usb usb1: SerialNumber: usb20_otg
<6>[ 3.924215] hub 1-0:1.0: USB hub found
<6>[ 3.924229] hub 1-0:1.0: 1 port detected
<6>[ 3.924762] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xf7100000
<6>[ 4.135230] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 4.135252] usb20_host usb20_host: DWC OTG Controller
<6>[ 4.135272] usb20_host usb20_host: new USB bus registered, assigned bus number 2
<6>[ 4.135294] usb20_host usb20_host: irq 49, io mem 0x00000000
<6>[ 4.135331] DWC_OTG: Init: Port Power? op_state=1
<6>[ 4.135337] DWC_OTG: Init: Power Port (0)
<6>[ 4.135368] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 4.135378] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 4.135386] usb usb2: Product: DWC OTG Controller
<6>[ 4.135393] usb usb2: Manufacturer: Linux 3.0.8+ host20_hcd
<6>[ 4.135400] usb usb2: SerialNumber: usb20_host
<6>[ 4.135634] hub 2-0:1.0: USB hub found
<6>[ 4.135646] hub 2-0:1.0: 1 port detected
<6>[ 4.136713] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 4.136724] android_usb gadget: Number of LUNs=2
<6>[ 4.136732] lun0: LUN: removable file: (no medium)
<6>[ 4.136739] lun1: LUN: removable file: (no medium)
<6>[ 4.136876] android_usb gadget: android_usb ready
<4>[ 4.136970] ct360_ts_init
<4>[ 4.136996]
<4>[ 4.136998] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.137005] $$$$-->[ DBG_Trace ]--> TouchPanel-->ct360_ts_probe--Ready
<4>[ 4.137013] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.137015]
<3>[ 4.515109] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 2...
<3>[ 4.515621] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 1...
<3>[ 4.516127] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 0...
<4>[ 4.516181] ct360_ts_work_func:i2c_transfer fail =-11
<4>[ 4.516247] ct360_ts: probe of 2-0001 failed with error -11
<4>[ 4.517053]
<4>[ 4.517065] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.517102] $$$$-->[ DBG_Trace ]--> Gsensor-->lis3dh_probe Ready
<4>[ 4.517146] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.517160]
<4>[ 4.517572] lis3dh devid:33
<6>[ 4.522709] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-0019/input/input1
<4>[ 4.523388]
<4>[ 4.523399] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.523435] $$$$-->[ DBG_Trace ]--> Gsensor-->lis3dh_probe-->OK!!!
<4>[ 4.523479] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.523494]
<6>[ 4.531370] usb 2-1: new high speed USB device number 2 using usb20_host
<6>[ 4.539674] using rtc device, wm831x, for alarms
<6>[ 4.539712] wm831x-rtc wm831x-rtc: rtc core: registered wm831x as rtc0
<6>[ 4.541268] lirc_dev: IR Remote Control driver registered, major 250
<6>[ 4.541284] IR NEC protocol handler initialized
<6>[ 4.541295] IR RC5(x) protocol handler initialized
<6>[ 4.541305] IR RC6 protocol handler initialized
<6>[ 4.541314] IR JVC protocol handler initialized
<6>[ 4.541324] IR Sony protocol handler initialized
<6>[ 4.541334] IR RC5 (streamzap) protocol handler initialized
<6>[ 4.541344] IR LIRC bridge handler initialized
<6>[ 4.541353] Linux video capture interface: v2.00
<6>[ 4.541982] device-mapper: uevent: version 1.0.3
<6>[ 4.542269] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
<6>[ 4.542519] Bluetooth: HCI UART driver ver 2.2
<6>[ 4.542534] Bluetooth: HCI H4 protocol initialized
<6>[ 4.542545] Bluetooth: HCILL protocol initialized
<6>[ 4.542710] cpuidle: using governor ladder
<6>[ 4.542724] cpuidle: using governor menu
<6>[ 4.608698]
<6>[ 4.608701] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc0]
<6>[ 4.613755] rk29_sdmmc_change_clk_div..1921.. newDiv=83, newCLK=298Khz [sd_mmc]
<6>[ 4.613801] .Line3796..The End of SDMMC-probe Ver.4.06 The last modify date is 2012-09-26. [sd_mmc]
<6>[ 4.613965] .Line3796..The End of SDMMC-probe Ver.4.06 The last modify date is 2012-09-26. [sdio]
<4>[ 4.614047] leds-gpio: probe of leds-gpio failed with error -16
<6>[ 4.615316] usbcore: registered new interface driver usbhid
<6>[ 4.615325] usbhid: USB HID core driver
<6>[ 4.615603] logger: created 256K log 'log_main'
<6>[ 4.615679] logger: created 256K log 'log_events'
<6>[ 4.615746] logger: created 256K log 'log_radio'
<6>[ 4.615812] logger: created 256K log 'log_system'
<6>[ 4.648638]
<6>[ 4.648641] mmc_attach_sd..1218.. ===== Begin to identify card as SD-card. [mmc0]
<6>[ 4.697153] rk29_sdmmc_change_clk_div..1921.. newDiv=0, newCLK=49500Khz [sd_mmc]
<6>[ 4.697223] mmc0: new high speed SDHC card at address 0002
<6>[ 4.733276] mmcblk0: mmc0:0002 SDMMC 29.8 GiB
<6>[ 4.734348]
<6>[ 4.734351] msdos_partition..461... ==== Begin to parse sdcard-partition. [mmc0]
<6>[ 4.734364] msdos_partition..530... ==== The sdcard has MBR. [mmc0]
<6>[ 4.734469] msdos_partition..543... ==== partition-1, size=31322112KB [mmc0]
<6>[ 4.734483] msdos_partition..571... ==== main partition-1....[mmc0]
<6>[ 4.734492] mmcblk0: p1
<6>[ 4.734932] mmc_rescan_try_freq..1721.. ===== Initialize SD-card successfully. [mmc0]
<6>[ 4.734949]
<6>[ 4.734952] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc1]
<4>[ 4.734963]
<4>[ 4.734965] =================
<4>[ 4.734968] mmc_rescan..1834.. ====find no SDMMC host. [mmc1]
<6>[ 4.735946] usb 2-1: New USB device found, idVendor=0bda, idProduct=8176
<6>[ 4.735958] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 4.735968] usb 2-1: Product: 802.11n WLAN Adapter
<6>[ 4.735976] usb 2-1: Manufacturer: Realtek
<6>[ 4.735983] usb 2-1: SerialNumber: 00e04c000001
<3>[ 4.740038] RT5631 0-001a: dapm: unknown pin HP_L
<3>[ 4.740049] RT5631 0-001a: dapm: unknown pin HP_R
<6>[ 4.760951] asoc: RT5631 HiFi <-> rk29_i2s.0 mapping ok
<6>[ 4.761279] ALSA device list:
<6>[ 4.761287] #0: RK29_RT5631
<6>[ 4.761371] GACT probability NOT on
<6>[ 4.761381] Mirror/redirect action on
<6>[ 4.761388] u32 classifier
<6>[ 4.761393] Actions configured
<6>[ 4.761401] Netfilter messages via NETLINK v0.30.
<6>[ 4.761441] nf_conntrack version 0.5.0 (14040 buckets, 56160 max)
<6>[ 4.761784] ctnetlink v0.93: registering with nfnetlink.
<6>[ 4.761824] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 4.761833] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 4.762016] xt_time: kernel timezone is -0000
<6>[ 4.762149] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 4.762279] arp_tables: (C) 2002 David S. Miller
<6>[ 4.762323] TCP cubic registered
<6>[ 4.762700] NET: Registered protocol family 10
<6>[ 4.763265] Mobile IPv6
<6>[ 4.763296] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 4.763403] IPv6 over IPv4 tunneling driver
<6>[ 4.764044] NET: Registered protocol family 17
<6>[ 4.764073] NET: Registered protocol family 15
<5>[ 4.764153] Bridge firewalling registered
<6>[ 4.764257] Bluetooth: RFCOMM TTY layer initialized
<6>[ 4.764287] Bluetooth: RFCOMM socket layer initialized
<6>[ 4.764295] Bluetooth: RFCOMM ver 1.11
<6>[ 4.764303] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 4.764312] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 4.764462] NET: Registered protocol family 35
<6>[ 4.764673] [BT_RFKILL]: Enter rfkill_rk_init
<6>[ 4.764760] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 4.764781] [BT_RFKILL]: ** disable irq
<6>[ 4.794386] [BT_RFKILL]: bt shut off power
<6>[ 4.824393] [BT_RFKILL]: bt_default device registered.
<4>[ 4.824482]
<4>[ 4.824485] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.824493] $$$$-->[ DBG_Trace ]--> TouchPanel-->ft5406_probe--Ready
<4>[ 4.824502] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 4.824505]
<4>[ 4.824512] focaltech_init_platform_hw
<6>[ 5.155493] input: focaltech_ts as /devices/virtual/input/input2
<4>[ 5.364487]
<4>[ 5.364500] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 5.364543] $$$$-->[ DBG_Trace ]--> TouchPanel-->ft5406_probe--OK!!!
<4>[ 5.364589] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 5.364604]
<6>[ 5.365712] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<3>[ 5.367751]
<3>[ 5.367762] rk_camera_probe Memory(start:0x8f000000 size:0x400000) for IPP obtain
<6>[ 5.368712] camera 33-0-gc0308_front: RK Camera driver attached to camera0(gc0308_front)
<3>[ 5.368790] rk_camera_add_device..1007..
<4>[ 5.372016]
<4>[ 5.372029] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 5.372066] $$$$-->[ DBG_Trace ]--> TouchPanel-->novatek_ts_probe--Ready
<4>[ 5.372113] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 5.372127]
<4>[ 5.372159] novatek_init_platform_hw gpio_request error
<6>[ 5.372202] novatek-ts 2-0016: platform data before i2c_set_clientdata!
<6>[ 5.372244] novatek-ts 2-0016: platform data before start read chipID !
<6>[ 5.372790] camera 33-0-gc0308_front: RK Camera driver detached from camera0(gc0308_front)
<3>[ 5.385263] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 2...
<3>[ 5.386256] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 1...
<3>[ 5.386810] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 0...
<3>[ 5.387670] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 2...
<3>[ 5.388096] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 1...
<3>[ 5.388518] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 0...
<3>[ 5.388940] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 2...
<3>[ 5.389361] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 1...
<3>[ 5.389781] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 0...
<3>[ 5.390203] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 2...
<3>[ 5.390623] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 1...
<3>[ 5.391043] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 0...
<3>[ 5.391462] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 2...
<3>[ 5.391879] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 1...
<3>[ 5.392297] i2c i2c-2: No ack, Maybe slave(addr: 0x16) not exist or abnormal power-on, retry 0...
<4>[ 5.392314] >>>koffuxu Novatek IC test Error ret = -11
<4>[ 5.392324] novatekh_exit_platform_hw
<4>[ 5.394460]
<4>[ 5.394465] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 5.394476] $$$$-->[ DBG_Trace ]--> TouchPanel-->goodix_ts_probe--Ready
<4>[ 5.394491] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
<4>[ 5.394496]
<6>[ 5.474407] camera 33-0-gc0308_front: Probe gc0308_front success
<3>[ 5.574637] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
<3>[ 5.574891] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
<3>[ 5.575142] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
<3>[ 5.604682] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
<3>[ 5.604937] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
<3>[ 5.605189] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
<3>[ 5.634635] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
<3>[ 5.634888] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
<3>[ 5.635141] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
<3>[ 5.664385] Goodix-TS-gt8xx 2-005d: Warnning: I2C communication might be ERROR!
<4>[ 5.664407] Goodix-TS-gt8xx: probe of 2-005d failed with error -1
<6>[ 5.666750] wm831x-rtc wm831x-rtc: setting system clock to 2015-09-18 11:25:37 UTC (1442575537)
<6>[ 5.667025] Freeing init memory: 880K
<3>[ 5.673360] init: /init.cm.rc: 47: ignored duplicate definition of service 'sysinit'
<4>[ 5.673463] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<6>[ 5.714927] keychord: using input dev rk29-keypad for fevent
<3>[ 5.715094] init: cannot open '/initlogo.rle'
<4>[ 5.909892] gp_rknand_info = : 0xed4fe000
<4>[ 5.910323] request IRQ_NANDC irq , ret=0.........
<4>[ 5.910538] FlashCopyProgBuf1=0xc1436000
<4>[ 5.910605] ATime: 40 ns AHB: 148 timming: 1081
<4>[ 5.910652] No.1 FLASH INFO:ad de 94 d2 4
<4>[ 5.910700] No.3 FLASH INFO:ad de 94 d2 4
<4>[ 5.911070] ATime: 32 ns AHB: 148 timming: 1061
<4>[ 5.911259] ATime: 32 ns AHB: 148 timming: 1061
<4>[ 5.911299] randomizer = 1 , EccBits = 18 pSpec->pReadRetrial = bf00b800
<4>[ 5.983198] FTL INFO:Version = 438,Date = 20121110
<4>[ 5.983209] totalLogicBlkRaw = 3947
<4>[ 5.983228] gBootMedia = 1 gSdmmcFwPartOffset =0!
<4>[ 5.983236] rknand_buffer.c version: 4.38 20121110!
<5>[ 5.984468] 10 cmdlinepart partitions found on MTD device rk29xxnand
<5>[ 5.984480] Creating 10 MTD partitions on "rk29xxnand":
<5>[ 5.984492] 0x000000400000-0x000000800000 : "misc"
<5>[ 5.985371] 0x000000800000-0x000001000000 : "kernel"
<5>[ 5.985979] 0x000001000000-0x000002000000 : "boot"
<5>[ 5.986494] 0x000002000000-0x000003000000 : "recovery"
<5>[ 5.986953] 0x000003000000-0x00001b000000 : "backup"
<5>[ 5.987686] 0x00001b000000-0x000023000000 : "cache"
<5>[ 5.988284] 0x000023000000-0x0000c3000000 : "userdata"
<5>[ 5.990807] 0x0000c3000000-0x0000c3400000 : "kpanic"
<6>[ 5.992101] apanic: Bound to mtd partition 'kpanic'
<6>[ 5.992110] apanic: No panic data available
<5>[ 5.992126] 0x0000c3400000-0x0000eb400000 : "system"
<5>[ 5.993124] 0x0000eb400000-0x0003dac00000 : "user"
<4>[ 6.004316] startBlk = 118 sysProtAddr = 117
<3>[ 6.004922] init: cannot find '/sbin/resize2fs'
<3>[ 6.004981] init: ext_check(/dev/block/mtdblock8): /sbin/e2fsck not found (skipping checks)
<6>[ 6.009557] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<3>[ 6.009661] init: ext_check(/dev/block/mtdblock6): /sbin/e2fsck not found (skipping checks)
<6>[ 6.043679] EXT4-fs (mtdblock6): mounted filesystem without journal. Opts: noauto_da_alloc
<3>[ 6.043784] init: ext_check(/dev/block/mtdblock5): /sbin/e2fsck not found (skipping checks)
<6>[ 6.076253] EXT4-fs (mtdblock5): mounted filesystem without journal. Opts: noauto_da_alloc
<4>[ 6.095193] UMP: UMP device driver loaded
<4>[ 6.136693] Mali: init_mali_clock mali_clock c0ac1900
<4>[ 6.141706] Mali: @@@@@@@Mali device driver loaded success@@@@@@@@
<4>[ 6.143345] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
<4>[ 6.144138] ipp irq 47
<4>[ 6.144485] IPP init, version rk30-ipp 1.001
<3>[ 6.178993] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
<3>[ 6.346172] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
<3>[ 6.354872] init: cannot find '/system/bin/drmservice', disabling 'drmservice'
<3>[ 6.354981] init: cannot find '/system/bin/chrome.sh', disabling 'chrome'
<3>[ 6.355013] init: cannot find '/system/bin/akmd8975', disabling 'akmd'
<4>[ 6.370207] vpu: power on
<6>[ 6.370255] VPU_SERVICE: HW ID = 0x67312398
<6>[ 6.370261] VPU_SERVICE: Compatible HW found at 0x10104400
<6>[ 6.370271] VPU_SERVICE: HW ID = 0x48311220
<6>[ 6.370277] VPU_SERVICE: Compatible HW found at 0x10104000
<4>[ 6.370626] vpu: power off...done
<6>[ 6.370650] VPU_SERVICE: init success
<6>[ 6.371241] rk_serial rk_serial.0: baud:9600
<4>[ 6.371249] serial.0 timeout:1000000
<6>[ 6.371409] rk_serial rk_serial.0: baud:9600
<4>[ 6.371416] serial.0 timeout:1000000
<3>[ 6.371689] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
<3>[ 6.371705] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
<3>[ 6.371911] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
<3>[ 6.371927] init: property 'ro.product.usbfactory' doesn't exist while expanding '$ro.product.usbfactory'
<3>[ 6.371939] init: cannot expand '$ro.product.usbfactory' while writing to '/sys/class/android_usb/android0/f_mass_storage/inquiry_string'
<3>[ 6.373980] android_usb: already disabled
<3>[ 6.374143] android_usb: already disabled
<6>[ 6.762704] .412.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc]
<6>[ 6.764449] .443.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
<6>[ 6.832381] .412.. MMC0 receive the message sd-Pending from VOLD.[sd_mmc]
<6>[ 6.832514] .412.. MMC0 receive the message sd-Idle-Unmounted from VOLD.[sd_mmc]
<6>[ 7.643320] camera 33-0-gc0308_front: RK Camera driver attached to camera0(gc0308_front)
<3>[ 7.643354] gc0308 sensor_ioctl cmd(0x3) is unknown !
<3>[ 7.643361] rk_camera_add_device..1007..
<6>[ 7.643589] camera 33-0-gc0308_front: RK Camera driver detached from camera0(gc0308_front)
<4>[ 8.049688] rk_fb_set_par:un supported format:0x5
<4>[ 8.049701] detected fb_set_par error, error code: -22
<4>[ 10.374400] delayed
<6>[ 32.114701] warning: `zygote' uses 32-bit capabilities (legacy support in use)
<4>[ 55.300786]
<4>[ 55.300790] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$-->Androd Start To Get Battery Capacity Ready
<4>[ 55.300807] update_capcity_on_android_boot
<4>[ 55.300812] $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$-->Androd Start To Get Battery Capacity End
<6>[ 55.318339] request_suspend_state: wakeup (3->0) at 55313963800 (2015-09-18 11:26:27.143078965 UTC)
<6>[ 119.336647] acc_open
<6>[ 119.336669] acc_release
<3>[ 120.233287] binder: release proc 626, transaction 21197, not freed
<6>[ 120.242645] .412.. MMC0 receive the message sd-Checking from VOLD.[sd_mmc]
<6>[ 120.258021] .412.. MMC0 receive the message sd-Mounted from VOLD.[sd_mmc]
<6>[ 126.796069] binder: release 1327:1327 transaction 28859 out, still active
<6>[ 126.844047] binder: 364:828 transaction failed 29189, size 7236-0
<6>[ 126.844065] binder: send failed reply for transaction 28859, target dead
<3>[ 128.212074] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
<6>[ 131.914406] [BT_RFKILL]: bt shut off power
<6>[ 132.534580] [BT_RFKILL]: bt turn on power
<6>[ 133.039581] rk_serial rk_serial.0: baud:9600
<4>[ 133.043943] serial.0 timeout:1000000
<6>[ 133.047692] rk_serial rk_serial.0: baud:9600
<4>[ 133.052048] serial.0 timeout:1000000
<6>[ 133.054596] rk_serial rk_serial.0: baud:115200
<4>[ 133.054638] serial.0 timeout:1000000
<3>[ 140.458305] binder: 1794: binder_alloc_buf failed to map pages in userspace, no vma
<6>[ 140.474016] binder: 364:812 transaction failed 29201, size 10676-0
<6>[ 140.480313] binder: send failed reply for transaction 35896 to 1794:1794
<3>[ 141.264578] binder: 1929: binder_alloc_buf, no vma
<6>[ 141.264594] binder: 364:923 transaction failed 29201, size 10880-0
<6>[ 141.264603] binder: send failed reply for transaction 37383 to 1929:1929
<6>[ 168.524951] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<3>[ 170.561747] binder: release proc 875, transaction 53687, not freed
<6>[ 174.778128] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 178.345134] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<4>[ 182.714603] wlan: Unknown symbol rkwifi_set_firmware (err 0)
<4>[ 182.720553] wlan: Unknown symbol rkwifi_set_country_code (err 0)
<4>[ 188.672698] standby rt5631
<6>[ 215.841025] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 222.148651] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<3>[ 222.212231] init: sys_prop: permission denied uid:1000 name:user.language
<3>[ 222.212414] init: sys_prop: permission denied uid:1000 name:user.region
<6>[ 226.518497] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 229.821245] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 234.158054] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 240.187447] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 243.274424] [BT_RFKILL]: bt shut off power
<6>[ 243.894479] [BT_RFKILL]: bt turn on power
<6>[ 244.397363] rk_serial rk_serial.0: baud:115200
<4>[ 244.401904] serial.0 timeout:1000000
<6>[ 248.135963] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 254.643860] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 261.907123] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<4>[ 278.473056] standby rt5631
<6>[ 318.544736] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<6>[ 349.748285] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
I really wanna use your rom, could you please tell me how to fix the problem? Thanks in advance!
101 Guest(s)
Devices in use: Desktop (84), Phone (17)
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
samih
